Question about Alpine MRV-T707 Car Audio Amplifier
Over heating problem
I have 2 12'' kicker comp yellow threading they wired 2ohm with 1 connector on side. my alpine mvr-t707 overheats how do i made amp ohm instead of 4
  • 81 Answers
"how do i made amp ohm instead of 4"
I think you're asking how to make the amp 2 ohm. If your 12's are already wired for 2 ohm, just connect the 2 leads to the bridged terminals on the amp. There will be 4 connections on the amp. One for each channel. Usually, the two outside terminals (one positive and one negative) are the bridge and it'll be noted with a line painted on the surface above the terminals. That's all you have to do.
If it is overheating, you should put cooling fans on it.
Posted on Aug 31, 2008
I have a comp s 12 2ohm kicker and a comp vr 12 dual 2ohm kicker how do i wire these to stay at 2ohms to the amp
you can wire them to be at 2ohm load you need two of the same speaker. its is very bad on the amp to run like that and you will not get a good bass sound because one will over power the other sound wise
Mar 23, 2013 | Alpine MRD-M605 - V12 MONO AMP 600WX1 RMS...
I need to know how to wire 2 Kicker comp 10" subs
you can find your wiring diagram here
Select from the list shown which describes your amp and subs (ie 2 channel amp with 2 4ohm subs)
Hope this helps and please rate, thanks
Mar 19, 2011 | Alpine MRP-M500 Car Audio Amplifier
I have 2 18" kicker
First you need the OHM rating of the subs. Most of the time its on the box or the magnet on the back of the subs (normaly 2ohm 4ohm or 8ohm) And that of the amp. Most amps are 4 ohm output if its a 2channel and 2ohm output if its a mono. You NEED to know these cuz wiring it wrong can blow channels in your amp or cause it to cut "in and out"
Jan 17, 2011 | Kicker Car Audio & Video
Help wiring my subs and amp?
number 1 sub number 2 sub
to amp to amp speaker side speaker side
connect negitive from sub 1 to positive on sub 2 this makes it 4 ohms and especially with that amp you have it will still kick some hard hitting bass good luck
Apr 14, 2009 | Car Audio & Video
Soundstream rub 500-1 mono....
U need to make sure your subs are wired correctly. And u need to make sure all your speakers are at the same ohm load. If u hook up two subs on one channel and two more on the other one u need to make sure that your subs are all 2ohm or 4ohm subs cause if u got two 4ohm subs ran parrallel then u will have a 2ohm setting and if both of them are 2ohm subs them your load will be a 1ohm load witch could harm your amp unless its an 1ohm stable amplifier.
Nov 21, 2008 | Soundstream RUB500-1 Car Audio Amplifier
Wiring my kicker solo-baric 15's
The best you can do is connect the dual 2 ohm voice coils of each respective sub in series (4 ohms total per sub) and then connect each sub to one channel of the amp. This will give each sub 1000W, which is the rated maximum from Kicker.
Mar 13, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Alpine mrv-t757
Hi Big Nick,
Sounds like you have got almost all the good out of those Subs. You can find the screws you need at almost any hardware store or Auto parts store. The light is becase you are dloading the amp with low OHMS.  You may need use one channel and Run the wiring like written blow to get the power problem to disappear.
S1+ = Kicker comp cvr sub coil 1 positive
A+ = Amplifier Positive output.
A+ to S1+
S1- to S2+
S2- to A-
Oct 18, 2007 | Alpine MRV-T757 Car Audio Amplifier
Alpine V12 MRV-T707
power wire from fuse block goes to "the 1 that says power"...remote is used to have your device turn another device a cd changer
May 28, 2007 | Alpine MRV-T707 Car Audio Amplifier
Kicker zx750.1& two 15"kicker solo L7 2ohm
if the amp could handle 1ohm paralell would work if not they wire in series
Apr 08, 2007 | Kicker (ZX750.1) Car Audio Amplifier
Car Audio & Video Logo
85 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
