Question about Speed Queen AWS52NW Top Load Washer
28+ year old- Speed Queen Heavy Duty top loader
I works fine on small & medium loads. When you set it to large or extra large loads it works fine through the wash cycle. But when it starts to fill for the rinse cycle it usually but not always lets the water keep running and draining out the exhaust hose. I have to then turn it to spin, let it go through the spin cycle, then turn it back to the rinse cycle and hope the valve shut so the "Lifetime Stainless Steel" drum fills up.
    Novelist:
  • 177 Answers
It sound like you drain hose is siphoning off the rinse water, It needs a standpipe make sure the drain hose is at about the height of the top of the washer, Make sure the drain hose isnt stuck in the drain it also needs an air cap. the drain hose should not lay on the floor to run to the drain
Please let me know if this doesnt solve your problems
Posted on Oct 04, 2008
Speed queen top loader hops and bounces around when in spin mode
Most likely it's out of balance.look in to that .even out your loads
Jan 04, 2017 | Speed Queen Washing Machines
Kleensmaid heavy duty washer by speed queen, washes but shuts down on what seems to be overspeed on the spin cycle
Amazon.com: Customer Reviews: Speed Queen 3.3 Cu. Ft ...
www.amazon.com/Speed-Queen...Washer/.../B004ZO...
Amazon.com, Inc.Find helpful customer reviews and review ratings for Speed Queen 3.3 Cu. ... If you need more water in the tub you can hold down the reset switch until the machine ... I tried the delicate wash and spin cycle, but the clothes retain too much water and ..... It takes time to correlate the number of turns and the direction to turn it.Missing: overspeed
Commercial Washer and Dryer Problems
www.affordablelaundry.com/commercial-washer-and-dryer-problems
The water should shut off once it reaches wash level, if it doesn't, and water level hasn't... (these are the glass type fuses) be sure to turn power off before checking them. ... If you have the voltage in, but not out, it's the contactor. .... We repair: Speed Queenwasher, IPSO washer, Milnor washer, UniMac washing machines.Missing: overspeed
[PDF]View document in PDF
Dec 19, 2015 | Speed Queen Washing Machines
Does the top loader heavy duty machine have a filter and does it need to be cleaned regularly. If so, where is it located?
No filter to be cleaned in the machine. There are however small wire mesh filters in the screw on connectors that connects the water hoses to the machine at either the tap side or where it are connected to the machine inlets. Unscrew the hoses from the tap and machine inlets and check both hose ends if the wire filters are not to clog up over time resulting in slow water filling of the machine. Remove carefully and clean with a nylon brush. Replace again.
Aug 01, 2014 | Speed Queen 3.3 Cu.Ft. Heavy Duty Top Load...
Vibration
With the age of the machine, although Speed Queen's are built like a tank, the suspension systems are one of the most worked systems on a clothes washer,so, that being said, I would check all related parts of the suspension system, springs,pivot,etc,.these parts do get tired, think of the amount of loads of clothes that you have run through the washer over those 15 years.
Good Luck !
Feb 14, 2010 | Washing Machines
Speed Queen top loader leaks from top of tub at large load spin c
make sure unit is level possibly lower front legs down so front sits higher,,, and also when u put or load in push the tub back so when the water enters it all enters into the tub sometimes the water will splash on the tube and cause a problem u are discribing hope this help
Feb 03, 2010 | Speed Queen ATS90AWN Front Load Washer
Jammed agitator
Some further checking indicated a bad transmission. As the unit is 15 years old, I decided the best solution was a new machine! ..
Dec 03, 2008 | Washing Machines
I have a 4 year old Calypso Sears washer. With medium to large loads, and heavy loads, such as towels and blankets, it will wash the clothes, but stops and shows a code of CA or Cl when it goes to do the...
If you want a work horse, find your local Speed Queen dealer and buy a Top loading washer, Look for a model like an AWS76NW or AWS52NW. Basic Top loader, work horse.
Let me know if you have questions.
Aug 21, 2008 | Washing Machines
Speed Queen AWS52NW Top Load Washer Logo
598 people viewed this question
Top Speed Queen Washing Machines Experts
Terry Schneider
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
