Question about GE Microwave Ovens
GE MICROWAVE GE JVM1842WD HAS NO POWER. OUTLET WORKS. IS THERE A FUSE AND WHERE
  • GE Master
  • 9,098 Answers
This one has an internal fuse, bottom TCO, and cavity TCO, either of which could be open and interrupting power.
A microwave can be dead for many reasons.
It may be the fuse, which is usually located behind the grille or near the internal cooling fan or on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
When checking TCOs thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
The TCOs you need to be concerned usually with have black wires. You can ignore the ones with blue / violet wires in this case.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There is also a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Sep 01, 2008
Boiling water in my GE Spacemaker Microwave it stopped working and looks as if it is at half power. When activated it makes a half power type noise and the light goes dim. Is this a fuse issue?
Probably not a house fuse. Typically good or bad!! Have you tried it in a totally different outlet?? Could be a bad connection of your circuit breaker to the bus bar in your circuit breaker panel. Try it on an outlet on a different breaker. Or have someone check the power at the outlet when it is running and see if the voltage is dropping.
Sep 13, 2017 | GE Microwave Ovens
My ge microwave just stopped working
Do you have power to the outlet? If so and you are mechanically inclined, you can unplug the microwave, remove the cover and there should be a fuse located on or near the circuit board close to where the power cord comes in. Test that fuse using a digital multi meter. That is usually where the malfunction takes place. If it is good then the main board has probably failed and may be cheaper to just replace the microwave.
Jul 07, 2014 | Microwave Ovens
No power checked outlet and power is on
HELLO.
This is the way out of the problem.
The outlet is on power,the power problem is from the microwave.
check on the back of the microvave to locate the fuse that control the supply of power to the microvave.
Change the fuse because it is unable to control power supply.
Then plug the microwave to the outlet.
Thanks .
Sep 19, 2011 | GE JVM1790SK Convection/Microwave Oven
No power to microwave JVM1790SK ...checked outlet and it is live
HELLO.
Since the outlet is live,the power problem is from the microwave.
Thanks .
Model jvm131h002 Stopped working. no power or
yes, at the back of the microwave there are 4 or 6 screws, take them out and then pull the cover follow the cable( the one you connect to the outlet) going to the inside of the microwave inside you will see the fuse change it with the same size, it is a slow burn fuse
Aug 04, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Ge spacemaker jvm1533 is dead wont turn on
check the circuit breaker first it may be the fuse is blown The fuse may be located behind the grille following the power cord on the rside of the unit.
it may be a bad thermal fuse or oven thermostat.
Dec 24, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
My Ge SpaceMaker XL1800 Microwave Oven won't power on any more.
1.Check power outlet for working.
2.If it is than you have broken fuse inside the m/w.
3. To change the fuse you have to disconnect the power to m/w, take the upper grill off, take the screw on top of control panel, lift the control panel up and removed. The 20 Am fuse located behind this panel.
Dec 15, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Microwave - Power Cord Appears to be Dead
Most microwave ovens are equipped with an internal fuse. This is typically located where the power cord enters the cabinet. The cabinet will have to be opened to verify the fuse.
The magnetron is not directly attached to the power source, it has to be stepped up in voltage significantly, either through a transformer or inverter.
It is usually best to have professional tech check the fuse for operation. Most shops will do this for a small fee if you drop the unit off yourself.
Jul 28, 2008 | GE JE1860 Microwave Oven
Ge microwave model #JVM1540SM1SS
Check the internal fuse. Unplug it, unscrew and take off the cover, the fuse should be easily found in the back by the power cord. It looks like a regular fuse but is white instead of clear glass because microwave fuses are special. You'll have to measure it with a meter as a result and be sure to replace it with the same kind. (try finding them at radio shack) Hopefully there isn't something more serious also.
Jan 01, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
74 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
