Question about ASUS P5VD2-MX SE Motherboard
No sound when plugging headphone
Hi, i need help regarding my headphone, when i turn on my computer, i hear windows opening & shutting down Xp sounds, but when i play music, no sound; but when i plug my speakers, it works well., also, when cheking on the realtek audio manager, headphones are functioning well...help me please?
  • 797 Answers
Go to the control panel and then open system.
In there you should see your hardware. Make sure it is all set correctly.
Also check the speaker on the taskbar. Open the sound and make sure that all are checked or (not checked) on to make the sound work ... wave, midi, and so on for what you are playing . Some will turn on when checked, some will turn off when checked...try these settings.
Make sure your music player is set correctly. Go to the properties in the program.
Posted on Sep 02, 2008
Sound will not play through headphones
Try here:http://www.computing.net/answers/windows- xp/headphones-amp-speakers-switching/55486.html Also:http://www.vistaheads.com/forums/microsoft-public-windows-vista-music-pictures-video/133605-sound-doesnt-switch-automatically-headphones-when-plugged.html Also:http://www.vistax64.com/sound-audio/198039-sound-doesnt-switch-speakers-headphones.html scroll down the page for the discussion.
Oct 18, 2009 | Philips (33-01-031) Headphones
Microphone connection
you just look whether you missed out any connection while shifting ........
Aug 23, 2008 | Edirol UA-4FX External Sound System
Windows will not turn computer off. I have unpluged every thing and all fans but the hard drive. I get 0.01 dcv when the computer is running and the same when I try to have windows turn the computer off....
This usually happens if Windows is having trouble closing a program. The easiest way to avoid the problem is to close all programs before you close Windows.
If that does not help, you need to track down which program is causing the problem.
If you are running Windows 95, remove all shortcuts from your StartUp folder.
If you are working with 98/ME/XP, uncheck all the programs listed in StartUp in the System Configuration Utility (you get to the utility by opening Start/Run and typing "msconfig" without the quotes in the Run box and then clicking on OK).
Shut down the PC. Reboot. Shut down again.
Then add one program back, shut down, reboot and shut down again.
If Windows shuts down as it should, add a program back to StartUp and repeat the shutdown, reboot, shutdown routine. Do that until you have pinpointed the errant program and reinstall it. If you are running a screen saver, consider it also to be a prime suspect.
Your Advanced Power Management, or APM, utility has decided to take leave of its senses.
Disable it, both in your BIOS file and in Windows.
That little sound riff that accompanies the shutdown is hitting a sour note.
Go to Control Panel and click on the Sounds icon to open the Property dialog box.
Scroll down in the Events box until you see Exit Windows. Change the sound settings to None.
Your TEMP folders are bulging at the seams.
If the C:\Windows\TEMP folder gets overloaded, all sorts of bizarre events can ensue. Clean it out. While you are at it, clean out your Temporary Internet Files folder as well.
Updating XP with the latest Service Pack may also cure the shutdown failure.
However, it is also possible that Advanced Power Management, or APM, is getting in the way of the shutdown routine.
APM may not be enabled in your XP configurations, but it may be turned on in your BIOS, a memory-resident program that controls how your PC sets itself up.
Microsoft recommends that you go to the Control Panel, click on “Performance and Maintenance,” and choose Power Options.
Click on the APM tab and click on Enable Advanced Power Management Support.
Personally, I don’t like automatic power management on desktops because it can cause all sorts of bizarre behavior. I would leave Advanced Power Management disabled in Windows and turn it off in the BIOS.
Consult your PCs manual to determine how to enter BIOS’ Setup file. Sometimes, as the PC boots, you can see a message on the screen that tells you which key to press to enter Setup. Press it before the screen welcoming you to Windows appears.
Once in Setup, look through the various sections until you find the option for controlling power management. Choose to turn it off.
For guidance on other XP shutdown problems, consult article 308029 in the Microsoft Knowledge Base. Use the article number as a search term at the support site below. Good information is also available at the aumha.org site.
Regards.
Aug 27, 2009 | Computers & Internet
Cant get sound through my headphones when i plug it in my computer
You need to check the headphone jack on the case before you try to use it again. It may have a wiring problem, Shutting down the computer is a serious problem and could do a lot of damaged to windows program and you computer.The way to reset the case headphone jack is to go int the control panel and search for the sound control device. go to the advanced options and put in the type of device you want the sound to come from. There is also the possibility that the headphone jack was damaged when you had your problem and will no longer function correctly. Hope this helps you with your problem.
May 17, 2009 | Microsoft Windows Vista Ultimate Edition
A8N SLI Deluxe Sound device/driver not working.
Have you tried using microsoft system restore to roll back your computer to when your friend did the dirty deed? To use it, go to start> all programs> accessories> system tools> system restore. If it hasn't been too long since you got it back, you might be able to recover your system very easily using system restore, but do it right now, because the longer you wait, the more likely it is that the repair record has disappeared.
Mar 26, 2009 | ASUS A8N-SLI Deluxe Motherboard
Compaq-presario-cq60-104tu-has audio problem
Plug in the speakers Jack,
then restart computer with headphones plugged inside.You will still hear windows startup sound.
At this point remove headphones and restart.
The problem is usually fixed in this way.
Dec 19, 2008 | Compaq Presario Notebook
Mbox problem (no input,output)
i'm running os 10.5.6 w/ protools 8.0 and the original mbox. i had the same problem. protools opened and seemed to work except there was no sound from either analog outputs or headphones. this worked for me:
1. shut down computer
2. unplugged all usb cables except keyboard/mouse
3. restarted computer
4. re-plugged usb cable from computer to mbox
5. opened protools session
6. hit play and now i'm hearing sound and everything seems normal.
i hope this helps everyone else
Oct 03, 2008 | Digidesign Mbox External Sound System
Regarding the system volume
@deepu85
plz check whether ur volume is set to zero or mute..
secondly be sure that u have the audio drivers installed...
please provide the above details for future advices..
SUDE
Jul 29, 2008 | Acer Aspire 3004WLCi Notebook
Cannot control sound when booting...
Sohanad, look in control panel under sounds. There a setting in there that you might have to check/uncheck, inorder not to hear sound when headphone are used.
Apr 28, 2008 | Compaq Audio card Sound Card
Aspire 3680-2574 Headphone jack
right click my computer--> properties-->hardware-->device manager-->sound devices-->find realtek hd audio-->right click-->disable-->OK
wait at least 3 min
repeat and enable
Oct 09, 2007 | Computers & Internet
ASUS P5VD2-MX SE Motherboard Logo
80 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
