Question about Kenmore 84052 Dryer
How to light the pilot?
I have a Kenmore 80 series Electric and see there is no front panel.
Do I pull the whole appliance out to find a pilot to light? or am I missing something?
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    Okay...your symptoms are confusing. Is this an ELECTRIC dryer or a GAS dryer? If it is a GAS dryer, there is no pilot.
  • 585 Answers
If this is an electric dryer, it doesn't have a pilot either. If this is a gas dryer it will have an electric pilot. but then if it were a gas dryer, it would have a removable lower front panel for servicing the burner. So you must have an electric dryer. if the dryer runs but does not heat, the electric element is most likely at fault. If you really were looking for a pilot light on an electric dryer, I must recommend that you call a reputable appliance service regarding repairs so as to not jeopardize your safety.
Posted on Dec 17, 2008
How do i get the back off my kenmore hd 90 series washing machine
YOU DONT!!! THE 90 SERIES COMES OFF OR OUT DIFFRENTLY. THE WHOLE BODY IS REMOVED BY PULLING IT FORWARD AFTER REMOVING FRONT SIDE PANELS THEN UNSCREWING 2 SCREWS. CAN THEN PULL OUT WHOLE BODY FORWARD
Oct 18, 2014 | Kenmore Washing Machines
Light pilot light on kenmore 80 series gas dryer
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 24, 2010 | Kenmore Dryers
How do I take the top off of a Kenmore 80 Series?
You remove the back panel that is how your get to everything. once the back panel is removed you will be able to put the belt and the idler pulley on. Please rate
May 24, 2010 | Kenmore 64852 Electric Dryer
Kenmore 80 series washer is it energy efficient
yes
and
yes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 06, 2010 | Kenmore 24032\24036 Top Load Washer
My kenmore 80 series dryer will not heat. Is it a pilot light or a heating element and how difficult is this to fix on my own?
This seems to be an electric dryer so, no pilot light.
The heating element might have failed or it has a heavy current fuse that has failed.
There aren't many things that a dedicated DIYer can't do given time, a few common tools and some common sense.
Having a multimeter at home helps too; these can be had at electronics or auto parts stores and usable instruments can be had for <$20 US. Somewhat intelligible Chinglish instruction sheet is included.
Jan 09, 2009 | Kenmore 65924 Electric Dryer
My Kenmore 80 series dryer is shutting down
Please post the complete model number of the appliance.
Possible problems are -
1) Motor bearings are failing (lack of lubrication).
2) Idler roller is failing (lack of lubrication)
3) Blower bearings are failing (lack of lubrication)
Dec 29, 2008 | Kenmore 659 Electric Dryer
Kenmore 80 Series Heavy Duty Dryer won't work
hi thanks for the question the belt has probably broken there should be a bottom panel use screw driver to pry the front on each side pry outwards remove panel now you should see a broken belt replace thanks the appliance dod
Sep 25, 2008 | Kenmore 63942 Dryer
Kenmore 84052 Dryer Logo
198 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
