Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Kenmore 253 55673407 side by side
I have a kenmore side by side model # 253 55673407. The frig is holding a temperature of 43ish degrees, which from my research is too warm. The freezer on the other hand is cooler very well. I have played with th temperature dial for the frig and the temp. has not changed. After reading the manual it says to clean the condenser, but I have tried to locate it with no luck. I have cleaned the toe kicker and have noticed no frost in the freezer.
Any ideas on where the condenser is located? An other tips would be great-
Thanks-
Kim
  • Penelope3 Aug 31, 2008
    Thanks for the help! I haven't pulled the frig out yet, is there a panel I remove before I see the condenser? I hope it's just dirty as the unit is only 3 years old. I appreciate your help very much-
    I will defintely rate.....
    President:
  • 1,263 Answers
The condensor is located in back behind the panel. if it is real dirty it's blocking airflow over the coils and fins. if this doesn't solve the problem either the thermo coupler is faulty or the freon is low. if that is the case the unit has to be serviced by a liscensed qualified tech. hope this helps please rate this ....thanks
Posted on Aug 31, 2008
  • Ronald Mueller
    Ronald Mueller Aug 31, 2008
    there should be a panel that you have to remove it will be behind it it will look like a radiator you can't miss it. good luck,
What is the mormal temperature swing of a Refrigerator?
What you call temperature swing, is hysteresis. For a refrigerator it only is allowed a few degrees. 1 or 2 up and down. A swing from 32 to 45 is far to big. Unless the factory can prove they advertise these figures. I would never buy a frig like that.
I would contact the dealer and ask him / her to replace the thermostat and if that is not possible to bring another refrigerator.
Something is really wrong with yours.
Jun 11, 2014 | Kenmore Side by Side Refrigerator
Have side by side and the freezer will not get below 18 to 20 degrees frig works great
those were not good model numbers but u should correct contols I think u will find all the air from freezer is going to frig.
Oct 16, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Not cooling enough per the display
I have this same model which I think I bought in 1988. My frig was overheating also and the compressor was extremely hot. I too cleaned the condensor coils again and have been cleaning them at least annually for a decade and a half by putting an adapter on my small vacuum cleaner. This time I took my 6 hp shop vac and a long bottle brush and scrubbed the coils clean running the brush over the coils many times and using a trouble light to help identify where all the accummulated dust was. Frig is working perfect again. Exhaust temperature is substantially reduced. Hope this helps.
Apr 30, 2009 | Kenmore Refrigerators
Remove faceplate in door of a kenmore frig.
If you look at the bottom of the facial plate, underneath. There are two slots to insert a flat screw driver. You should be able to access everything once you take that off. Good luck
Apr 24, 2009 | Kenmore 54662 / 54664 / 54669 Side by Side...
Kenmore side by side freezer not cooling
try removing the panel in the freezer. you will see an evaporator fan . test it and the thermostat beside it it is one of the two
Apr 09, 2009 | Kenmore 53502 / 53504 Side by Side...
Frig does not stay cold enough
you are either low on coolant or the fan inside the freezer compartment is stuck or defective.
Mar 25, 2009 | Kenmore 55203 Side by Side Refrigerator
Refrigerator is freezing at the bottom and 60 degrees at the top
probably the fan is not running
take the fan housing off and you may find a buildup of ice preventing the fan from running
Nov 29, 2008 | Kenmore 53642 / 53644 Side by Side...
Refrigerator not cooling properly
you need to turn the frezzer downso it lets more cold air into frig. and put the frig setting back in the middle,aslo vac off your coils under the frig.all this should work,if not let me know,also check to see if you have any frost buildup on the freezer walls-mike
Oct 14, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenmore refrigerator 5260 not cold
  • the defrost timer on your machine is actually integrated within a control board/air diffuser. hopefully that is not the problem (expensive).
  • i would start by testing the heater and bimetal thermostat in the freezer. (note: the bimetal thermostat will only have continuity when below 40 degrees.)
  • the heat you feel between the doors is normal (if it is not too hot).
  • some of the heat that is released by the machine is intentionally released between the doors to prevent condensation.
  •  if it seems warmer than usual then you might need to clean the coils under the machine and make sure the airflow under the machine is not obstructed at all.
  • if the coils are dirty then they will not be able to release the heat properly and the heat will be released in other areas like between the doors.
Jul 18, 2008 | Kenmore 52632 / 52634 / 52639 Side by Side...
Kenmore Side-by-side refrigerator
try unplugging it for 5 min and plug back in?
Jun 29, 2007 | Kenmore 57029 Side by Side Refrigerator
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
264 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
