The reasons why Photos get blurry might not always be an issue with the lens. Here are a few things you should consider - 1) Check if the Battery of the Camera is fully charged. This can hugely effect the outcome of your pictures. 2) Make sure the Memory Card is not full. 3) Check for the Macro or Normal mode. To do this, simply check the top of the LCD Screen. If you find a "Flower" Icon, then the camera is set into Macro mode. To change this, press the OK/Menu button. Find the Macro menu and press up/down to make Macro Off and Normal (Mountain Icon) to On. The camera is now changed into Normal Mode and a Mountain/Pyramid icon should be there at the top of your screen. 4) Try increasing the resolution. Again press the OK/Menu button and press Right/Left until you find a "Lines" icon. Press the Down/Up arrow to choose the resolution. 8M is the highest. Press OK to confirm. Note - Higher the resolution, better the picture quality but lesser the number of pictures you can save. 5) Check if there is a Crossed Thunder Bolt icon on the LCD screen. If you find one, the flash has been turned off. To turn it on, press the Up/Thunder Bolt. A Crossed Arrow with an A should appear. This indicates the Camera has been set to auto Flash.
Hope the images get better with these tips. You can always call Sakar International at 877-397-8200
I found how you change it!! Go to a textmessage in your inbox and use the volume-button on the side of your phone. Up makes the text bigger, down makes it smaller :D
hi this is quite simple, if using xp, just right click anywhere on screen ( not on an icon ) goto properties , then settings, change the resolution settings and this will get the screen back to a normal size, do not forget to apply settings when done, as it will revert back to the default settings you have....hope this helps
Do you mean the icons are huge?
If so the screen resolution is set to low eg, 640 X 480
To change the screen resoultion go to and click on Start - Control Panel - Display - Settings tab and move the slider on the Screen resolution to the right until 1024 by 768 then click OK
If this is not suitable change the Screen resolution higher or lower to suit your requirements.
right click on the desktop and either go t "personalize" or "properties" from there go to "settings" and you will see a slider bar, move it all the way to the right and hit apply and then ok...it should all return to normal. i hope this helps!
Are you using XP or Vista? First thing I would try is a complete uninstall of the lexmark software, download the latest drivers from the Lexmark web site for the operationg system you are using and reinstall.
