The inside unit systen is on, but the outside unit fan won't turn on
  • 639 Answers
Friend,
ngfam1 At your service!
Sounds like first you must know if you are low on freon!!
How old is the unit?
If the central air is 20 years old or more you may not be advisable to put good money into bad!
I did replace my ac unit after 7 years of my wife bugging me that we are loosing money! On our electric bill!
SHE WAS RIGHT ! I GOT A NEW GAS FURNACE 93 AFU AND A NEW AC UNIT OUTSIDE 13 SEER AND GUESS WHAT?? MY BILL GAS AND ELECTRIC BILL IS COMBINED AND IT WENT DOWN $12OO. A YEAR!!
WELL HOW MANY THOUSANDS OF DOLLARS DID I WASTE IN 6 YEARS? OVER 7 THOUSAND DOLLARS..HMMM THAT WOULD HAVE BOUGHT ME THE UNITS!!!!!!!!!
SHE WAS RIGHT ! AND SHE KNOWS THAT!
Below I referred you to a great service nation wide!
If none of these tasks remedy the heat problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF nces are so much more efficient today that they can save you a lot of money in energy!!!!
You need a hands on tech for this repair!
A&E Factory Service
1(800) 905-9505
You will be fine
Bless You ngafm1
Posted on Aug 31, 2008
  • Neil
    Neil Sep 02, 2008
    Friend,
    I came to your service on fixya.com some days ago!
    And gave you some good advice!
    But, I did not receive a rating from you yet!
    Can you please give me a rating at our fixya.com site!
    Bless, You ngafm1
Why tempstar 5000 High Efficiency a/c outside fan won't turn off ?
Sounds like your contactor is sticking in your outside unit. They could be welded shut.
Jul 21, 2014 | Heating & Cooling
I HAVE A CARRIER CENTRAL AIR, THE OUTSIDE FAN IS BLOWING INWARD AND WON'T SHUT OFF WHEN THE FURNACE SHUTS OFF AFTER TEMP IS REACHED
Check the t-stat to make sure that the "fan" switch is st to auto. If not the fan is in the "on" position and is always on. Otherwise, It sounds like your "Central Air" is a packaged unit(Furnace and air all one unit outside the home) and the fan relay inside the unit is stuck. This need to be replaced. It is the rectangular unit with the leads from the fan motor attached to it.
Jul 29, 2011 | Heating & Cooling
The central air turns on, but does not cool. The fan outside of the house is not moving. Is there a switch I need to use to turn the outside fan on?
There should be an electrical box next to your exterior unit. Open it up and there should be a pull handle on an electrical bridge. Usually when it is turned one way it will make an electrical connection and if it is rotated 180 degrees and plugged in it won't make an electrical connection.
Jun 04, 2011 | Heating & Cooling
I have a goodman cpk j42 -1b ac unit on the outside and a central heat and air unit inside. the ac unit come on and runs fine but when it hit the temp the thermastat clicks and the fan outside goes of but...
Hello BWOOD Check the thermostat FAN button is in AUTO position not ON position.That might be it .The relay is in the blower unit but they RARELY become frozen/welded stuck on.
Aug 30, 2010 | Heating & Cooling
AC compressor wiil not turn on
You will have to find the contactor which is located in the outside unit. And check the voltage at the contactor, 26 v as this is the thermostat calling for the compressor to come on. You can also push in the contactor and see if the fan and compressor start. There should be an outside fuse box close to your condensing unit. Good luck
Jul 23, 2010 | Samsung AW1203B Air Conditioner
Can i run the fan on my inside unit if the outside unit is not working
You should be able to run the fan on the inside unit if the outside one isn't working. If you're worried, turn off the circuit breaker for the outside unit. If you don't know why the outside unit isn't working, check the circuit breaker at the breaker panel, check the breaker inside the box that electrically connects to the outside unit, and check the outside unit for a reset button.
Oct 15, 2009 | Heating & Cooling
Outside unit kicks on but inside fan sometime works and sometimes won't and i have replaced thermostat to get to work i have to turn the fan to on and back to auto several times and finally the fan inside...
Goodman air handlers (inside unit) fan have a delay timer that turn on the fan ,sometimes up to 3 minutes after the outside unit is on,this makes the a/c more efficiency.
Sep 19, 2009 | Goodman CKL36AR36 Air Conditioner
Outside unit come on for ac but inside won't come on for ac or heat
Turn Tsat to fan to see if inside unit will come on. If it does Tstat needs replaced. If not it is fan motor or fan relay. Possible cap. Do you here the fan relay come in. If it is a Good man unit it is time delay and you wont here it. Need to know your make of unit. Rusty
Apr 25, 2009 | Heating & Cooling
A/C quit running
This question is really to broad to answer. There are several things that could cause it to stop running. I think I would turn everything off, let it cool down for several hours and try it again. When you kick it back on, take note of what is running and what's not running. Inside fan, outside fan, compressor. If the outside unit will not run at all it could be as simple as a grasshopper caught in the contacts. If you hear the compressor running outside but no outside fan, The fan motor probably needs replaced. Please make sure that all power to the unit is TURNED OFF before removing cover plates on outside unit and before trying to remove insects from contact points. Check all wiring inside outside unit while it is open. Also check capacitors for swelling or leaking. If you don't know how to turn all the power off or open the outside unit, you need to call a professional AC technician. Hope this helps. kstfas
Aug 26, 2007 | Ruud UAKA037 Air Conditioner
Heating & Cooling Logo
144 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
