Question about HP iPAQ H5555 Pocket PC
HTTPS web sites
I am unable to access sites with HTTPS, and cannot see to security certicficates to accpet them. my ipaq 5555 seems to have factory installed IE. Is there any way to update or change settings to accomplish this?
  • 490 Answers
 IE can be updated from microsoft or manufacturers site. DeviceMosaic, Proxiweb, netfront are other browsers that supports https sites.
Posted on Oct 20, 2007
Unable to login to WAP4410N using web based administration utility after factory reset. it's reporting as invalid username or password
Please see the Reset the Default Factory Setting please read it the Detail I have a WAP4410n wireless access point, I have reset it to factory default by pressing the reset button for 30 seconds. I am able to ping its default ip 192.168.1.245 through its default ssid "ciscosb" if I configure my static ip was solved by connecting through the lan cable, and setting manually the ip to 192.168.1.0/24 network, and accessing 192.168.1.245 through web, the reason why the connecting through WiFi was working because the management web access through wireless is disabled by default
Thanks
Apr 21, 2015 | Cisco Small Business WAP4410N WirelessN...
I have a new iMac, just installed Net Nanny, and now all the user accounts that are monitored will not access secure servers. The two admin users have no problems. Does anyone know why this might happen?
NetNanny prevents monitored users from accessing secure (https) sites. If you wish to turn this off follow this excerpt from the long, winding NetNanny FAQ:
How do I stop getting blocked for HTTPS?
Login to Net Nanny and click on Web and then on Advanced and uncheck the box next to Block Secure Web Sites.
Hope that helped!
Mar 06, 2011 | Computers & Internet
I set up wireless network for my boss, using Belkin wireless n router, so the 3 computers can connect to the same wireless printer, and she can access this network with her home laptop. All is well except...
If possible, to rule out the modem as the cause, connect a computer directly to the internet(bypassing the router entirely). If it is the router, you could try flashing it back to factory defaults and reconfigure. Log into the router's firewall feature and see if port 443 is blocked to the outside--this could cause https connections to fail.
Mar 04, 2011 | Belkin F5D8236-4 Router
Internet access problem: I have a wireless router. The IPAQ internet works fine when attached to my pc. When I remove the IPAQ from the cradle, the internet no longer responds. But, the green light and...
ask on the HP forum yet, (we are not HP here)
sounds to me (seems) like weak battery
or it programmed to not use WIFI when running on wifi. on bat.
as wifi can suck such at tiny battery dry in minutes.
why not get and old CELL phone and use it and dump this old relic.
https://h30434.www3.hp.com/
Sep 28, 2017 | HP iPAQ H5455 Pocket PC
I have an HP iPAQ 6920 with a Keypad Security Lock Code. My son while playing with the phone repeatedly entered the wrong code and now it's not accepting my original code. Also there's now a 2m 08s...
Welcome to Fixya
Passwords are encrypted type. There is no special code that you need to enter to bypass the password for this unit. The only way for you to use this unit again is to do a Hard Reset. Meaning everything will be back to original factory state. If you decide to do that, then please follow the procedure below:
A clean reset clears all user-installed settings, programs, and data, and restores
your HP iPAQ to factory settings.
To perform a clean reset and return your HP iPAQ to factory settings:
1.Press and hold the Answer/Send, Power, and End Call buttons.
2.While holding these buttons, use the stylus to lightly press the Reset button on the bottom of the HP iPAQ until the device restarts.
3.When the HP iPAQ restarts, release all of the buttons, and then remove the stylus from the Reset button.
The HP iPAQ restarts and powers on.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Dec 24, 2010 | HP iPAQ hw6920
I forgot security code and how to reset it back
with the nokia phone to reset the code go to menu-settings-and in there will be a button that says reset to orginal, the factory security code is ether 0000 or 5555 mine was 5555
Sep 21, 2010 | Nokia 2630 Cell Phone (Unlocked) - Black
Help with pre-owned iPAQ h5555
I have an IPAQ 5555 and although it's old it works pretty well. A few things to be aware of - you need to upgrade the ROM to the latest version. I don't have the links to the downloads but you should be able to find them on the HP site.
The problem that you will likely run into is Windows 7 and Activesync. I did everything via Activesync on Windwos XP - hooked up to my PC and installed software, sync'd appts and contacts etc... Activesync won't install on Windows 7 due to "incompatibilities"
I just installed "Windows Mobile Device Center" for Windows 7 and was able to get my device connected to my machine but syncing is not yet working.
As for WiFi access, from what I remember it's just a matter of turning on the networking via the Ipaq Wirelss app (icon is a little green square) and then turning on WLAN. That will hopefully cause two little left and right arrows to appear up in the top blue bar on the device's screen - the top left LED should also flash green to indicate that you're connected to your network. If the LED is flashing amber then your networking is on but your not connected to anything yet. If this is the case then the icon showing will likely be two arrows with an x. Touching this icon should open a small window called "Connectivity". On this window you can click on the "Settings" link, go to the "Advanced" Tab and rthen click on the "Networks" button at the bottom of the resulting screen.
You should now see a list of available networks - make sure your router is broadcasting Wireless G and not just N or you probably won't see it. If you do see your network's SSID then touch and hold the entry and select the "Conect" 'option on the resulting menu.
Starting out I would keep your wireless security turned off just to keep it simple. If you can connect this way then you can think about securinng your network. Once secured it's basically the same proceudre but you just have to enter your WEP key.
btw if installing some of the HP service packs etc.. for 5555 doesn't work using Windows 7 and the Mobile Device Center (it may .. I haven't tried) you may try loading Windows XP Mode on your Windows 7 box and then installing Activesync in the virtual environment and working in there just to get your device upgraded
Hope this helps. Good luck
Dan
Feb 19, 2010 | HP iPAQ H5555 Pocket PC
Internet Explorer cannot display web page
a couple things I've seen
- first the address as posted is invalid (can't find) but if you insert a dot (.) between parents and brickshools then it finds it (http://parents.brickshools.org/)
- if the corrected address is correct it looks like the site is redirected to a secure connection (https vs. http) and then the problem is that the site owner's security certificate has several problems as follows:
The security certificate presented by this website was not issued by a trusted certificate authority. The security certificate presented by this website has expired or is not yet valid. The security certificate presented by this website was issued for a different website's address. these issues were presented to me by Internet Explorer v7.0 - the main address functions (http://brickschools.org/) so it definitely seems to be a security certificate issue on their end. I would speak with the site owner. btw, I'm coincidentally in Toms River :)
Apr 07, 2009 | Microsoft Windows Vista Home Premium with...
HP iPAQ 5555
after full reset I am unable to access online capabilities
May 06, 2008 | HP iPAQ H5550 Pocket PC
HP IPAQ 5555 1.10.13 ROM UPDATE
I thought my 5555 with 1.10.10 was the latest and most stable?? How come i didnt know about 1.10.13 ROM Update... Anyway, i think it is your Camera Update that causes it. But to confirm, which ROM are you using now? Go to "Start" >> Settings >> "Asset Viewer" >> Under Version >> check the ROM Revision. 1.10.10 had no major problems, only sometimes when i couldnt connect to my wireless router / bluetooth problems, but now it is okay, dun worry.
Sep 12, 2005 | HP iPAQ H5555 Pocket PC
HP iPAQ H5555 Pocket PC Logo
90 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
