Question about Samsung RS2630SH Side by Side Refrigerator
Multiple Ongoing Problems w/ Samsung RS2630SH
Icemaker failure x 3. Replaced under warranty.
Cooling failure x2.
Frosting over: ongoing. - Rear panels of the freezer has been replaced x 2. (Apparently a campaign item.)
Now making noise from back of unit. Getting more and more frequent.
  • idc4mhc Sep 01, 2008
    Yes the noise is from the outside.
    Thank You Much!
    Now I am better informed to deal with it!
  • 725 Answers
Noise from the back .. outside ? would be the fan motor DC ver-speed motors.. frosting over is likely a drain problem
Posted on Aug 31, 2008
  • Franklin Ouchida
    Franklin Ouchida Sep 01, 2008
    check the fan blade in the back .. I have seen them crack one of the blades .. you can also check the drain hoses from the back... if they changed the ice maker they should have changed the control board too or you will have more trouble with it...also the ice make will not make ice if the freezer is not 5 degrees hope it helps..
When the Samsung 50" plasma TV is turned on and during the whole time the TV is running there is one small green dot (or light) in around the middle of the screen. It continues and does not go away as the...
Still under warrenty?Yes,call the tv manufacture,get this tv replaced quickly.The Plasma screen is developing a burn in dead pixels.This problems,can't not be repair.Except replaced the Plasma screen itself.The plasma screen panel are 90% of the tvs,not worth repairing,if it damages or broken.Will cost the same as a new tv,if the screen require replacing.Still under warrenty call it in right away to get the picture screen replaced under warrenty.
Oct 04, 2010 | Samsung HP-R5072 50 in. Plasma HDTV
Frigde wont get cold but freezer does.
I am an authorized Samsung service center, and I have dealt with this ongoing design problem for years. The problem occurs when the unit comes out of the defrost cycle, not all of the frost has been removed by the defrost element and an ice bridge occurs at the top and bottom evaporator coil. There are sensors that send readings back to the main PCB during and after this cycle, They have to be replaced along with adding heat transfer clips for better frost meltage and air circulation.
Order the following parts through Samsung:: Fixer # DA61-03585A, Plate # DA61-03502A, Thermal Bi-metal # DA47-10160H, Sensor # DA32-00006W. Have these parts installed by a professional appliance repair company.
I hope this will fix your dilemma, Ward Appliance Repair.
Dec 29, 2008 | Samsung RS2630SH Side by Side Refrigerator
Refrig side won't cool past 55 degrees
Nov 30, 2008 | Samsung RS2630SH Side by Side Refrigerator
What Can I do if My Mp3 sansa m250 froze
This is an ongoing issue and its better that you called Sandisk about this to have it replaced under warranty.
Jun 17, 2008 | SanDisk Sansa m250 MP3 Player
RS2630SH icemaker slow production
Had the same problem. This allows 12 seconds for the tray to fill. If your water filter is the least bit dirty or the water supply line is clogged a bit, you will get an incomplete fill and the cubes will be hollow, mishapen, or, in my case, all won't eject properly. Replace your filter. If that doesn't do it then use a shop vac with any kind of modification to it that will fit into the supply line and **** out the blockages. Hope this helps.
May 27, 2008 | Samsung RS2630SH Side by Side Refrigerator
Hot refrigerator
I had the exact same problem and got sick and tired of it. I contacted the Consumer Product Safety Commision and they came out and photographed my refrigerator and asked questions about the fridge. If everyone who is having trouble would write the commission we might be able to get the fridge recalled. Even if you repaired it already, they want to know the problem and what you did about it. the web site is: www.cpsc.gov. Everyone please help out. The more people we get to respond the better. ThanksZFH3I10
Dec 28, 2007 | Samsung RS2630SH Side by Side Refrigerator
Samsung RS2630SH Side by Side Refrigerator Logo
259 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
