Am unable to get tape in VCR/combo - Televison & Video
  • gene5531 Sep 07, 2008
    Have a Sylvania VCR/TV combo. Recently have been unable to load video tape.
  • gene5531 Sep 10, 2008
    Have a VCR/TV combo - Sylvania, Model #6313CE. Am unable to get video tape to load. None of your answers have worked.
  • 185 Answers
Sir,
If you unplugged it with a tape inside that procedure has probably messed up the internal cpu or integrated circuit that controls the functions of the set.
So, it must be reset and restored to its factory settings. To do this merely unplug the power cord and leave it unplugged for at least 4 hours. It takes this long to totally discharge all the memory cells inside the unit. Then power it up again and check it out.
After the reset above if it still does not eject the tape there may be a mechanical problem. For this there are all sorts of things you can try. I refer you to www.fixer.com which has a database of things you can do to get a stuck tape out and get the tape mechanism working again.
From this site, for example, you will find a section on Sylvania vcrs that has suggestions on removing a tape. You can find it at:
http://www.fixer.com/dbase/syl/vc4360at01p5.shtml#TAR4
Thank You
Posted on Sep 07, 2008
  • Abdur Rahim S
    Abdur Rahim S Sep 07, 2008
    sir,
    http://www.fixer.com/dbase/syl/vc4360at0...
    Thank You
    Genius:
  • 1,239 Answers
Hi sir actually it happens to all cassets if not stuck also it have some problem like vcr mechanism so repair it
Posted on Sep 10, 2008
  • 3,037 Answers
If it isn't loading then either the sensor is broken or the motor to accept it is broken. You will need to remove the outer panel and diagnose the problem more fully inside to find the exact cause of your problem
  • 10,594 Answers
It seems some thing wrong with VCR mechanism. Some thing is obstructing cassette to load-in properly. Off the top cover and see some foreign object inside as kids normally slide small toys in mechanism. If nothing, check loading belts. Still every thing clear and problem exist, take it to nearest repair shop for proper repair.
Regards,
  • Shahid Electronics
    Shahid Electronics Sep 10, 2008
    let me try again as your unit isn't in front of me. please let me know, does loading motor in vcr mechanism starts when you inserted cassette?
  • 1,879 Answers
Like what's happening ? Able to put the cassette in and the video is not showing up ?
Happens to all cassettes ?
Tried switching source from the remote or front panel ?
    Master:
  • 521 Answers
Are you connecting the wires properly in proper sockets.
Posted on Aug 31, 2008
  • tech expert12 Aug 31, 2008
    this problem always leads beacuase of improper connections.or some where loose.please check.
    thanks.
    please do rate the solution,
    regards,
    fixya team.
VHS tape not working in Samsung TV/VHS Combo and unable to get the tape out
Must take VCR out to remove tape gently.Cause of problem is usually a dirty mode switch.
Feb 26, 2015 | Samsung CXJ1352 13 in. TV/VCR Combo
How to record on vcr/dvd combo I set the timer program to record on the vcr but nothing happen, I can record by hitting the record button, but unable to get the timer to work. I received the vcr/dvd combo...
First make sure the internal clock is setup correctly observing am/pm. Then try recording something so you can watch the operation to see if it works. Make sure you have a tape you can record on and also make sure the write protect tab has not been removed from the front lower corner of the tape. Good Luck! I hope you now have success!
Nov 11, 2009 | Toshiba Televison & Video
Trys to eject movie, fails, then shuts off...
the tv must unscrew the cover turn the power felds around for vcr cage for sensor the tape will pop out.push the eject button doing this.
Aug 13, 2009 | Funai F3819D Combo
Symphonic tv vcr combo will not eject tape
You need a new VCR belt it located on right side of the vcr tray take your finger and start rotate the belt clockwise, it should release the tape. or the motor is going bad.
Apr 25, 2009 | Symphonic SC319C 19 in. TV/VCR Combo
Copying VHS tape to DVD
Hi.
I'm sorry, but according to zenith xbv323 VCR/DVD combo user's manual page 24 you can ONLY copy DVD to VCR and not the other way
Feb 26, 2009 | Philips Magnavox DVD/VCR Dual Player
Want to play a tape on my magnavox vcr GDV228MG9. what mode should the TV (SANYO DS27510)be set on? Should it be the video mode 1 or 2 or what? I have tried both and can not get vcr to play. altho I did...
The most common problem is people tend to not use the correct output on the back of the combo unit, make sure that you are connected to the DVD/VCR output on the back of your combo unit, not to DVD only. If you are plugged into the back of the TV, use mode AV 2, on the front use AV1.
Dec 24, 2017 | Televison & Video
Tape stuck in vcr
Carriage has been set out of alignment due to improper extraction- need to repair or replace the carriage loader...accordianman
Jul 10, 2008 | Symphonic SC319C 19 in. TV/VCR Combo
Sylvania SRD4900 DVD/VCR combo problem
Hi I am Temperance MI and I see this mode in my shop often, does any onscreen menu come up when using the remote and
going into menu? If not maybe the remote is bad, common just
a loose battery lead, If you are able to go into menu, and set the
clock, but unable to set timer record, look closely at you recordable tape to make sure on the left bottom from corner the
the recording tab is in place, You can place scotch tape over this hole of existing tab to ensure it will go into record. Finally
if it wont go into record when you try to use OTR, you
make a problem with the record ready switch in the VCR section. Joe . East Electronics, Temperance MI
Jan 23, 2008 | Durabrand DUR7 Portable DVD Player
VCR plays for a few seconds and rewinds. Now, the VCR plays tape in fast forward mode
Most everyone I know had problems with the tv/vcr combo including myself. I'll never buy one again. I'm sorry you are having the same problem.
Aug 28, 2006 | Quasar VV-2002 20 in. TV/VCR Combo
Open Questions:
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
