Question about HP Jornada 565 Pocket PC
Problem I was just given a 560 someone at the office didn't want. The problem is that when turned on it lets you align the stylus, then goes to the pop up menu page and freezes. I have tried both soft and hard reset but no change. Can anyone help me? Thanks
Bogdan
  • 198 Answers
SOURCE: Finger Print Scanner
Hi again. Give me your email adress please, for me to send you the required upgrades. Read my other post in the other section you've wrotten and you will have the instructions on how to do everything there. Thanks.
Posted on Jan 23, 2007
SOURCE: rx1950 freeze on soft reset
You can do a hard reset by doing the following...
01) Press and hold down the "Calendar" and "iPAQ Wireless" buttons.
02) While holding down these buttons, use the stylus to lightly press the "Reset" button/hole on the back of the iPAQ until the screen goes blank.
03) Release the "Calendar" and "iPAQ Wireless" buttons.
04) Press the "Reset" button/hole again (so that it resets/powers on.)
Posted on Nov 18, 2007
SOURCE: HP rx3115 hard reset
nobody helps,
i think give it a big bang and buy new one!!!
Posted on Dec 19, 2007
SOURCE: doesn't turn on-tried everything-hard-soft reset
have u presses the button on the bottomon the left the reset one like a really small hole?
Posted on May 08, 2008
JackHeath
  • 1049 Answers
SOURCE: hp ipaq 3715
Hopefully you can do a warranty repair, I'm pretty sure the main board is damaged since a hard reset should have taken you back to the factory defaults.
Posted on Dec 10, 2008
SOURCE: Hp rx4540.How to access the Boot loader mode??
A factory reset erases all user-installed settings, programs, and data, and restores your HP iPAQ to factory settings.
CAUTION All user-installed settings, programs, and data are erased from memory with a factory reset.
To perform a factory reset and return your HP iPAQ to factory settings:
  1. Press and hold the OK and Rotate Screen buttons.
  2. While holding these buttons, use the stylus to lightly press the Reset button on the HP iPAQ until the device restarts.
  3. When the HP iPAQ restarts, release all of the buttons, and then remove the stylus from the Reset button.
The HP iPAQ will now restart and power on.
If you have done the above and still no go. Then your main drive has probably failed.
Link below is a repair how to video
http://www.wonderhowto.com/how-to-repair-hp-ipaq-rx4200-rx4240-rx4500-rx4540-243534/view/
Posted on Mar 11, 2010
0 characters
1 Points
Hi there, my Datalogic Skorpio keeps coming back with the stylus alignment screen. Even after clean boot. I keep aligning but no go, when I press ESC the alignment stops but the styluspen is not usable.And...
Hi Ronald - Please contact Datalogic Mobile technical support in Oregon at 800-547-5304. We can let you know what needs to be done to solve this problem.
Sarah
Datalogic Mobile
Mar 11, 2011 | Datalogic Skorpio Pocket PC
My Palm Zire M150 touch screen is badly misaligned. How do I reset the alignment?
the screen says use stylus to tap center of target ...i do that and it goes to upper left corner i tap and it goes lower right corner and back and forth between the to corners?
Mar 01, 2011 | Palm Zire Mono M150 Handheld
Plugged in charger and get alignment screen Tosh e
The unit will not go past the alignment screen until it gets a good calibration alignment. Be sure to click as close to the little + marks with the stylus as you can. If the click is to far from where it thinks it should be then the alignment will fail and start over.
I hope this helps, if not let me know
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of PC and printer support/repair
Jun 28, 2009 | Toshiba e310 Pocket PC
Tungsten e2 is always looping on the stylus calibration screen
actually ur Digitizer is faulty u can replace it urself cost around 25 $ or so do u want to proceed let me know , unless u change the touch panel digitizer u will be stuck at align screen thing
let me know if i can help more
RATE ME WELL !
Jun 02, 2009 | Palm Tungsten E2 (Multilingual) Handheld
Trying to disable welcome screen and stylus alignment
edit the DeviceConfig.exm file. Enable the section System - Welcome Screen. Change the Enable Key to Disable or 0.
Apr 09, 2009 | HHP Dolphin 9500 Pocket PC
HP iPAQ 2490B can not be hard reset
remember that you must hold down the two buttoms at the same time then push in the reset for 2 sec (holding it in). release the 2 buttoms then remove the stylus for the reset port. after about 4 sec press & release the reset buttom again, sytem will pwr up. If this doesn't resolve the issue then try the clean reset but bear in mind u will loss any thing u installed on the ipaq as system go to default setting and u will be required to align the screen. good luck
Mar 07, 2009 | HP iPAQ HX2490 Pocket PC
I have a tmobile wing the phone works fine but the touch screen does not work. i got the phone from someone and when i switch the sim cards it went to the screen that says to taap it to align the screen..i...
All you have to do is tap the screen with the stylus (slim pen that is position on the bottom right side of phone) where ever you see ( + ). Follow the plus sign ( + ) where ever it is on your screen. It should go in 5 different directions on the screen before it prompts you to the next screen. This process is mostly needed for hard reset (starting from original factory settings) or if you need to align the screen with the stylus.
Please make sure while performing the aligning task to tap the center of the (+) as possible. Not doing so may result in a poor functioning screen.
Mar 02, 2009 | T-Mobile Wing™ Smartphone
Hard reset for a HTC Touch Diamond
To perform a hard reset
1. Pull out the stylus.
2. With the device turned on, press and hold the VOLUME DOWN and
ENTER buttons, then press the RESET button with the stylus tip.
3. Release the RESET button, but continue pressing the VOLUME DOWN and ENTER buttons until you see this message on the screen:
4. Release the VOLUME DOWN and ENTER buttons, then press the
VOLUME UP button to perform the hard reset, or press any other
button to cancel the reset.
Clear Storage
You can also use Clear Storage to reset your device back to factory default settings and/or format the internal storage.
1. On the Home screen, slide to the Settings tab and then tap All
Settings.
2. On the System tab, tap Clear Storage.
3. In the drop-down menu, select whether to Clear Storage only,
Format internal storage only, or Clear storage and format internal storage.
4. Enter “1234” and then tap Yes.
Sep 14, 2008 | HTC Touch Diamond Smartphone
Align screen
settings>screen>align screen
99% solved.
Aug 26, 2008 | O2 XDA Mini S Smartphone
Palm 700P stylus problems
it sounds like it could be a warrenty issue, if you have restoreed the device and its still not working then you would need to get it repaired or replaced
Jun 11, 2008 | Palm Treo 700p Smartphone
HP Jornada 565 Pocket PC Logo
15 people viewed this question
Top HP PDAs Experts
David Payne
David Payne
ka4iup
ka4iup
Bob S
Level 1 Expert
Are you a HP PDA Expert? Answer questions, earn points and help others
