Question about Brother HL4040CDN Duplex Unit
I have been having trouble printing my red. My letterhead contains a red "A" in it and a few other items have red. Normally, the red items have pink, yellow or white vertical streaks through them. The page also appears to have faint vertical streaks as well. I created a flyer with multiple images on the front and printed a test of it. When printed, the flyer images seemed ok on the left side of the page; But, from the left center all the way to the right edge of the page the images contain red streaks. If I could get red streaks in the red A, maybe it would not be as bad. I have no clue what is causing this. Please help.
  • Brother Master
  • 6,850 Answers
Replace the magenta image unit. Yellow image unit also and for the white streaks have the glass that cover the laser cleaned.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Jun 13, 2015
SOURCE:
How to write a letterhead to apply for an internship?
Normally a letterhead is a professionally printed blank sheet of paper with your name/address/logo/etc. pre-printed on the top. You could design your own letterhead using a word processing program to print as a header on your application letter. It seems pretty unusual to require a letterhead, especially for an internship. Perhaps they mean a letterhead from your university?
Aug 30, 2016 | Miscellaneous
When printing on letterhead, my documents have a slight "copy" of the letterhead in various locations throughout my document.
Your preprinted letterhead is sluffing off during the fusing process. Have your service tech adjust the fusing temperature.
Aug 12, 2014 | Brother MFC-8860DN Printer
SOMEBODY CAN WE HELP US? WE HAVE A PROBLEM WITH DUPLEX LEXMARK X644.
If you mean that you are getting a ghost image of the letterhead on the page this is caused by not setting the paper type to letter head which caused the temperature to be wrong and print does not bond. Or you may have a bad fuser or bad toner cartridge. Try setting the paper type to letterhead or bond first to see if that helps.
Aug 07, 2014 | Lexmark X644e All-In-One Laser Printer
Can I use two letterheads on a Konica C280
set one draw to letter head set the other to special that way each draw is different. just make sure the paper weight is correct for each paper.
May 18, 2017 | Konica Minolta bizhub Office Equipment &...
I have a Dell 5210N mono printer. And I want to use the manual feed tray as a second paper drawer for letterhead paper only, ie leave a whole stack of paper in the manual feed. Then when I select manual...
Check the software provided or installed on your Computer you use for work(printing software), look for print properties, check for print settings, look for manual Feed, Under manual Feed, set it for letterheads, however this has to correspond with the Applications you are using to print letterheads out of( under print, into the preferrences you should be able to have the settings as well). If your printer software does have these settings, then you will have to do it Manually upon every print.
Dec 03, 2010 | Dell 5210n Laser Printer
How to change the default tray on a HP 2430?
print config page of printer,see how trays are configured.
Jul 01, 2009 | HP LaserJet 2430n Printer
The printer prints the letterhead but not the text on the page.
either your print cartridge is running out of ink or your settings is set to fast draft
Jun 20, 2009 | Brother MFC-665CW All-In-One InkJet...
HP Laserjet 4250tn - cant print a letterhead invoice
Do a paper path test from each tray in diagnostics on the control paneland check Printer Properties for PAPER HANDLING
Feb 17, 2009 | Office Equipment & Supplies
"shadow" print on letterhead and envelopes
CLEAN YOUR DRUM WITH COTTON SWAB. (AND BLOW OUT PRINTER1.gif IF YOUR DARING.)
Jan 02, 2008 | Brother HL-2040 Laser Printer
Brother HL4040CDN Duplex Unit Logo
325 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
