Packard Bell, EasyNote display problem
Hi, i have a major problem that I have a tottally black screen on my laptop. I have tried holding down "Fn key" and pressing F11 and F5 (as these both look like display keys) a number of times but nothing........Ive tried plugging in an external Screen, Nothing.....Im reall stuck. I have just had a new laptop but i cant see anything on my old one to get years of my data off!!!Aaarrgggh. CAN ANYONE HELP PLEASE????????
    Problem Solver:
  • 9 Answers
Packard bell h5315 easynote usually has the nvidia GPU...I personally think its the GPU and not the screen inverter.
U need to buy a refurbished motherboard that will fix you`re problem..Or try using a heatgun on the gpu..This worked for me on an IBM GPU and fixed the issue.
Posted on Oct 17, 2010
    Problem Solver:
  • 50 Answers
Try the link . . . www.laptop-problem-solution.com
For find your best solution.
7
Posted on Jul 25, 2009
I have a TJ68 packard bell Easynote laptop, it will power up, but display screen is black and flickers. I connect a vga cable to an external monitor and can see contents of laptop on external monitor.
The fact that you can see the desktop on the external monitor means your LCD Inverter on the laptop is bad. The video card in the laptop is good, otherwise you would not be able to see the desktop on either screen.
Shine a flashlight on the dark screen to see if you barely see the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works, then your screen is bad. If you see no icons by shinning the flash light and nothing shows on the external monitor, then most likely your video card is bad.
The lcd inverter can be purchased on ebay for less than $15. It is located at the bottom of the lcd screen. You'll have to remove the plastic strip that is around the lcd screen by removing the plastic or rubber bumpers that have screws under them. Normally there will be bumpers at each corner and maybe along the insides on the plastic strip. Remove the bumpers, the screws and pry the plastic strip off with a little force with your fingers. You will then see the lcd inverter at the bottom of the lcd screen.
Just put your computer's name and model in the ebay search followed by lcd inverter.
Actually it looks like your laptop uses the LED screen instead of LCD so it will not have the LCD Inverter. You will have to purchase a new screen. I found the one below on ebay.
http://www.ebay.com/itm/Packard-Bell-EasyNote-TJ68-AU-065UK-LAPTOP-LED-LCD-SCREEN-/400293582889?pt=US_Laptop_Screens_LCD_Panels&hash=item5d335b5829
May 13, 2012 | Packard Bell Computers & Internet
I buy PC packard bell easynote_TS11HR-032FR and the touchpad does not work, when i use my pc for the first time.
Check this:
Many laptops with touchpads have a switch or a keyboard combo that will disable the touchpad. Look to see if there is a little button you can push located near the touchpad. Alternately, there is normally a Fn-special function key combination you can use. You press the Fn key and also the special function key that has a little symbol on it that looks like a touchpad. That can turn the touchpad on or off.
Aug 05, 2011 | Packard Bell 160240 Mouse
Model: Packard Bell Easynote GN45 - Display has "shifted" to the left; thick black chunk down the right hand side of the screen. Display at top of screen also appears at the bottom of the...
Test the laptop using an external monitor
If this works fine, then the issue is with the screen, or possibly the vga cable. I notice this is referred to as a compatible screen, was this obtained new, or is it 2nd hand. Although most 15.4 screens fit most 15.4 laptops, some do not display correctly, this might be your problem. If you know the screen to be good I would suspect the connection at the back of the screen
If this still shows issues with an external monitor, you have a problem with your graphics chip on the motherboard
Jan 22, 2011 | Packard Bell EASYNOTE GN45 COMPATIBLE...
Packard Bell MZ36-UO24 Easynote laptop using Windows 7 the screen went black suddenly whilst repairing i tunes 10.1 program from control panel now can hear the fan on pressing 'on' button all 3 front...
hi have you tried FN+F3 as tis is the key sequence to send screen to external monitor. however failing this you might try to wipe the whole machine and start from scracth and upon failing this im sorry to say but its time for a new screen, and as i have the same laptop i can tell you the screens are roughly £70 but every now and again you find them on ebay cheap. however i would not advise putting a screen in this machine based on the cost and that the machine is not what ide call GOOD. the graphics card in these are extremely poor and clash with a lot of programes. also if you are ever planning on upping to windows 7 this machine doesnt handle it very well as i have found out, my advice if its the screen is throw it on ebay with a reserve of £50 as they mke good money for spares and repairs and look for a decent laptop as im sorry to say but our packard bell mz36 are pretty much a pice of SH#T.
Nov 25, 2010 | Packard Bell Computers & Internet
How to change the brightness on packard bell notebook. please help me.
On most Packard Bell laptops the brightness adjust keys combinations are hold down Fn and press F8 to turn it up and F9 to turn it down.
If this is not the case on yours then look for 2 F keys with small blue circles with blue dots around them, they are the brightness controls.
Alternatively you can go to the control panel look for display options and adjust the brightness from there.
Regards.
Jul 10, 2010 | Computers & Internet
Touchpad on Packard Bell Easynote not responding
the fn key and one of the f keys should turn this on and off, if not
its possible the cable from the touchpad to the motherboard is loose or the touchpad is bad
Jul 20, 2009 | Computers & Internet
Easynote laptop packard bell
Try Safe mode, disable display adapter and restart. See if this helped.
Nov 04, 2008 | Packard Bell Computers & Internet
Screen on easynote m series laptop very dark can't see
Try updating your video card drivers..
Didn't think Packardbell made computers anymore..
Oct 28, 2008 | Packard Bell Easy One Silver 2101 Notebook
Packard bell - easynote
you have the FN key ingaged try FN + F10, F11, F12 one of those keys should turn it off
Aug 01, 2008 | Computers & Internet
Packard Bell Easynote E4 - Wireless Switch
i've been having the exact same yrouble with my Easynote E4 laptop and have just fixed it.
in the bottom left hand corner of the keyboard theres a key with Fn written in blue, hold this down and press F1it should beep and the 'wireless lan connection indicator' in your system tray the red cross will disipear then you will pick up wireless!
Apr 02, 2008 | Computers & Internet
Computers & Internet Logo
1,577 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
