Question about Dell Inspiron 700M Notebook
Driver I didn't see one for a Microphone in the control panel
  • 51 Answers
Then you need to install the drivers.
Posted on Sep 01, 2008
Volume control
Click start control panel on the left select Hardware and Sound then select manage audio devices then recording you should see a Microphone right click select enable Windows 7
Click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a Microphone right click select configure speech recognition then
You will see earphones with a speaker among a list set up a microphone headset with Microphone then next and next again you should see your earphones with microphone being configured
Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list
Make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or
select the voice tab
Make sure that you have the right media selected also
select volume make sure the box for microphone has a tick in it
Acer laptops run on the Windows operating system.
They also have built-in speakers that have a menu to change the settings.
All laptop speakers have a driver that tells the speaker how to function.
If the driver gets damaged or deleted, the speakers are rendered unusable.
Acer speaker problems usually have a driver issue that can be solved by the user.
Go to "Start," "Control Panel," "System and Security (or System and Maintenance)," "System," then "Device Manager."
Type in the Administrator password, if you are prompted to do so.
Click on "Sound, Video and Game Controllers."
Right-click the name of your Acer speakers and select "Update Driver Software."
Click on "Search Automatically for Updated Driver Software" and allow the computer to download any updates.
Reboot your Acer laptop.
Raise Speaker Sound Levels
Click on the "speaker" icon located in the lower right corner of your desktop.
Raise the volume bar all the way up to increase the sound.
Select "Mixer" to raise the other volume bars all the way up.
Windows 7 right click on the speaker icon in the taskbar select either playback or recording devices you should see your microphone listed under the recording tab right click on it select
properties at the bottom select use this device enable
Jul 15, 2013 | Acer Aspire 3610 Notebook
Microphone Not Working!
If this is a microphone that connects to the 3.5 mm microphone jack, check that your microphone is connected to the Mic port (pink on the rear of a desktop). Make sure that the plug is fully seated. If you are using a front microphone jack on a desktop, try using the rear port (or vice versa). Next, if you have Windows, check that the audio input is set to Microphone, instead of Line In. (For Windows 7, this would be Start > Control Panel > Hardware and Sound > Manage Audio Devices (under Sound) and the recording tab.) Microphone should be your default device.
Next try uninstalling the audio driver and letting Windows reinstall the driver. Use the Device Manager (under Devices and Printers in the Hardware and Sound Control Panel). Expand the section labeled Sound, video and game controllers. Then right click on the Audio driver. Click on Uninstall then reboot the computer after the driver is removed. The correct driver should be reinstalled. (I believe that you do not have a separate driver for the microphone under Windows but you should make certain of that.) Check for driver updates as well. The Windows Update may list these as Optional updates.
If you have a USB microphone, try a different port. Also check for drivers from the manufacturer.
If you have an Apple or Unix OS, check for similar issues with the connection or drivers.
I hope this helps.
(who had a similar problem with Audacity recording on the line in port last month; I fixed the problem by uninstalling the audio driver and then reinstalling it. Then changing the Recording Source to Line In finished the fix. The driver got changed by a computer tune-up utility (registry cleaner).)
Apr 13, 2012 | Labtec Audio Players & Recorders
My microphone isnt working
First you must check your microphone is muted in your sound card settings in control panel.if it is ok ? you can re install your sound card driver some time your microphone is not detected by sound card driver.
Sep 09, 2011 | Acer Aspire 2930-4661 Notebook
How do we activate the microphone on the Toshiba Laptop Satellite model L550--00p.
Hi richardcharr,
You can "Update the Drivers"
Part 1
Go to the "Control Panel" from the paul7of9_179.jpg Start Menu.
"Open the Control Panel"
Scroll to find "Hardware and Sound," and click on the "Sound" applet.
Open the "Microphone Properties," and click on the [Driver Button].
"Update Driver for the: Microphone"
Part 2
paul7of9_81.jpg From the "Desktop Screen,"
paul7of9_82.jpg Right click on the Volume Icon
Once the 'window' open!
Select the "Recording Device" shortcut.
  • Select the Microphone Icon {2x click} to open.
  • The [Microphone Properties] 'window opens.'
  • Now, check the (Device Usage:) to make sure that it is [Enable].
  • Next, check the "Levels / Enhancements" by clicking on the buttons...
  • Make sure "that all the levels on the [Sound] are up!
  • Next, go to the "Driver" by clicking on the "Properties" button.
  • Select the [Driver] button, and "Update the Driver."
  • "If any of the Driver {Areas} are not "Grayed-Out?"
  • Click, on the "Rollback Driver." Only if; the update didn't "Activate the MIc?"
  • Click, on the "OK" button when finished!
  • "Restart the Computer, "only if a 'message' instructs you to do so?"
!Important: "Take a 'moment to rate the help', so I can get 'credit' for the work.
Thank you!" - paul7of9
Mar 15, 2011 | Computers & Internet
Audio driver is working properly but mic is not working.....using lenovo g430 3000
If the audio driver is working properly but the microphone isn't, ensure that: 1(a). The microphone is not muted.On Windows XP, go to start, run and type sndvol32 and press enter button to launch the Windows Sound Volume Management Panel. Under the Microphone volume control, uncheck "mute" box.This should make your microphone functional again. (b). The wrong microphone may be selected, esp. if your sound-card has an external port for microphones.To rectify the problem, use 1(a) as illustrated above, go to File>Advanced Controls and select Input Devices.Under the Microphone advanced settings, you'll see MIC1 Select and MIC2 Select. Switch the selection as appropriate until it works. 2. If the audio driver has it's own Sound management Panel, e.g that of Realtek, open it's sound control panel and disable all microphone effects that may be enabled. 3. Ensure that sound acceleration is maximum. Open the DirectX Diagnostics Engine by going to Start>Run> and type dxdiag and press enter button.When the window opens, click the Sound tab and slide the Sound acceleration bar to maximum.
I hope my solutions work.Have a good day.
Feb 11, 2011 | Lenovo IdeaPad Y430-3231U Notebook
Microphone not working using realtec software in windows 7
Click start, then enter control panel, click on performance and maintenance, click system, click the hardware tab, then device manager.. Your microphone will be under "sound, video, and game controller" devices. Find your microphone. Right click the device, click the driver tab, then update driver. If that does NOT work, then you need to download the driver that is compatable for your microphone that runs on the Windows 7 operating system.
Nov 22, 2010 | Logitech (980174) Headset
How to get your webcam microphone to work: Click on Control Panel, Hardwre and Sound, Sound, Recording. You should see your microphone icon with a Green check mark on it. If there is no Green check mark, it means it is disabled. If there is No green mark on Microphone it never works. To enable the Microphone Right click on Microphone and click on Enable. If you do not see the Microphone in the list, Right click on the White space and select Show disabled devices. Then you would see the Microphone. However, if you do not see the green check mark on it, Right click on it and click on Enable. And also Select Microphone and click on Set Default (If Set as default button is active).
If you see the Green check mark on Microphone the Microphone definitely works.
Step 3: Increasing Microphone Sensitivity and Un-muting the Microphone.
1. Select Microphone and click on Properties button.
2. Adjust the slider until to 100 % of its range.
3. If Mute is on, click the mute button to un-mute the device.
4. If Microphone Boost is available, boost the volume.
5. Click OK to make the changes.
Now the Microphone should work. To verify you can test it on the free webcam test tool site.
Jul 01, 2010 | Logitech Webcam
Acer aspire 5810t microphone does not work. can anyone help?
it was the same with my pc
i istalled Win 7, after that the mic didn`t work. so i installed the driver for the mic again (can you get from the acer homepage)
after that its fine again. but now i have still a problem with my battery. its not that old and not used that often, but it has only 3h life when full charged....
anyone with the same problem?
Apr 06, 2010 | Computers & Internet
Presario v6000 microphone
go to control panel and enable your audio driver... reboot your laptop.... now open the audio driver icon from the system tray and try to test the microphone... enable the settings for microphone in it
Sep 18, 2008 | Compaq Presario Notebook
Dell Inspiron 700M Notebook Logo
Alun Cox
