Question about RCA HD52W58 52" TV
Double print and curve screen
My tv now has double print and curved screen
Where will I find the fl231 fuse?
Posted on Dec 12, 2008
    Genius:
  • 1,030 Answers
This is an indication of convergence problem. from your description the curved screen indicates complete loss of covergence. First question is in setup menu do you have the convergence option? if no then it will be the fl231 fuse problem. common to these set and if you can solder. its not a difficult repair. if you do have the option. then it can be any or all of three cuircit boards. let me know and i will do my best to see if i can help you fix it
Posted on Sep 20, 2008
Any , experienced the curved TV. Now a day wide screen TVs come. With flat model and curved model. I suppose if you beyond 40" TV you should go for a curved one .
It really depends on how far away from the television you are? In a larger room a flat screen is fine. In a smaller room a curved is better. Remember though, with a curved screen the optimal seating place is dead centre, so it you have multiple seats in the viewing plane, only the one in the centre gets the best view.
I have a 50" flat screen in my small basement and its fine. At work we have a, 86" Ultra HD 4K Samsung with a flat screen. We also have 54" curved screen televisions in an area to just 6 seats.
Oct 28, 2017 | Televison & Video
Jvc tv has double exposure and curve
Convergence is most likely for this model------that circuit in this set is right at front behind grill below the screen.
If you can solder it is a do it yourself type repair with parts under 30 dollars (most shops get 250 average parts and labor) and I can tell you how to get that board out and what is needed.
Here is the board removed from a set.
Oct 31, 2012 | JVC AV-56WP74 56" Rear Projection...
SONY PROJECTION TV MODEL # KP-51WS510.
If the entire screen is curved, and it is not taking the whole screen, then you have a vertical deflection problem.
If the colors are double and do not match, with lines of different colors around pictures , then you have a convergence problem, often caused by a faulty convergence board.
The curving effect can be a side effect of bad convergence, or you may have both problems at once.
Unless you are a TV repairer yourself, better calling technical support. Usually you can ring the number listed on the owner manual.
Jul 21, 2009 | RCA P52920BL 52" Rear Projection...
Colors have seperated on tv, and curve
You have a convergence problem.
Maybe need change the IC of convergence, or the power supply of these parts.
Bye.
Apr 04, 2009 | Mitsubishi VS-50501 50" Rear Projection...
Panasonic PT-53WX54 curved bottom
its the problem of convergence in the unit that needs to be repaired
for how to repair please click the above link
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Oct 06, 2008 | Panasonic PT-53WX54 53" Rear Projection...
Curved screen and double letters
i see this alot and rca shold issue a bulliteen. so i wrote advice on this. see fl231 problem under tips and tricks under my profile. this is a simple easy inexpensive repair. if this dont help let me know.
Sep 19, 2008 | RCA HD52W59 HDTV Projection Television
The convergence circuit has a problem. Can you confirm the model number as HD52W58 please? I will double check the requied parts and update this.
Thanks,
Dan
Sep 03, 2008 | RCA HD52W58 52" TV
Distorted picture on RCA LCD TV
it can be replaced with a t0220 stile case dioded 220k ohm go to nte look up and do a search on the rca part #moz-screenshot.jpg 259638 search the web for the part.
Jun 29, 2008 | RCA R52WM24 52" HDTV Projection Television
Double image
convergance ic bad
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 10, 2007 | Mitsubishi VS-45609 TV
WS55711 mitsubishi RPS - Dec 2002
This sounds like your convergence correction amplifiers have malfunctioned. These Integrated Circuits often burn out after a few years (STK392-110) they can be replaced with a higher version (STK392-150) However it is important to have the biasing circuitry checked to make sure nothing has burnt out as a result of the ICs malfunctioning. If you have a background in electronics you can repair this problem with very little effort, however if you do not have a background in electronics, I would suggest that you have your TV serviced by a qualified TV technician.
I hope this helps,
Thank you,
Shuttle83
Oct 15, 2007 | Mitsubishi WS-55711 55" Rear Projection...
RCA HD52W58 52" TV Logo
61 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
