I need CD, or DVD to learn how to use my Lowrance it is modle LMA-332C & LMS-337C DF.
  • 19,396 Answers
Here you can buy the DVD for $13:
Bennett Training DVD For Lowrance LMS-332C
Here is the user manual:
LMS-332C and LMS-337C DF Owners Manual
Do not forget to rate the solution appropriately.
Many thanks.
Posted on Aug 31, 2008
LMS 337c DF. The LCD backlight seems to jump from bright to off and back continually after the unit has been on for 10-15 mins. holding finger on the power/light button stabilizes the problem until the...
the lcd is going out and will cost more to fix it then the cost of the gps....my advice is to get a new one from bestbuy and get the 4 yr performance service replacement plan so next time you have a problem like this they will replace it for free.
Mar 06, 2008 | Lowrance LMS-337CDF GPS Receiver
Lowrance completely dead
my lowrance lms 337c df will not power up. I checked all the cables and poer and they are good . can you assist me
Aug 14, 2011 | Lowrance LMS-337CDF GPS Receiver
Hi,when i switch on my lms-332c the map does not come up on the screen.If I remove and replace the map card it works perfectly. Can I fix this? regards nigel
I am guessing that the card you are using is a NAVIONICS chart? There have been some Lowrance units that were made around the same time that have had problems recognizing a Navionics chart right from power up.
Make sure the LMS-332 has the latest firmware version which can be downloaded from http://www.lowrance.com/en/Products/Marine/Full-Size-SonarGPS-Chartplotter-Combos/LMS-332C/Downloads/LMS-332C-Software-Update/
If the update doesn't help, this is going to be a compatibility problem with the LMS-332 and that particular card. You will need to replace the card or upgrade to a newer unit...but probably can just get used to removing and replacing the card when you turn the unit on.
Jul 08, 2009 | Lowrance LMS 332c Mapping Sonar/GPS...
I have a lowrance LMS 332C GPS. After 5 years I
The LGC-2000 is bad would be the most likely cause, but if this started right after you changed the cables, Try connecting the NMEA 2000 network to a different power source than the main power. If you still have the original cables, and you didn't have the problem before, try using those again to make sure there isn't anything wrong with any of the new cables.
But most likely, the LGC-2000 is toast and you will want to contact Lowrance support to see about getting it repaired/replaced.
Jul 04, 2009 | Lowrance LMS-332C GPS Receiver
My Lowrance LMS-337c df keeps going crazy.
Normal 0 false false false MicrosoftInternetExplorer4 st1:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}This could be caused by glitch in the operating systemsoftware or by low voltage due to a short in the unit or somewhere in the boatswiring. To troubleshoot the problem Iwould recommend the following steps.
  1. Try a soft reset
  2. If the problem resurfaces, try a hard reset
  3. Update the the operating system software
Soft Reset (Does not delete GPSData)
1. Turn unit OFF 2. Press and holdthe PAGES key
3. Press and hold the PWR key
4. Release both buttons when the USA map
Appears
Hard Reset (Deletes stored GPS Data
such as Waypoints and trails)
1. Back up any waypoints, routes,and trails that you want to save on a blank MMC card
2. Turn unit OFF
3. Press and hold the ZIN&ZOUTKeys at
the same time
4. Pressand hold the PWR key
5. Release both buttons when the USAmap
appears
To update the operating system software, check out this link:
Lowrance337c df update
If you don't have a card reader I can program an update card for you.
Dec 15, 2008 | Lowrance LMS-337CDF GPS Receiver
Gps
I have a manual for this unit but i'm still using mine so not willing to sell it to you. I'm in Melbourne and you're welcome to borrow it for a week or so or i could probably photocopy/scan certain sections for you and email them if it helps. Let me know if you still need it by emailing me at joshklat@hotmail.com
Cheers,
Josh
May 21, 2008 | Lowrance LMS-337CDF GPS Receiver
140 people viewed this question
jasbo
jasbo
