Question about LeadSinger Wireless HiFi Remote Duet Mic for LS-3700 Karaoke Unit Microphone
No sound I have the LS-3700. There is no sound but all other functions (video, mode selections, etc.) work fine. I have tried turning it off/on, checked all plug-ins but still no sound.
  • 1 more comment
  • Anonymous Dec 07, 2008
    exact same problem one minute it was working then it wasnt, did this solution fix the problem??
  • leadsinger Dec 17, 2008
    EXACT SAME PROBLEM BUT FOR THE LEADSINGER LS-2100, DID THIS SORT THE PROBLEM??
  • bobconley Dec 20, 2008
    Video is good but there is no sound from music or mic
I removed the cover on the back (the access to musicartridges) I also removed wireless receiver unit (approx 2" black plastic piece) pull straight up to remove. after removing the receiver you'll see two screws, remove them, unscrew the mic head, pry the body apart (fingernails). You will see two circuit boards, the smaller one became disconnected. The board should reconnect easily, the outlet looks almost like the wireless receiver outlet you removed earlier. if it does not slide in easily DON"T force it, you may be trying to install into receiver outlet ( They look the same), The correct outlet is above (towards mic head) the four outlets to the music cartridges. CAREFUL NOT TO BEND PINS same with the wireless receiver.
Posted on Oct 15, 2008
Tip
Display problems while playing Virtual Console games
If you are experiencing display issues (dim, blank or half-blank screen, ghosted image, etc.) with a Virtual Console game while using the Component Video Cable, please read the following:
Some Virtual Console games default to displaying 240 lines of video. Some HD TV's are unable to display a signal with only 240 lines. Try the steps below to set the Wii to output 480 lines of video, which may solve the problem:
  1. While on the Wii Channel Menu (main screen of the Wii), connect a Nunchuk to Wii Remote.
  2. Select the Virtual Console game from the Wii menu, then select "Start" to begin the game.
  3. When the game starts, press the Home button on the Wii Remote. (In many games, the music can be heard when the game starts.)
  4. Select "Operations Manual" from the Home menu.
  5. Press the Z + A + 2 Button simultaneously (the Z Button is on the Nunchuk). A sound will be heard if the button combination has been entered correctly.
  6. Close the Home menu. The game should now display correctly. Note: You will not have to do this the next time you play, as the Wii console will remember these settings.
If the Virtual Console game is still not displaying properly, but all other games work fine, please call 1-800-255-3700 so that we may assist you further.
on Mar 04, 2010 | Video Game Consoles & Games
Denon AVR-3200 wont go into standby mode
Not sure what you mean by standby mode. The power button on most of the audio remotes I deal with merely turns the equipment on and off.
Nov 24, 2013 | Denon AVR-3200 Receiver
Vsx-815h,power on hear the click as normal but no sound from any sources.The hdmi is allowing pictures so that side is ok.Has happened before and i left it unplugged from the mains for a short time and it...
Hello
At first check does the amp tunes to radio stations and can you hear sound from it. Your amp has no HDMI input function. The setup may have changed to your DVD or Blu-Ray player. Without knowing the device you connected to it, it is difficult to point out the exact fault. Anyway , just try these as your amps' maual indicates.
The user manul of your set points out these reasons only for absence of sound with your amp.
Go to the signal select setup and select "Auto" there. If it is selected to AUTO mode when you input a digital signal or analogue signal, the set will detect it automatically.
check whether MUTE finction is ON. If it is ON, turn it to OFF.
Check the speaker select function.
OK
Apr 12, 2011 | Pioneer VSX-815-K Receiver
Leadsinger sub mic, modle LS 3222. Green lite flashing but no sound. any help?
We had this problem too. Can you perform any functions with the duet mic? We couldn't, just had the light flashing. Turns out the light is supposed to flash (never is solid). Check the connections to the sub mic pack in the back of the main mic. Ours was loose. Once that was plugged in properly, we turned everything off and started again. All was fine.
Good luck.
Nov 29, 2008 | LeadSinger Wireless HiFi Remote Duet Mic...
Magic-Sing EG-18000 works, no sound
look and see if the RF light is coming on, if it is not then the transmitter (mic) is not on the same frequency as the receiver.
Nov 22, 2008 | LeadSinger Wireless HiFi Remote Duet Mic...
LS 3700 Leadsinger Microphone
We had the same problem just this weekend. However, we investigated it ourselves and discovered that you can take the microphone apart by unscrewing the two small screws inside the mic, under the music chips. Once the screws are out pry the two halves apart very carefully. Once we were inside, we discovered that the soundcard was loose and all we had to do is plug the sound card back in. Close 'er up and start up the show. Good Luck!
Nov 10, 2008 | LeadSinger LS-3000 Consumer Microphone
I cannot get the functions on the remote to operate.ie pbass dsp/eq etc?
The P.BASS function is only available with 2 channel LPCM sources such as mp3,Divx,cd
and wma. Press P.BASS button and "POWER BASS ON" will be displayed on the screen.
The P.bass does not work with DSP/EQ or DOLBY PRO LOGIC ll modes.
If you press P.BASS in the DSP/EQ mode, the DSP/EQ mode is automatically shut off and the P. BASS function comes on.
The DSP/EQ function is only available in STEREO mode.
Press the PL ii mode button to show STEREO on the display.
This feature works with CDs, MP3-CDs, 2 channel DVD-Audio, DivX and Dolby Digital discs.
When playing a DVD disc encoded with two or more channels, multi-channel mode will be selected automatically and DSP/EQ function does not work.
Nov 04, 2008 | Samsung HT-Z310T Theater System
No Sound
The camcorder may be in what may be called "narration mode." This function mutes the playback audio so you can narrate with you own voice when playing tapes back. Check for a function like this in the playback sound menu.
Nov 06, 2007 | Panasonic NV-DS60 Mini DV Digital...
Menu Options
sound or volume can be lowered or turned off using zoom control button
Aug 30, 2007 | JVC GR-D370 Mini DV Digital Camcorder
LeadSinger Wireless HiFi Remote Duet Mic for LS-3700 Karaoke Unit Microphone Logo
337 people viewed this question
Top LeadSinger Audio Players & Recorders Experts
Michial Gueffroy
Shehu Pro
Shehu Pro
johnny rebel
Are you a LeadSinger Audio Player and Recorder Expert? Answer questions, earn points and help others
