Home | HP | iPAQ H1940 Pocket PC | Imate jasjam have pro...
HP iPAQ H1940 Pocket PC
Problem for HP iPAQ H1940 Pocket PC
Imate jasjam have problem
By fazal_khan35 on Aug 31, 2008
sir
my htc jasjam was working fine. but i install arabic lang file and then its was aks for restart i restarted my divice and now it not going to the windows, only htc showing. plz help me think you
Solution #1
posted on Aug 30, 2009
Not Rated)
bilalbutt
Rank: Wiz
Rating: 79%, 14 votes
I think the files you installed were not compatiable with your cell or were corrupt try a hard reset here is the procedure;
Hard reset: Press and hold the Left SOFT KEY and Right SOFT KEY, and at the same time, use the stylus to press the RESET button at the bottom of your device. You will be presented with a menu saying 'press R to reset, X to exit', if you press R Your device will be set back to factory default settings.
(The L/R soft keys are the "- -" keys just above the start and OK buttons)
Was this helpful?
Yes
No
Popular Solutions for HP iPAQ H1940 Pocket PC
Questions and Unsolved Problems for HP iPAQ H1940 Pocket PC
Do you recommend HP iPAQ H1940 Pocket PC?
Answer
Answer
over heated my battery on my I-paq and now it will not charge. will i lose my data (excell) if I... (More)
Answer
how do i transfer data from a usb flash drive onto my ipaq PDA. the ipaq PDA does not have a usb... (More)
Answer
My pocket cd is so ruined it cant run in my drive, so i cant install my drivers for the pda on the... (More)
Answer
My HP 3115 Is not loading when I turn on or resets, It show this screen that it says HP invert with... (More)
Answer
When I insert my battery the HP home screen is frozen with 1.07 showing. I can't proceed or do... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For HP iPAQ H1940 Pocket PC:
Top PDA Experts
Rank: Guru Guru
Solutions: 551
Experience: Experienced a lot in computer troubleshooting. Knowledgeable about cellular phones.
Ask Me
Find more PDA Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
