Question about GoVideo DV1030 DVD Player/VCR
Remote codes wont work. need the right one
I have tried the four codes that came with this universal remote, but none work. I need the right one. Please help.
    Scholar:
  • 47 Answers
Hi!
First, without knowing what universal remote control you have, I can't really provide you with a list of remote codes that might work. A brand and model number (usually found on the remote), would be helpful.
Short of that, there is a likely solution. If you refer back to the users manual for your remote, there will be a "scroll" feature that allows you to enter the codes, one by one, and see which one works. Most remotes have numbers that start with 001 and go up through 300 or 400, so it can be a little tedious, but it should work. It procedure is a little different, but basically you get into the setup or learn section of the remote, enter the code, the press the power button and see if it powers up your device. If it does, then your done! On average, I'd say this process takes 10 minutes or so.
Please let me know if this helps. If you deem it appropriate, a rating would be appreciated. And I'll be glad to help more if you have the info above. Good luck!
Bob
Posted on Oct 14, 2008
Lost remote for zenith H27F56S,so I bought rca universal remote, and have all the codes but still wont work to set up channels.I have followed the set up process to the "T" yet it still will not...
Sometimes the setup procedure might be not right. Check it with an other code. If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts. Setup code list and setup instructions to some popular model remote controls are given. Zenith TVs should synchronize with codes to RCA. Check the number of digit codes, that the TV asks. If it is a three digit one, and you are entering a four digit code, the TV won't synchronize.
Mar 08, 2013 | Televison & Video
Universal remote codes
Hello
If your Technica TV asks for a four digit universal code; buy onw RCA RCR311B model remote control. The codes for Technica with this remote control are:
1004, 1006, 1009, 1010, 1013, 1025, 1035, 1045, 1051, 1060, 1061, 1075, 1078, 1103, 1122, 1123, 1205
If it asks for a five digit code, buy RCA RCR 312W model remote control
Codes for Technica with this remote control are:
10054, 10180, 10150, 10060, 10092, 10016, 10056
Otherwise, give me the Brand Name and Model Number of the remote control you have with you now, and let me search whether there is any code for Technica TV, with this remote control. OK.
Jan 04, 2012 | Televison & Video
Universal codes sylvania need tv
Universal codes are in ur tv univeral remote manual already.None of those codes work for ur tv brand.None of the codes people give u will work either.Return the universal remote where u bought it.Try website like Remotes.com to buy the tv original remote.
Jun 11, 2011 | Sylvania LC370SS8 Television
What code will work with a universal remote for the LD 195 SL8? I have tried four various universal remotes and none have worked.
I can t give you any specific codes as they will be different for each remote. However, if you have tried all the codes for Sylvania, then also try codes for the following brands. All of the brands in this list are made by Funai who also manufacture the Sylvania LD195SL8:
Funai
Emerson
Durabrand
Symphonic
Superscan
Try codes for the above brands and also try the code search features on your universal remotes. You will find details of these in the user manuals. If neither the codes for Sylvania or the above brands or the code search feature work, then it's unlikely that the remotes will work with the TV. Universal remotes often fail to work with Sylvania machines for no apparent reason.
Regards
BElectric
Dec 04, 2010 | Sylvania LC-195SL8 19 in. LCD TV
I NEED TO PROGRAM A MAGNAVOX TV WITH A PHILLIPS UNIVERSAL REMOTE CONTROLL
Find codes and methods here.
http://www.docstoc.com/docs/23925020/Programming-Remote-Control-Brand-Codes-TV-Sets
If those codes dont work try the last three(or four) numbers of your TV's serial number.
On my universal remote is just a matter of holding down the TV button till the light stays on, then punching in the three digit TV code. When the TV turns off it's the right code. But read your manual for your controller.
Oct 08, 2010 | Universal Remote Control Universal IR...
Who makes Broksonic tv ?
can you plese visit this website http://www.broksonic.com/
there the manufacture. you may want to call them for the current codes not all codes are garanteed to work thanks.
Apr 23, 2009 | Broksonic CTGV-5463TCT TV
Help with dvd player DRC282 remote code
I purchased this same DVD player (DRC282) and none of my universal remotes worked for it. Since I was lucky enough to buy one without a remote, I ended up purchasing an RCA universal remote (RCR3273). Once again, none of the codes worked so I had to unplug the unit for 5 minutes, then plug it back in and hold the Standby button for 15 seconds to return it to it's factory settings. I manually searched through 71 codes before I found a match but the play, pause, rewind and many other functions failed. I tried again skipping over 71 and found the right code at 115 tries. That one had all the functionality I needed. You should try the same strategy with your Comcast universal remote. Skip the first match and keep going until you hit the second manual match.
Apr 09, 2008 | Televison & Video
Vizio and the directv dvr
Vizio recommends using code 11758 or 10178 for Cable/Satellite universal remotes that use five digits such as DirecTV. For four digit Cable/Satellite universal remotes , use 1758 or 0178. For three digit Cable/Satellite universal remotes, such as Dish or Echostar, use 627. These codes typically make the Power, Volume and Mute functions work.
Jan 13, 2008 | Televison & Video
Need code for sanyo tv
Welcome to FixYa.
SANYO TV Codes: 0154, 0159
Please be informed that the codes vary with different make and model of the universal remote that you have. If none of the codes above work, please post back with make and model of your universal remote included.
Thank you for using FixYa.
Jas247
Sep 01, 2007 | Sanyo DS31590 31" TV
GoVideo DV1030 DVD Player/VCR Logo
163 people viewed this question
Top GoVideo Televison & Video Experts
Demonic-2011
Demonic-2011
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
