Question about Panasonic Lands Phones
I purchased a KX-TG4323 phone system. I followed the instructions to set up a ringer ID for our two cell phones. Everytime I try to call it still rings to the default setting. I tried several times and it will not work. HELP!!!
Panasonic KX-TG4323 5.8GHZ intermitten Link problem and lose phone connection. Is there a work around or interference causing problem, such as Wi Fy, Fios, neighbor etc. Pleas help
Posted on Oct 28, 2009
How do I turn off the ringer off or lower the ringer setting on my Panasonic cordless phone model #KX-TG5432?
Note, in these instructions: {V} = down on Navigator key (large key in center of phone) {^} = up on Navigator key {>} = right on Navigator key
4 volume levels (high/medium/low/off) are available. The default setting is HIGH. 1 .Press {MENU}. 2. Scroll to "Ringer setting" by pressing {V} or {^}, then press {>}. 3. Scroll to "Ringer volume" by pressing {V} or {^}, then press {>}. 4 Press {V} or {^} repeatedly to select the desired volume. To turn the ringer off, press {V} repeatedly until "Off ?" is displayed. 5' Press {Save}. Note: When the ringer volume is set to off, the handset will display "Ringer off", and will not ring for outside calls. The handset will ring at the low level for intercom calls.
Apr 06, 2011 | Panasonic KX-TG5432 Digital Dual Cordless...
VIBRATE STAYS ON
Follow the below instructions and you can remove the vibrate state. I have included a link to download the phone's manual as a PDF file.
Sound Settings
Ringer Types
Ringer types help you identify incoming calls and messages.
You can assign ringer types to individual Contacts entries,
types of calls, and types of messages.
Downloaded Ringers can be downloaded right to your
phone.
Preprogrammed Ringers include a variety of standard
ringer types and familiar music.
Vibrating Ringer alerts you to calls or messages without
disturbing others.
Selecting Ringer Types for Voice Calls
Your phone provides a variety of ringer options that allow you
to customize your ring and volume settings. These options
allow you to identify incoming calls by the ring.
To select a ringer type for voice calls:
1. Select Menu > Settings > Sounds > Ringer Type >
Voice Calls.
2. Select With Caller ID or No Caller ID.
http://downloadcenter.samsung.com/content/UM/200708/20070824101259031_sprint_m300_ug.pdf
Mar 19, 2011 | Samsung SPH-M300 Cellular Phone
Phone shows ringer is off..how do I turn it on?
Follow the steps
Press Menu--->Ringer setting--->Ringer volume----> press up button to ON the ringer.
You can reduce ringer volume by down arrow and increase volume by up arrow.
Thanx
Jul 24, 2010 | Panasonic KX-TG2343 Cordless Phone
Ringer is turned ,i need to know how to turn it on
here is a download of your manual:
[PDF] KX-TG2343File Format: PDF/Adobe Acrobat - View as HTML
KX-TG2343. Pulse-or-tone dialing capability. The unit is Caller ID compatible. ...... Please use only a Panasonic KX-TCA60, KX-TCA86, KX-TCA88, ..... in accordance with the instructions and limitations specified in this manual. WARNING: ...
service.us.panasonic.com/OPERMANPDF/KXTG2343.PDF
May 23, 2009 | Panasonic KX-TG2343 Cordless Phone
Ring tone changed tonight--it is too loud and awful.
The Ringer ID, Light Up ID, Picture ID and Custom Ringer settings cannot be assigned via the software, nor backed up, restored or transferred to another handset.
3. The USB connection cannot be plugged in while the phone is being charged - it is also physically impossible to do so. Kind of dumb given the USB connection sucks a lot of battery power.
4. In fact the USB should plug in to the base/charger so the phone is instantly connected (like a PDA) once docked, with two-way synchronisation. This is not as important though, as #2 above.
5. It is possible (as I learnt the hard way) to inadvertently wipe out the existing phone book and all its hard fed Ringer ID, Light Up ID, Picture ID and Custom Ringer settings merely by attempting to add new entries thru the software without first retrieving the existing entries from the phone. On the positive side, re-sending the same entries does not overwrite the already set up Ringer ID, Light Up ID, Picture ID and Custom Ringer settings.
Jan 20, 2009 | Panasonic KX-TG5673 Trio Cordless Phone
I have a Panasonic KX-TCA132E but no instructions. I have set up with my phone company for incoming caller id to be displayed, however it is not working. Do i have to use the handset to activate the...
I have had this phone (twin) for quite a few years . If your incoming line supports caller ID it should work immediately. I never had to activate this. I would check if caller ID on your line is working. Check with another phone if you can.
Aug 13, 2008 | Lands Phones
Phone wont talk--it has talkingidfeatures
The ringer has to be on first. Usually the unit announces the caller’s name after the 2nd ring. If you turn on the answering system and set the ring count to “2” the unit does not announce the caller’s name. Set it for more than 2 rings for name announcement.
Jul 16, 2008 | Panasonic KX-TG5632 Phone
Ringer ID, editing a caller 's phone #
See caller ID section on this Manual
You can edit the caller number if you are connected to a PABX system and require prefixing for outside lines, you can also remove area codes if you want to return a call just using the local code without the area code
http://service.us.panasonic.com/OPERMANPDF/KXTG1032.PDF
Jul 02, 2008 | Panasonic KX-TG1033S Cordless Phone
KX-TG6052 two handsets. Can't get Talking-Caller ID to turn off!
to turn the talking caller id off go to the menu press 0 then * then 4, then press 0 again to select off.
to turn the ringer on the handset back on, go to the menu, prees 1, 1, then press 1 for a low ringer, 2 for medium and 3 for high.
Mar 15, 2008 | Panasonic KX-TG6052B Phone
Lands Phones Logo
97 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
