Question about Kitchen Ranges
I have just fitted a wood burning stove,the horizontal pipe out of the back is approx 7 to 8 inches long,is this too long,I get a lot of smoke coming out of the door until the chimney gets warm,once warm it draws vey well,if I have to shorten the horizontal pipe it will caus a lot of work but it is possible????the upright flue is 5.8 metres 150mm double skinned stainless flue,any ideas???
    President:
  • 1,462 Answers
I have seen this problem solved by fitting a fan at the top of the chimney - sounds daft but it worked. was in a house in france
Posted on Sep 01, 2008
The fireplace no longer produces a flame, i do not have the manual to trouble shoot and fix it
Gas Fireplace Manual - Gas Fireplace Instructions: Mendota ...
mendotahearth.com/gas-fireplace-stove-owners-manual.php
Mendota gas fireplace manuals and gas fireplace instructions for Mendota ...Mendota Gas Fireplace Insert FullView Model FV33i PF2 - Installation Manual
[PDF]FIREPLACE HEATER - Crane
crane-usa.com/assets/.../Fireplace_Heater_2013.pdf
by C Care - ‎Cited by 2 - ‎Related articles
your fireplace heater, please contact Crane. Customer ... This instruction manualapplies to the following models of the Fireplace Heaters product line: Color.
Nov 29, 2015 | Heating & Cooling
Why does my blazeking wood burning stove get creasote in the fire box and how do i get it out?
Hi Darlene,
Creosote consists of combustion byproducts,[smoke] that gradually builds up in the stove & chimney.MOISTURE in the wood,and slow burning greatly increase build-up. 1/4 '' of creosote is considered a hazard. Consult a professional chimney sweep,then burn only 'seasoned' dry hardwood,and when you start or re-kindle the fire,burn it hot enough to thoroughly heat the flue; this will draw the smoke up the chimney faster,decreasing the time build-up can occur. Stay Warm!
Nov 25, 2014 | Home
Poor draft on savannah woodstove
Drolets are a real pain at times. Don't buy their pellet stove. Check your stove pipe to insure its clean and not blocked. This includes spark arrestor. Is you stove cap 2' higher than anything 10' away from pipe? Refer to install manual. If you are not getting an y back draft issues with smoke inside house you may need to add on a section of trip wall pipe at the top.
Feb 27, 2014 | Drolet Savannah 55,000 BTU Wood Stove,...
How is air supply regulated in wood burning stoves?
To regulate air flow, there are damper devices built into the stove, flue and stove pipes. Keeping the air flowing correctly through a wood-burning stove is essential for safe and efficient operation of the stove. Fresh air needs to enter the wood compartment to provide oxygen fuel for the fire; as the fire burns, the smoke must be allowed to rise through the stove pipes, and exit through the chimney.
May 07, 2013 | Home
How do i get even heat thru out the house with a daka wood stove
http://www.hearth.com/talk/categories/main-hearth-forums.4/
You burn wood, and smoke goes up flueway.
You're not running chimney smoke through ductwork so you have a heat exchanger.
What kind of heat exchanger?
probably air since you're running through ductwork?
How much hot air or hot water is coming off heat exchanger?
How big of a space can be heated with that amount of heat?
Is the exchanger located in optimal location?
Considerations.
One room log cabin with fireplace will not stay very warm.
One room house with big wood burning stove in center, with hot flue pipe running across the room and exiting on far wall, will get warm-hot, but will cool off fast.
Why?
Because the BTU output of firewood is much less than electric, coal, oil, or gas.
Otherwise they would have made wood-burning steam locomotives. But the locomotive boiler cannot get hot enough with wood ... the boiler needs coal to produce enough BTUs to boil water fast enough to rotate the turbine and turn the wheels.
Maybe your wood stove output should be measured.
Don't forget a huge percentage of fire heat goes straight up flueway.
Mar 16, 2013 | Lux Tx500 Series Smart Temp Electronic...
Woodstove smokes into the house
I've never used a ceramic chimney, or seen one for that matter. I know that the dual walled vent pipe works better when warn/hot. Can't explain it real well but the inner pipe gets hot while venting the heat and smoke. And between the inner and outer wall is cooler air, which is drawn down towards the wood burner. Creates a suction by the exhaust out of the center pipe. Mine smokes up the house when I leave the doors open and when it's a low flame inside. I'm sure you've checked on the manufacturers' specs for venting but, if you don't already know, look into the thermal dynamics of a dual walled vent pipe. And also a ceramic as you have. Has to be something with your stove install or vent pipe. Hope this couch advise helps!
Apr 04, 2017 | Heating & Cooling
We have just had a new Oregon 7 Stove fitted. We seem to be producing a lot of smoke and the fire is not burning very well. We don't have a manual for the 3 air flow controls and can't work out...
hello.
Drop me a line on info@victorianfireplace.co.uk and I can send a manual to you. the smoke is probably the paint curing on the surface easy to tell as it has a chemical smell and not of wood or coal smoke.
hope this helps kind regards jon
Jun 01, 2011 | Heating & Cooling
We have just had a wood burner stove fitted at some cost and we seem to have rather a lot of smoke smell in the room we thought with a stove this wood eliminate this . .
You won't be able to eliminate all smoke odors with any woodburning system that I am aware of. On a new installation it's possible that part of the smell is coming from light oil coatimg on stove from manufacturer burning off. I would also check setting on damper,and make sure chimney is clean. On manual damper I set them at full open at start. Then when I have a good hot fire going I shut mine down to 3/4. I would do some trial and error to find what works the best for you. I hope this helps. Thanks
Nov 24, 2010 | Heating & Cooling
Wood burning heater when putting wood into stove lots of smoke comes into the house when door is opened.
It ain't drafting right or you have the damper closed. Look for obstructions in the smoke stack.
Wood burning tips
  • Burn only wood. No garbage, plastics, rubber, paint or oil, briquettes, paper, etc. Burning these items releases harmful chemicals into the air.
  • Burn Wise Program from EPA: Emphasizes the importance of burning the right wood.
  • Build small, hot fires instead of large, smoldering ones.
  • Don't "bed the fire down" for the night. Holding a fire overnight is a fire hazard and can create serious indoor and outdoor air pollution problems.
  • Open your damper if the smoke is dark. Dark smoke indicates more pollution is being produced and fuel is being wasted.
  • Keep your stove clean and well-maintained. Follow manufacturer guidelines; replace catalytic stove filters every 1-4 years. Have your chimney checked and cleaned at least once a year.
Use seasoned wood The best fuel for woodstoves is dry, "seasoned" wood. Seasoned wood has a moisture content of about 20% or less. It tends to be dark in color, cracked on the ends, light in weight and has bark that is easily broken or peeled. Here are some tips for preparing seasoned wood:
  • Split the wood to help it dry. Wood will dry out more quickly and burn best if the wood is cut to about 3 1/2 inches to 6 inches in diameter.
  • Cover the split firewood to protect it from the weather and stack it loosely in alternating layers, at least 6 inches off the ground.
  • Time must be given to allow the wood to reach 20% or less moisture required for seasoned wood. This process takes approximately 6-12 months. Think ahead and buy next winter's wood well in advance.
It is recommended an annual chimney cleaning to remove creosote build up and to identify potential problems. Things to consider:
  • The Chimney cap may be plugged by debris.
  • Catalytic combustor and baffles are exposed to very high heat and deteriorate as used. Replace every 1-4 years depending on use.
  • Stovepipe angles and bolts are subject to corrosion.
  • Gaskets on airtight stove doors need replacement every few years. Gaskets and seals are used by the appliance designer to control the location and flow of air into the appliance.
  • Check seams on stoves sealed with furnace cement. Seams may leak and cause you to loose valuable heat and reduce the efficiency of the unit.
  • Replace broken or missing firebricks.
  • Keep the floor of your stove clean of debris and ash.
-from the web
Nov 02, 2010 | Heating & Cooling
I have a wood burning stove fitted in our modern home. The stove has a vertical flue pipe fitted from the top and up through a purpouse built chimney liner in the ceiling. the lower parts of the system...
(1) The lower "enamel" pipe is possibly Ceramic coated pipe, used for high temperature flue applications.
(2) The "stickey black tar" is creasote. Whoever installed the flue pipe did it wrong. It needs to be reversed so that the "Crimped" end of the pipe is pointing down. That way the creasote will drain back into the stove and get burned up.
Apr 01, 2017 | Heating & Cooling
Kitchen Ranges Logo
132 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
