Question about RCA HD52W59 HDTV Projection Television
FL231 RCA HD52W59
I jumped FL231 and the picture is great. When I hook it up to the satallite, all I get is snow. Is it possible I forgot to connect something, which I doubt, or what? I already changed from air to cable, duh, and think I checked everything else. Am I missing something or did I create another problem?
  • RCA Master
  • 8,617 Answers
You dont want to leave that fuse jumped, as it blows when there is a problem with the convergence power supply, and if the power supplt surges again with that fuse jumped you will destroy the convergence power supply and the deflection board and the cost would be in excess of 500 for those two boards.
Posted on Sep 04, 2008
WERE CAN I BUY AND HOW MUCH IS A FL231 FUSE FOR RCA HD52W59
If you replace just the fl231 it will blow again. You will need to replace the FL231,DL231 and CP230. You can get the parts at the following link with free instructions with pictures total cost is about 26.00. Its listed under the RCA repair kits as the ITC222 & ITC222A convergence option missing repair kit. Its available at www.tvrepairworld.com
Dec 29, 2011 | RCA HD52W59 HDTV Projection Television
Rca hd52w59 3d screen colors are seroperated no convergence
If you replace just the fl231 it will blow again. You will need to replace the FL231,DL231 and CP230. You can get the parts at the following link with free instructions with pictures total cost is about 12.00 shipping is free. the parts are all listed under the RCA parts category.
http://servicemanuals.vstore.ca/
May 28, 2009 | RCA HD52W59 HDTV Projection Television
I have an RCA hd52w59. I just replaced fl231,
find your 'service' page, usually you have to hold the input button and the power button together for a couple sec. a new menu should appear Look for the factory restore choice and choose it.
Apr 22, 2009 | RCA HD52W59 HDTV Projection Television
Picture is blurred and bowed
ok you have a convergence problem. first check out the article the fl231 problem in the tips and tricks section it will tell you of a condition that might mean an easy repair. first check to see if you have the convergence options in the customer setup menu
Mar 15, 2009 | RCA HD52W59 HDTV Projection Television
i have found the reason for the fl231 fuse blowing is faulty solder connections on the flyback transformer is the main cause. I have came across only one bad signal board that cause this but this was very very rare 1 in 1000. This is a very specific fuse, .400 and it is recomended only to replace with exacte one. consult the fl231 problem in the tips and tricks section.
Jan 02, 2009 | RCA HD52W59 HDTV Projection Television
Destorted picture on my tv
the fl231 problem requires a soldering iron. to remove it from the circit board. I would not recomend this for someone who has never soldered before. and consult the fl231 problem under the tips and tricks section
Dec 26, 2008 | RCA HD52W59 HDTV Projection Television
Hd52w59 convergence fuse
you jumperd the fl231 fuse? did you resolder the flyback connections. if these are not resolder the oscillation can still cause probklems
Nov 27, 2008 | RCA HD52W59 HDTV Projection Television
HD52W59 HDTV
Sounds like the fl231. First question? In the setup menu do you have convergence option? if not this is an indication of the special fuse called fl231
Sep 16, 2008 | RCA HD52W59 HDTV Projection Television
Rca hd52w59 convergence problem
there is a special fuse on the power deflection board. when blown this causes the processor to think it a crt tv. The fuse calle fl231 is a small brown rectangular fuse in the middle of 3 just like it next to the flyback transformer the big black thing with the large red wire comeing out. ussally it blows because the solder connections on the flyback. WARNING high voltages are generated by flyback. be careful please
Dec 27, 2007 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 HDTV Projection Television Logo
85 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
