Question about Mitsubishi WS-65513 65" Rear Projection HDTV
Mitsubishi WS65813 Rear Projection TV. Main power board is bad,
Where can i find the main power board (part no. 930B9030) for this TV. I can fix it myself but dont even know where to find this part. Any Ideas?
  • goingdeep599 Aug 31, 2008
    Thanks so much, at least i have a starting point. :)
  • Mitsubishi Master
  • 8,617 Answers
They are no longer available from mitsubishi or the distributors. You may be able to get the board remanufactured at the following link. Just leave them a email with the part number.
http://servicemanuals.vstore.ca/
Posted on Aug 31, 2008
TV won't power on.
The Convergence ICs are bad. There is a pair of them on rather large heatsinks on the main board. If you have little or no soldering experience these can difficult to remove and replace. Not a cheap or quick fix.
Dec 26, 2013 | Mitsubishi VS-45607 45" Rear Projection...
I have a WD 62525 tv that will not turn on, completly dead no lights or sound. replaced the main fuse on power supply board what else could it be?
you might need to have voltage checking at this time. if their is a dc output voltages at the power supply board.if none the main board will not turn on.then probably their is bad component at the power supply board.
Nov 18, 2012 | Mitsubishi WD-62525 62" Rear Projection...
Contstant blinking green light on Mitsubishi ws65813 projection tv
u have bad dm board , this board look like a cable box , when u open the back cover of ur tv u would see this box , u have to replace about 7 capaciotors on this box , the capaciotor are on the small boars inside on this box 1000Uf at 16 volts , but if u have no idea on how to replace this cap u can hire a tv tech nowmal repair is about $250
Nov 02, 2010 | Mitsubishi Televison & Video
Main board is shot.
This will have its own main board, easily replaced, what you need to do is take the board out and get the part number of it then Google it or Ebay for a replacement.
Hope this helps
Mar 06, 2010 | Televison & Video
Mitusbishi WS65813 blinking green light
You have a defective power supply and/or DM board, usualy are bad caps 1000 uf 16v, if after replacing all caps the problem persist you will need to contact mistsubishi and send the chassis for repair.
Jan 16, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Blue screen no signal
You need to replace the surface mounted voltage regulator IC (small black square chip with a metal tab on one end, and two legs on the other end.) it is on the main board, right behind the signal input board. It's a BA09FP regulator IC, you can purchase this on mouser.com
it requires a bit of disassembly, but it is relatively easy to do. it is component number IC9C25. It could be bad, or just have bad connections . This IC supplies 9 volts to the terminal board. Try resolding it first.
Jan 15, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Tv won't turn on?
Your main boards are bad. The FMT, DM, & Power Supply. They are no longer available, You have to have the chasis rebuilt. Mitsubishi is rebuilding these chasis. You have to pull it without any cut wires & ship to Georgia.
tvdoctor
Dec 27, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi ws-55859 parts
time to get a new one.
even you get the main board, you might have other problem that has not show up yet.
Oct 05, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Mitsubishi ws65813
HACKER-PROBABLY BAD CONVERGENCE AMP IC CHIPS,TEST AND SEE IF YOUR CONVERGENCE FUNCTION IN YOUR MENU WILL WORK,IF NOT CHANGE THE 2 STK CHIPS INSIDE TV.IF YOUR NOT A GOOD REPAIR GEEK I,D CALL ATV GUY OUT,EST.AROUND 300.00. JOE TV
Dec 12, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WS-65869 65 in. Power Light
They are little green soldered in fuses located on the center board (the one with the STK's on it) toward the rear of the set near the large transformer.
Aug 24, 2007 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi WS-65513 65" Rear Projection HDTV Logo
93 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
