Question about Samsung Audio Players & Recorders
I have recently installed a samsung dvd writer TSSTcorpCDDVDW SH-S202N and repeated get the 2131 error message when trying to burn cd's,not only with itunes, but also windows media player. i found a firmware download on the samsung site, but it only loads 4%. i am so frustrated and have been working here now for 10hrs trying to find the answer. please help??!!
  • 1 more comment
  • Syna Sep 01, 2008
    Thank you, but your answer didn't solve my problem. I deleted I-tunes, redownloaded and installed it and changed my speed to 24, as you suggested.
    The error 2131 still occured.
    Please help!!
  • Syna Sep 01, 2008
    I do feel the help I received from your staff solved my problem! I was also having problems with my windows media player burning cds, but after I redownloaded I-tunes and the firmware (thank you for that . . can't find where I would like to rate that help), both modalities worked just fine. However . . I also used some older cd's! So, not sure which helped the most, but I am very happy and very thankful!
  • Syna Sep 01, 2008
    I was helped, yes, but not by the suggestion to purchace a new burner. Prior help was very much appreciated, thank you all.
    May I call on you again??
    Genius:
  • 1,269 Answers
If you just purchase the device, I suggest you to replace it since that error is a firmware bug. New unit should work fine.
Posted on Sep 01, 2008
    President:
  • 624 Answers
This is caused because you need a firmware update on the drive.
Use this link to get the updated firmware and user manual:
http://www.samsung.com/us/function/search/resultList.do?searchWord=sh-s202n
Please rate this is it helps.
Dave
Posted on Aug 31, 2008
  • Dave DeGain
    Dave DeGain Sep 01, 2008
    Did you do the firmware update? I believe this will solve your problem.
  • Dave DeGain
    It was the firmware upgrade that solved your problem.
  • Samsung Master
  • 6,487 Answers
Delete itunes and re-installed it. This re-established the upper limit.
Changed the itunes burn speed to 24x , I did go back and set it back to maximum speed and it continued to work at the same speed.
Hope that helps..........
  • Mark Gil
    Mark Gil Sep 01, 2008
    If that's the case this can be a prblem already with your media drive , because as I check this problem alot of users are having the same prblem and it only cause by a bad media player/burner... I suggest you to have it replace...
  • Samsung Master
  • 19,396 Answers
I think 2131 is a logical error, it occurrs on Dell and Samsung DVDs, I see if there is a firmware update to fix this.
  • Ginko
    Ginko Aug 31, 2008
    Do a firmware update, I searched on forums and apparently this is the only way to fix 2131, as the error is an internal bug on samsung and dell devices.
    Many new Samsung can do firmware live update automatically, if not download firmware here (select mirror 1).
    Regards
I fitted a new DVD Writer on my computer (XP Pro) and when I put a disc in the rom, a Microsoft error message poped up 'Windows Media Player cannot play the DVd because a compatible DVD decoder is not...
That's going to be a software error. Basically just letting you know that it has no idea how to play the file. Might need to upgrade to the latest Media Playerif you're trying to actually play a movie, or just disable autoplay to get rid of the message entirely
Jul 25, 2011 | Samsung SH-S222A DVD-RAM Burner
DVD not burn by the Writer but burns CD easily.
Some steps you can try.
1. Try a different brand of disks.
2. Try a different burning program.
3. Clean the lens.
Hope this helps you.
Regards Bill
Jun 30, 2010 | Samsung (SH-S162L/BEBN) DVD RW Burner
After installing Samsung's TSST corp CDDVDW SH-S222A, the drive will RW CD's and Read DVD's but not write DVD's. Updated drivern from Samsung - no help.
Please be sure that your writer writes DVD's also confirm once again from where you've bought it..
If its surely the Right one then try some other Image burning softwrae don't use Nero its not good..
Jan 02, 2010 | Samsung (SH-S162L/BEBN) DVD RW Burner
I have a Samsung DVD writer Model SH S202N and want to use it for bitsetting +R can you help please?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If a registry key "Disable_Bitsetting" is present in
  • HKEY_LOCAL_MACHINE\SOFTWARE\Ahead\Nero Toolkit\CD Speed (CD/DVD Speed)
    or
  • HKEY_LOCAL_MACHINE\SOFTWARE\Nero\Nero 8\Nero Toolkit\DiscSpeed (DiscSpeed)
and has a value of "1". Change to "0" (zero)
Nov 06, 2009 | Computers & Internet
Dvd WRITER
you need to go into the control panel. click on clock,region,language. In there you can change the region.
Apr 12, 2008 | Computers & Internet
Dvd/cdrw drive not buning disks from itunes
insert new dvd disc and burn select data disc on it , if it work reinstall the nero software and check otherwise give mail id
Mar 20, 2008 | Computers & Internet
DVD writer not reading disks
change ide cable 1st ok get back with me thx nick
Feb 03, 2008 | Computers & Internet
Burns cds
This could be several issues.
Firstly there could be a format compatability error.
if the burner is looking for Wavs and finding MP3s, then you,ll need to convert the formats, for compatability.
Secondly this could be a copyright protection function, if the cd your trying to copy is protected, then the writer will refuse to copy the files. ( can Sometimes happen if downloaded )
I,d suggest locating some better Software, for your writer.
Or re-installing your original packet-writing software that came with the writer.
Hope this points you in the right direction.
Mike @ compurepair.
Jan 24, 2008 | Computers & Internet
SH-S182 installation
before anything else.. your computer must not be plugged in
have some screw drivers ready
open the case
remove the connections of your old cd/dvd-rom
remove the screws
remove the drive from the bay
replace it with your new dvd writer
replace the connections and the screws
put everything else back
then turn on your system :D
Nov 02, 2007 | Samsung SH-S182 DVD±RW Dual Layer Burner
Samsung DVD writer SH-S182 problem
try a different power connector from psu,do not share same as HD!!should work!!
Oct 07, 2007 | Samsung SH-S182D DVD RW Dual Layer Burner
182 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
