Question about HP iPAQ RX3700 Pocket PC
IPAQ 3700 Series - Battery not holding charge
We have several of this devices and seems like on many of them the battery of the devices (iPAQ 3765) will stop working very soon. Are there replacement batteries available? Can they be ordered? If not, how can this issue be fixed without having to use external power supplies? thank you.
    Master:
  • 450 Answers
In this model of ipaq the battery come inbuilt which means it is not enduser replaceable so cannot place an order to the battery so call HP and send the unit in for service. All the best :-)
Posted on Sep 12, 2005
My hp ipaq 614 wif is not turning on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Aug 23, 2012 | HP iPAQ 614 Business Navigator 2.8-tft...
I have the IPAQ pocket pc 3765 and I was replacing battery but when I opened I saw the battery door out of its place but I do not know where is located then I can not to finish my work. Can you describe...
Welcome to Fixya
As far as i can remember, there are no battery door for ipaq. Once the device opens, gently pry out the original battery. This one should come right off (it is only stuck using some double sided tape). All you need to do is to replace the double adhesive tape if you are going to replace the battery then close the unit. Tip: Use an old credit card or something that won't damage the case to gently lift the battery out.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Jul 04, 2011 | Computers & Internet
Replacement battery installed & still won't charge for iPaq 3600
he is correct, it needs service.
this product has no support now, why not retire it like 99.9% have.
its soldered in not welded, using toxic, lead/tin solder.
nobody uses these now, they all use Cell phones, smart now.
ask here, but see the ***** thing there, the OOPS
https://h30434.www3.hp.com/t5/forums/searchpage/tab/message?advanced=false&allow_punctuation=false&q=iPaq+3600
everyone else left the 20th centry now;. it seems..
Sep 29, 2017 | HP iPAQ H3835 Pocket PC
Data missing - Ipaq model HP5555 - did not do hard reset
I'm sorry but the HP Ipaq 55xx series store data on a volatile ram based memory. Unlike a nand flash (like usb sticks, memory cards etc) this memory will hold data only as long as it's powered on. If your main battery gets empty you should still be able to retain your files for some 10-20hrs with the backup battery (if it's ok itself and not depleted). After this time the power to the ram memory is cut off and all data is lost.
The problem you face is somewhat related to that backup battery, as it appears it's unable to do it's job and maintain the power to the ram memory at least some 10 hrs. You should have that battery replaced.
There is no way to recover the data from the ram memory as it is stored as an electric charge over some memory cells in the ram chips. When there is no power, these charges dissipate and the pattern is lost.
I'm sorry for having to give the bad news.
Bogdan
Jul 03, 2009 | HP iPAQ H5555 Pocket PC
Compaq iPAQ H3800 Pocket PC
I had the same problem with my iPAQ H3800. I bought a replacement battery on eBay for £7.49 and now it's fine.
Dec 11, 2008 | Compaq iPAQ H3850 Pocket PC
Battery
This IPAQ will not support 3rd party battery manufacturers. Ensure you are using an original HP battery. You usually can use the battery one time--but when the charge runs out, so does your luck.
Most of the time you will get an on-screen warning that the battery will not be able to charge when you use a 3rd party battery. If you are using an original, you might need a new battery--they do wear out after time--too-old batteries no longer hold a charge.
Jan 21, 2008 | HP iPAQ h6315/h6365 Pocket PC
IPAQ 3765 Won't Turn On
you may have to buy a new battery for the unit. Simple as that
Jan 05, 2008 | Compaq iPAQ H3850 Pocket PC
HP iPAQ doesn't turn on
Failed battery pack most likely.
Jul 11, 2017 | HP iPAQ hw6510 Smartphone
IPAQ 3700 series
Most iPaqs use a small AC Adapter This model will still need an AC Adapter, because it does not draw any current from USB to charge.
Oct 11, 2006 | Compaq iPAQ H3630 Pocket PC
HP iPAQ RX3700 Pocket PC Logo
127 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
