Question about Dell A940 All-In-One InkJet Printer
Cartridge error 50c
I have the lexmark x5150. every time i try to print, scan, anything it says "cartridge error 50c". i have looked everywhere trying to fix the problem and the only thing that i have found is complaints about this model. please help!!!!!!!! Error 50C. I've unplugged the unit several times. I've checked the cartridges several times, making sure that it seats properly. Will replacing the cartridges (even though they are not empty) guarantee that it will work? Has anyone done this successfully?
    Habit-Forming:
  • 5 Answers
Have you tried the Lexmark Knowledgebase?
http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:133:0:0&framed=&docid=ENUS8448&relevance=1
It addresses this specific issue. It sounds like a shorted cartridge. However, sometimes this just means that the contacts in the cartridge carrier need to be cleaned. You can do this by removing both cartridges and cleaning the electrical contacts on the cartridges as well as the ones they touch in the cartridge carrier on the printer. You can do this with a slightly damp soft cloth. You can also use a bit of rubbing alcohol as well.
I would try cleaning the electrical contacts as I described above before I'd do anything like getting new cartridges. If the problem persists after that and after following the instructions in the link I posted above, then it might be time to get new cartridges.
Posted on Sep 11, 2008
Says erorr 50c on my lexmark x5150
The 50c error indicates a problem with your cartridge. This article will help you determine and resolve the issue: Cartridge Error 50C and Other Errors on the Lexmark X5100/X6100 Series LCD Screen.
Apr 20, 2011 | Lexmark X5150 All-In-One InkJet Printer
How do i fix Cartridge Error 50C?
The reason for this kind of error in your printer is it might be due to your shorted print cartridge .Try to power off your unit and unplug it. After few minutes again turn it on.Try to un install and then reinstall your cartridges. Or else go for a new cartridge to fix this error for sure.
Thank you !!
May 31, 2010 | Lexmark X5150 All-In-One InkJet Printer
Errir 50C
Try these solutions from Lexmark online support: (apparently one of your print cartridges has shorted)
Lexmark X5150 Error 50C
Jan 09, 2010 | Lexmark X5150 All-In-One InkJet Printer
LEXMARK X5150 CARTRIDGE ERROR
Try this --
Cartridge Error 50C
Your print cartridge has shorted.
  1. Power off your All-in-One and unplug it.
  2. Plug in your All-in-One again and turn it on.
  3. Uninstall and then reinstall your cartridges.
  4. If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
Cartridge Error
Complete the following instructions:
  1. Power off your All-in-One.
  2. Use both hands to lift up the scanner unit until the scanner support holds it open.
  3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
  4. Remove the color print cartridge.
  5. Lower the scanner unit until it is completely closed.
  6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
  7. Reinstall the color cartridge and remove the black print cartridge.
  8. Lower the scanner unit until it is completely closed.
  9. If the error message occurs again, replace the color cartridge.
  10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
  11. Lower the scanner unit until it is completely closed.
  12. If you receive the error message again, replace both cartridges
Nov 18, 2008 | Lexmark X5150 All-In-One InkJet Printer
Error code 50c
Cartridge Error 50C
  3. Uninstall and then reinstall your cartridges.If this does not resolve the issue then try the next steps.
  12. If you receive the error message again, replace both cartridges.
May 26, 2008 | Lexmark X5150 All-In-One InkJet Printer
Won't print after scanning
i have the lexmark x5150 printer that is giving me the cartridge error 50c-- what does this mean [other than i need to buy a decent model]? i hate this thang!
Feb 07, 2008 | Lexmark X5150 All-In-One InkJet Printer
Cartridge error 50c
I removed the color cartridge and left the black one. it worked.
(I have Lexmark X6100 Series)
Jan 17, 2007 | Lexmark X5150 All-In-One InkJet Printer
Dell A940 All-In-One InkJet Printer Logo
66 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
