Question about Zenith C27V22 27" TV
32" No Power, But Beeping Sound
My TV turned itself off and now won't turn back on. There is a muted beeping coming from the inside of the set, which goes off if I unplug it. No power lights, sound or picture at all. Help?
    President:
  • 1,263 Answers
You have a problem with the power supply module . it is located on the main board and needs to be replaced by a local repair tech.
Posted on Aug 31, 2008
Tv won,t come on makes beeping noise
Try unplugging from outlet for fifteen seconds. Press the power button for a few seconds "before" plugging back in. Now plug back into the wall outlet and try turning it on to see if this reset the TV's settings.
Sep 28, 2014 | Emerson Televison & Video
Panasonic pt56wxf95a turns itself off
Did you replace the bulb? clean dust out of fans?
Apr 17, 2010 | Panasonic PT-56WXF95 56" Rear Projection...
Try to turn on power and it will not come on...makes a beeping sound and the power light flashes multiple times
According to TECH information these sets had alot of defective Tubes bad hori startup transistors and Flybacks so its possible you could have one or the other wrong with TV.
Aug 14, 2009 | Philips 32PT6441/37 32" TV
ACER Aspire- beeping sound - 6seconds when I power machine on
The beeps are telling you there is a hardware failure (POST). The number and length of beeps will give a better indication as to what has failed. Write back with that info and someone on this web site will interpret this for you.
Jan 18, 2009 | Acer Aspire T135 PC Desktop
Beeping noice when tv is on.
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main digital board.
Sep 08, 2017 | Sanyo DS32920 32" TV
Tv troubleshooting
There is problem in the power Supply section.check the h-out Transistor if Damage then Change for the Same COde #
Nov 13, 2008 | Televison & Video
Lg 32lcd2d (tv won't turn on)
It is most likely the power supply. If you see domed caps change them using a higher voltage cap. If it's 1000uf at 15vdc put in a 1000uf at 25 or 35 vdc. If this helps let me know.
Sep 27, 2008 | LG 32LX1D 32 in. LCD Television
RCA 32 in TV no picture no sound just a beeping noise TV power is on
HELLO.! IT SOUND'S LIKE A POWER SUPPLY PROBLEM TO ME.!!! & FOR THE TIME YOU WILL PUT IN TO IT & THE MONEY .!!! YOUR BETTER OFF GETTING A NEW SET.!!!HOPE THIS HELP'S YOU.!!!"GOOD LUCK"
Jul 20, 2008 | RCA 20F511T TV
You have a bad flyback transformer and shorted horizontal output transistor. Your set would have to be taken to a shop to have these parts replaced. Stargazer
Aug 04, 2007 | RCA 32V550T 32" TV
Zenith C27V22 27" TV Logo
169 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
