Question about Canon PIXMA MP460 All-In-One InkJet Printer
5100 I'm having the same problem with my printer MP460 First it always said jammed paper but there is no jammed paper in it en now it says error 5100 Could you help me?
  • Anonymous Mar 26, 2014
    jammed paper
    Sniper:
  • 62 Answers
1.First I recommend, resetting your printer. Turn it off and unplug it. Wait at least 10 seconds, plug it back in, and turn it on.
Next, if you feel comfortable trying to fix the printer on your own, you can follow these instructions after the phone number. If not, I recommend calling Canon and asking them to repair it for you. You can reach Canon support by calling 1 (800) 828-4040 during regular business hours (currently Monday-Friday 10:00 a.m. - 10:00 p.m. EST, excluding holidays).:
I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on)
Posted on Jan 09, 2009
Error code 5100 on cannon pixma mp460 Does not load paper
Hello and Welcome to FixYa!
If you are facing Error 5100 then it means that the cartridge can not be detected by the printer.
Actually the printer is not actually loading the cartridge and showing you the error 5100.
To solve this error follow the given steps:-
  • Turn off printer
  • Remove both the cartridges from the printer
  • Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches
  • Return the cartridges
  • Turn on the printer.
Error will be removed.
I hope this solution helps you
Let me know If you have any more Confusion, questions or issue regarding your problem
Thank you and Keep using FixYa!
Sep 26, 2011 | Canon PIXMA MP460 All-In-One InkJet...
Terdapat code error 5100
turn off printer, then turn on again, then press paper jam button it may fix the problem
Jan 18, 2011 | Canon PIXMA MP460 All-In-One InkJet...
Alarm is flashing error code 5100 and won't let me print anything
Error 5100 is Carriage error.Possible problems in:
- Carriage unit
- Timing **** strip film
- Logic board assembly
- Carriage motor
First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output) is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.If this not help your printer need service.
Nov 04, 2009 | Canon PIXMA MP460 All-In-One InkJet...
My printer is saying error 5100, what should i do to get my work printed
- Carriage unit
- Carriage motor
Oct 28, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Have an MP460 and cleared a paper jam only to have the error code 5100 pop up and stop everything from printing
You will should be able to find information on that error for your printer by entering "error 5100" without quotes in the search box here. Then press Search. Then choose result 1 and follow the steps. Each step will have more detail available by click that steps link.
Hope this helps. Please remember to rate this information.
Thanks
Jun 04, 2009 | Canon Pixma MP450 All-In-One InkJet...
I have got error code 5100
5100 error code means there is somekind of obstruction inside the printer thats interfering with the printing process. You have to check the inside the printer especially near the gears and under the rollers. The obstruction can be anything like a small piece of paper, a paper clip, ball pin etc., check thoroughly and you will find it. Post back if you need more help.
Dec 03, 2008 | Canon PIXMA MP460 All-In-One InkJet...
Error code 5100 - can't clear it
Lift up below the display screen.The printer top will raise up and a arm will lock into place.Make sure the ink cartriages are firmly in place,snaped into position,sitting flat.Lift arm out of the way and close the lid.Worked for me ,good luck.
Oct 07, 2008 | Canon PIXMA MP460 All-In-One InkJet...
Canon pixma mp460 code error 6000
Solutions for error 6000 Issue: ERROR LCD: Error code (5xxx through 9xxx) appears on the display
1. Press ON/OFF switch to reset the multifunction device 2. Removing paper jams MP450 / MP460 3. The MP460 may require repair
heres the problems currently with mp460 and at bottom is the link
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=13369
this is the solutions for the mp460
for the guest
clean out your ink absorber after unplug
reset printer you still have a little credit card sized paper in your printer that you need to remove it
May 16, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Pixma mp460 error 5100
this error is an error within the printer. This error means that there is something obstructing the printing process. Check inside your printer through the gears that you can see under the lid. There should be something obstructing the gears such as dirt or in my case popcorn. There was even some paper caught underneath the rollers that I had to jiggle around to even see. Check VERY thoroughly.
Oct 19, 2007 | Brother HL-2040 Laser Printer
Canon PIXMA  MP460 All-In-One InkJet Printer Logo
56 people viewed this question
old marine
old marine
