Question about HP Jornada 928
Line API on PocketPC 2002
I'm trying to check if a XDA or Joranda 928 is connected to the mobile phone network, then switch it on and off. I'm having a few problems.... 1) How do I know that I have the right line as lineInitializeEx is telling me there are 7 of them. At present I iterate all of them and pick the one that has INTERACTIVEVOICE assigned to it. However I should be able to use lineOpen with LINEMAPPER but this is always returning no handle. 2) I think the function I need to use is lineGetEquipmentState however I can only get version 2.0 and I think this needs 2.2 with extensions.
  • HP Master
  • 3,920 Answers
Why use this old HP pocket PC? (nobody does now, right>?)_
even a $20 old smart CELL phone works better, cheaper...
there is no HP support now. its obsolete.
but if really compelled to live in dark-ages, (like me)
note the product is SO OLD the forum is locked
read only
http://h30434.www3.hp.com/t5/Tablets-and-Mobile-Devices-Archive-Read-Only/bd-p/palm-webossoftware
see this page, see the word in red, click here?
do that (create and account and post for help at HP.com)
http://h30434.www3.hp.com/t5/Tablets-and-Mobile-Devices-Archive-Read-Only/My-Hp-Slate-Tablet-Wont-turn-on-HELP/m-p/2779395/highlight/true#M55586
Posted on Apr 25, 2017
SOURCE:
Blackberry z10 network setting
try checking if airplane mode is off Tap mba1334327736541_lowres_en-us.png Settings > Network Connections > Mobile Network.Set the Mobile Network switch to On. After you finish: To turn off your connection to the mobile network, set the Mobile Network switch to Off.
Aug 28, 2014 | Blackberry Z10 24Gb Black WiFi Touchscreen...
Samsung phone
you messed up your imei. try this : http://forum.xda-developers.com/showthread.php?t=1264021
Oct 21, 2013 | Samsung Lands Phones
My o2 xda orbit mobile when switched on does not sustain. It gets off by itself. But if I keep on pressing the on/off switch at an interval of say 30 seconds the mobile keeps on as long as I continue doing...
at the moment im currently finding a soloution for this on my own xda orbit. im going to start by dismantling the phone to see if there is a loose connection etc..
also gona try hard reset if it still persists but if it dont work i think its an issue with the battery which id get off ebay, they cost about £5 but ill try these first before i spend money, ill be doing these tonight so ill let you know what happens tomorow.
Oct 15, 2009 | O2 Xda Orbit Smartphone
Solution to my problem
hi there!
Simply, tap your device and go to Connections > check the networks and let you select the networks manually and automatic. if still doesn't work, Insert your sim card to other mobile phone and see if you still don't have your signal. Maybe the sim card was damaged. If not, perhaps the phone has it. Anyway, does your phone locked to another network provider? pls check.
thanks!
Feb 19, 2009 | i-mate JASJAR Smartphone
Http error $code$
i've gotten that a couple times when trying to connect via the internal modem, a simple reset usually fixed it. If your wifi settings are messed up make sure your wifi switch is on, ensure it is enabled in com manager too. Also, try removing the wireless network via the software and adding it again. if all that fails do a hard reset. If that fails you are pretty much out of luck. I had two MDA's.... they both slowly got **** as months went by and i constantly had to reload the firmware, you may want to consider a different model
Jun 11, 2008 | T-Mobile MDA
O2 XDA Zinc
How to hart reset or formating O2 Xda Zinc
Jun 03, 2008 | O2 Xda IIs Pocket PC
How to unlock o2 xda phone password?
i have forgot my o2 XDA stealth password. how can i break it now
Dec 23, 2007 | Cell Phones
T-mobile MDA on/off switch broken
plug in your charger to your phone, find something small to stick into the reseting hole, when your phone turns on, go into settings>power>advanced: un-click the "turn off device if not used for"
it may drain your battery faster, BUT it works!!! :D
Good Luck!
Apr 14, 2007 | T-Mobile MDA
Phone will not connect to network
hi i was also having the same problem but i installed radio version 1.13 for my mini and the problem is somewhat solved though not completely
Aug 01, 2006 | O2 Xda II mini
HP Jornada 928 Logo
64 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
