Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Ge oven profile spectra xl44
Is there anyway to bypass the oven lock or bypass the self cleaning mode to get oven working?
  • iamqtpie Sep 26, 2008
    I HAVE A GE GAS OVEN XL44 AND I JUST SELF CLEANED IT AND NOW IT BEEPS AND I HAVE AN ERROR CODE F3. PLEASE HELP
    SUE
    iamqtpie@verizon.net
  • merideth217 Nov 27, 2008
    Your solution was spot on - It saved Thanksgiving Day! Thank you sooo much!!!
  • 750 Answers
Hello ,
Welcome to fixya.
I'm Huuum and happy to assist you,
You asked, is there anyway to bypass the oven lock or bypass the self cleaning mode to get oven working?
Why do you need to do this?
If the door lock is stuck in closed position and preventing you from using the range?
You may free this by following this procedure.
Threat it like an error code.
This can reset the system.
Turn the breaker off to cut the power for 5 minutes.
Then restart the breaker and try the range.
It's like rebooting your computer when its acting strange!
Usually it corrects most problems!.
Or they are sometimes just a glitch.
If this does not remedy the problem, then the lock switch itself is bad and if you think you can bypass it then you may as well change it. Same labor!!.
Let me know how it works out.
Huuum
Please remember to leave a rating.
Posted on Sep 25, 2008
  • Neil Golan
    Neil Golan Sep 25, 2008
    Paulface, I GOT IT!!
    I my have found the solution to your problem.
    Your range is equipt with a lock out system!
    Here are two methods to stop lock out
    Gas/Control Lockout (on some models)
    Your control will allow you to lock out the
    surface burners, oven burners and control
    panel so they cannot be activated.
    To lock/unlock the controls:
    Turn all surface burners off.
    Touch and hold the Gas/Control
    Lockout pad for 3 seconds until the
    display shows LOC ON.
    To unlock the control, touch and hold the
    Gas/Control Lockout pad for 3 seconds
    until the display shows LOC OFF.
    When this feature is on and the touch pads
    are touched, the control will beep and the
    display will show LOC ON.
    The control lockout mode affects all
    controls. No controls will work when this
    feature is activated.
    The adjustment will be retained in memory
    after a power failure.
    touch pads so they cannot be activated when
    touched or cleaning the glass panel.
    To lock the controls:
    Touch the 9 and 0 touch pads at the
    same time for 3 seconds until the
    control beeps twice. The display will
    show LOC continuously and the time
    of day if not blacked out.
    NOTE: All cooking and timing functions will be
    cancelled when locking out the control.
    To unlock the control, touch the
    9 and 0 touch pads at the same time
    for 3 seconds until the control beeps
    twice, and LOC will be removed from
    the display.
    NOTE: Some models have a Control Lockout
    pad. Touch and hold it for 3 seconds to
    lock/unlock.
    Do not forget to leave a rating afterwards!
    Thank You
  • Neil Golan
    PAUL FACE, I FOUND A BYPASS!,
    Let me see if we can help you with this. First try killing
    the power to the oven for 30 seconds and see if the locking mech
    resets. If nothing changes try this: kill the power for at least ten
    seconds, power back up,simultaneously
    press the cooking time, delay start and the number 8 pad. Test should
    appear in the display. Press and hold the self clean key, this will
    test the lock motor and cam assy. The display should show 2 on the left
    (for locked) and change to 3 on the left for unlocked. Travel time of
    the cam will display a 0 between locked and unlocked. You must hold the
    self clean key for these changes. This latch mechanism is thermally
    controlled and sends a message to the main board to lock and unlock
    during self cleaning. We are just bypassing this with this test. Your
    temperature sensor may have gone bad during the self cleaning cycle.
    This is the probe located in the oven cavity. If you know anyone that
    is handy with a meter, it should ohm out at 1092 ohms at room temp. If
    this checks out, someone will have to open the top and check the lock
    motor and cam.
    Huuum NOW let me know if you got in!.
    I'm trying for you!!!!!!!!!!!!!
Stuck in clean mode. Ge Spectra xl44 My wife cleaned the over a couple of years ago using the self cleaning mode and ever since then the oven has been stuck in clean mode when we try to use it. I've...
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Nov 25, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
How do you turn off the self cleaning oven when door is locked on the GE Spectra XL44
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Sep 14, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
XL44 oven. How do you latch the oven closed for self-cleaning...there is no lever.
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
heatman101
Sep 07, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
I have a Ge Profile XL44 range/overn but I can't find the manual - how do I use the self clean. I see the button to press but do I take out the racks before I turn it on?
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!!
Sep 06, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
I have a GE spectra xl44 stove model #jgbp28bea2ct, when I turn on the oven the clean light winks and the oven does not heat up. please help
heatman101
Aug 16, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge xl44 self cleaning gas oven willnot come on
heatman101
Feb 20, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge spectra xl44 repair - the oven will not self clean - regular oven works
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jan 21, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
I have GE XL44 range. How long should i run self
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!!!
Dec 09, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven wont turn on.
I tried several times to get my oven to work and nothing seemed to help. After downloading the manual from this site, my husband locked and unlocked the oven door several times very hard and it knocked something in place and now my oven works. I hope it works for you.
Nov 22, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
1,086 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
