Question about HP PSC 1410 All-In-One InkJet Printer
Green light under start button
Printer shows E where sheet numbers are. Light under no paper is on. Do i need a new ink cartridge?
  • Anonymous Sep 05, 2008
    i have stalled cartridges
    Scholar:
  • 136 Answers
The E means Error. disconnect the printer's electrical supply and reconnect after a few minutes. Reload it with paper and print a test page.Make sure you have ink in your cartriges.
Posted on Sep 19, 2008
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
Printer is flashing an alarm and showing a message of "E" and "2"...what does that mean?
Hi-
This is the list of error code
How to clear Error Code Canon printers MP150 MP160
CANNON Printers MP150/MP160 ERROR CODE
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber
full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
Steps:
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting formenu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED
lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
Hope this helps!
Good Luck!
Mar 21, 2011 | Canon PIXMA MP150 All-In-One InkJet...
My yellow ink light flashing despite ink in cartridge. New cartridge does not solve this problem
Hi not know if it work for you but you can try
re: How do I reset the ink level? e: How do I reset the ink level?
1) Disconnect the printer's power outlet
2) Press and hold the power button while connecting the power outlet back. 3) While still holding down the power button, press the reset button twice.(red circle with a triangle) 4) Release the power button
The printer takes about 10 seconds to show the number 0. (at this step, i press and hold the reset button twice, each time i press and hold is about 5 seconds. then i'm able to continue to the next step) 5) Press + to change the value from 0 to 1. 6) When this value is 1, press colour button; this will light up two leds.
One is for plain paper and the other for photo paper. At this point feed the printer with paper. 7) Press the power button twice and the printer will print a some stuff (if this page doesn't print by itself, press the "color" button once and the test page will print). Don't worry much about the printed material. I got some stripped lines and some numbers. I believe that my colour cartridge is clogged which is why I got the green strips.
When you print this sheet the value in the display returns to zero. (at this step, i have to wait for about two minutes or more then the printer automatically start print the document mentioned.) 8 ) Open the printer cover cover (not the scanner cover) and remove the cartridges. With the printer still open, disconnect the power outlet. 9) Close the lid and turn on the printer. 10) Refill cartridges and place them back in their nice little abode in the printer. 11) close the printer cover. Wait for 2 mins. (for my printer, i didnt wait for two minutes, the light immediately disappeared) The amber light beside the black ink and color ink will have disappeared.
Also if you take printouts now you will no longer get the ink low warning.If you check the ink status
it will show that the cartridge is full !!! THe ink level has been reset successfully."
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one and to go on helping.
All The Best: Pineworks
Feb 07, 2010 | Canon PIXMA IP5200 InkJet Photo Printer
On the screen show 5e
Procedure to reset Printer canon MP145, MP150 and Canon MP160 with Error Code Message for Printer Canon MP145 and Canon MP160, you can find error code message the end of this post:
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
button pressing
5) Unplug cable power. (for MP145 / MP150)
6) Turn Off Power. (for MP160)
Error Code :
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 – Ink remaining is unknown
E16 -E19 = Failed to scan head alignment sheet
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error – USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
Aug 09, 2009 | Canon PIXMA MP150 All-In-One InkJet...
ERROR CODE E-4 0. No activity on turning ON the printer
MP150/160 resetting errors: do a EEPROM reset
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E8 Waste ink absorber full, or platen waste ink absorber full
Direct Printing
E22 Carriage error
E29 EEPROM error
E35 15 USB Host VBUD over current error - USB
button pressing
procedures below.
procedures below.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 24, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Red light on steady
If the ink light is on steady red, that means the black or color ink cartridge is nearly empty. Obtain a replacement black or color ink cartridge. To know which cartridge is out of ink, check the ink levels using EPSON Status Monitor 3 (Windows) or EPSON Status Monitor (Macintosh). If you just replaced the cartridges before you got the error light, that means that the replacement cartridge is not recognized by your printer. Please reseat cartridges. Then turn the printer on and off. The cartridges maybe bad also.
If the paper light is on steady red, try to reload 10-20 sheets of regular paper into your printer. When printing on CD/DVD, CD/DVD tray is not inserted in the printer. Insert the CD/DVD tray in the printer and press the paper button.Could also be that the printer has loaded more than one sheet of paper at a time. Load paper in the sheet feeder, and then press the paper button to resume printing. If the CD/DVD guide is open, close the CD/DVD guide, load paper and then press the paper button.
May 17, 2009 | Epson STYLUS R230 InkJet Photo Printer
E5 light
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
Direct Printing
E22 Carriage error
E29 EEPROM error
button pressing
procedures below.
procedures below.
Thanks, Joe
Mar 25, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Doesnt recognise refilled catridge of canon pixma mp145
it will show that the cartridge is full !!! The ink level has been reset successfully."
PS: I did not solve this myself just copy and paste from other source but I tried it and it works.
Feb 25, 2009 | Canon PIXMA MP150 All-In-One InkJet...
My MP160 has an error code E5 and nothing I do will move it
I think you may have answered your own question.
Here is a list of error codes for your printer, as you can see the code E5, means the cartridge is not installed properly or un-supported.
I would remove cartridge, check slot for debris, clean contacts on cartridge, re-seat cartridge and then try again. If all fails then try a new cartridge, as the other one could be faulty.
If you still have no joy, you probably have a faulty print head unit.
E3-3 = Paper jam
E4 = No ink
E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
E29 = EEPROM error
E35 15 = USB Host VBUD overcurrent error - USB
Feb 07, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Current Problem on Printer """E5"""
This error means waste ink counter is full.
Solution:
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Press resume
Feb 01, 2009 | Canon PIXMA MP150 All-In-One InkJet...
HP PSC 1410 All-In-One InkJet Printer Logo
27 people viewed this question
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
