Question about Hotpoint TDC32 Electric Dryer
Hotpoint dryer my dryer is making holes in my clothes as if it is getting caught in something and also scortching marks around the tears.
  • 833 Answers
Could be your thermostat has frozen on.
Posted on Nov 15, 2008
My whirlpool duet electric dryer makes scortch marks on my light colored clothing. I've tried cleaning every part I can think of in the dryer drum but it still does it. What could be causing
Look for exposed metal on your drum. It should be coated with a protective surface. If part of that surface has gotten chipped then that is the cause. I believe there are repair kits for such problems that use an epoxy/teflon mix that you apply to damaged areas in the dryer
Dec 17, 2014 | Whirlpool Dryers
When I take my clothes out of the dryer some of them have blackish marks on them please help thanks
Make sure the drum is properly seated. If the drum sags, clothes can get caught in the gap on the bottom, then pinched when the gap closes on the top. This can cause grease stains on the clothes, or worse, can tear them.
If the drum sags, check the drive belt and drum support rollers.
Sep 13, 2013 | Whirlpool AWZ7303 Electric Dryer
Hotpoint cycle large capacity dryer
What kind of brand and model do you have?
I would probably recommend replacing the entire piece, it will be hard to find something that will be a perfect fit. If there is not a tight fit it's likely something will still get caught.
Feb 09, 2018 | Dryers
Kenmore dryer model 110 drum loose
Sounds like drum rollers are worn and rear drum seal is also worn and need replacing.
Nov 14, 2017 | Kenmore Dryers
Articles of cothing get caught between the rotating drum and the frame--I'm sure these are not the correct structural terms. Too often, when I open the door, something will be caught and hanging, and I...
Your drum seal between the drum and the body of the dryer needs replacement, this is what causes the clothes to stick and tear holes in them.
I hope this helps
Please rate me
Aug 10, 2010 | Frigidaire Electric Dryer
My crosley dryer is making a terrible scraping noise. I lifted the top of the cover off and could see the drum. There are several scrape marks in a few spots. Obviously it is rubbing on the bottom. What is...
The first thing to check is whether there is something caught in the drum rim (both front and back). Feel around the circumference of the drum in both places for a piece of clothing or pocket item jammed in there. If all is clear, then most dryers have drum glides on the front that will wear. Those aren't expensive and not that hard to replace for the mechanically inclined. A bad rear support roller is also a possibility. To replace it , the drum will probably have to be removed. Drums aren't that hard to get in and out, depending again on your mechanical ability. Hope that helps
Jan 02, 2010 | Crosley Dryers
Black marks gets on clothes as if they're getting caught in something.
Our Hotpoint DLL2650 has the same symptom. A bearing has been squeaking for over a year. Now one of the drum rollers makes a grinding sound against the drum. I suspect the drum roller has come apart.
Dec 05, 2009 | GE Dryers
Dryer makes small holes (cigarette burn size) on clothes
Get a new dryer. Old ones tend to tear-up clothes and burn holes.
Apr 29, 2009 | Dryers
You need to check the drum where it fits into the front door/front housing. If the housing is worn close will get caught and tear.
Jul 21, 2008 | Hotpoint NVL333EY Electric Dryer
Hotpoint TDC32 Electric Dryer Logo
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
