Question about Watches
Casio 2758 will not go into timekeeping mode
Dear Sirs,
After having a replacement battery installed, and this after losing all display, my Casio 2758 will not go into Timekeeping mode. Instead it displays the month.date and seconds.
Because of this I cannot change from the 12-hour to the 24-hour mode.
How can I fix this, or does it mean that there is a failure in the processing untit or something ?
Yours truly,
Bill Abrahams E-mail billabrahams@telenet.be
4 Suggested Answers
SOURCE: Tag Heuer Aquaracer calendar problems
You have to unscrew the knob first then you will be able to pull it out to change the minutes, hours, date. You may have to use a pair of small pliers to initially turn the knob.
Posted on Mar 17, 2008
SOURCE: How do I change my Casio twin sensor alti thermo
Press and hold the top left button for 2 seconds to go into the time adjustment mode.
While you are in this mode press the top right button to switch between 12 hour and 24 hour modes.
Press top left to return to normal.
Posted on Feb 21, 2010
cmcduncand
  • 714 Answers
SOURCE: Stopped Pocket Watch
RECOMENDATION:
Seek professional help.
To find a registered repair person in your area.
GOTO:
http://www.watch-clock-makers.org/
Hope this tip helps.
r/ David
http://antiqueclock.clockstop.com/
Posted on May 14, 2010
SOURCE: can not change from 24 hours mode to 12 hours mode
1. Press [A], the top left button, and the seconds should start flashing 2. Once you have some digits flashing, press [D], bottom middle button, and will switch between the 12h/24h formats 3. Wait a few seconds and the digits should stop flashing and return from the time set mode, to timekeeping mode.
Here is a link to a manual directly from Casio, showing you all of these steps. As per the explanation on top of the manual, this should work with 3 different models of Casio watches, including yours. http://ftp.casio.co.jp/pub/world_manual/wat/en/qw1659.pdf
Have a good day
Posted on May 06, 2011
Testimonial: "perfect"
Casio Wave Ceptor 3353. Digital time is correct. Hands are about 15 minutes fast ahead . Cannot correct.
I have the casio 3353. When I read hte manual to do different things, it always startes the instruction by saying "in timekeeping mode". In the instuction booklet at page 8 it shows a picture of the watch face in timekeeping mode and in the picture the face shows the day and date. My face is showing the digital time here. How do I show the day and date,or the timekeeping mode?
Sep 09, 2010 | Casio DW9051B-1V Wrist Watch
I have a casio 2747 and i am having setting the time digitally because i dont want military time and it refuses to change plzz help me
On the Casio 2747 you can easily change between 12-hour and 24-hour (i.e. Military time)... Follow these steps:
1. Make sure you are in Timekeeping Mode (i.e. digital display shows date at the bottom).
2. Press the "D" button (i.e. bottom-right button) to toggle between 12-hour and 24-hour timekeeping.
Note: 12-hour timekeeping mode will display an "A" or "P" for AM and PM.
Mar 10, 2010 | Casio G-Shock GW300CA-1V Wrist Watch
How do I set the analogue hands so hat they tell
Push the lower left mode button (C) until the bottom line of the LCD is "HS". Then press either to top right (B) or bottom right (D) buttons to change the position of the hands. The mode button selection is shown on page 1 of the manual. Changing the hands is described in the Analog Timekeeping section on page 4 of the manual. The manual is currently available here: http://ftp.casio.co.jp/pub/world_manual/wat/en/qw2735.pdf
Dec 06, 2009 | Casio WVA105HDA Wave Ceptor watch
I can't turn the alarms off on my Casio GW-330ca
Setting CASIO G-Shock Watch 1) Home City
2) Home city and Setting the digital time
3) Adjusting hands
4) Alarm set/on/off 5) Snooze 6) Hourly Chime A --- B ( ) Button reference C __ D
1) Select home city first (if equiped):
Press C until regular timekeeping mode is reached. Hold A until seconds flash. Press C to get to city code. Use B and D to move city east or west to your home city. Press A to set and exit.
2) Set time, Date, etc:
Hold A until seconds flash. Press C until item to adjust is flashing. Press B or D to adjust. Press C to go to next item. Press B or D to adjust. Press A when done adjusting all items to exit.
3) Adjust hands (if equiped):
Press C until H-Set is reached. Hold A until time flashes. Press D to advance minute hand. Press B while holding D to set faster and continuously. Press D to stop hands when correct analog time is reached. Press A to exit H-Set mode. Press C to go back to timekeeping mode.
In Timekeeping mode B is illumination and D is time/day/date display advance.
4) Alarm set/on/off
Press C until alarm mode is reached (AL1 - AL4 + SNZ and SIG). Press D to select alarm to adjust. Hold A until alarm time flashes. Press B or D to adjust alarm time. Press C to toggle between hour and minutes set. Press A to exit. Press A to turn alarm on and off.
Repeat for AL2 - AL4. Press C to return to Timekeeping mode.
5) Snooze (SNZ) Press C until alarm mode is reached (AL1 - AL4 + SNZ and SIG). Press D to select snooze alarm (SNZ). Hold A until snooze alarm time flashes. Press B and D to adjust snooze alarm time. Press C to toggle between hour and minutes set. Press A to exit. Press A to turn snooze alarm on and off. Press C to return to Timekeeping mode.
To stop any alarm, press any button. To cancel next snooze, Press C and go to either the timekeeping screen or the snooze alarm screen.
6) Hourly Chime (SIG): Press C until alarm mode is reached (AL1 - AL4 + SNZ and SIG).
Press D to select hourly chime (SIG). Press A to toggle chime on and off.
May 09, 2009 | Casio G-Shock G2600 watch
I have the wrong day of the week, when I set the date.
The day of the week will be right after setting the year, month, and date. Adjust with step 2) from timekeeping mode (where time, date, and day can be toggled with button D).
1) Home City
2) Setting the digital time
3) Adjusting hands
4) Alarm set/on/off
5) Snooze
6) Hourly Chime
A --- B
C __ D
Press C until timekeeping mode is reached (high beep).
Hold A until seconds flash. Press C until item to adjust is flashing. Press B or D to adjust. Press C to go to next item. Press B or D to adjust. Press A to exit.
Press C until H-Set is reached. Hold A until time flashes. Press D to advance minute hand. Press B while holding D to set faster and continuously. Press D to stop hands when correct analog time is reached. Press A to exit H-Set mode. Press C to return to timekeeping mode.
4) Alarm set/on/off
Press C until alarm mode is reached (AL1 - AL4 + SNZ and SIG). Press D to select alarm to adjust. Hold A until alarm time flashes. Press B or D to adjust alarm time. Press C to toggle between hour and minutes set. Press A to exit. Press A to turn alarm on and off. Repeat for AL2 - AL4. Press C to return to Timekeeping mode.
5) Snooze (SNZ):
Press C until alarm mode is reached (AL1 - AL4 + SNZ and SIG). Press D to select snooze alarm (SNZ). Hold A until snooze alarm time flashes. Press B or D to adjust snooze alarm time. Press C to toggle between hour and minutes set. Press A to exit. Press A to turn snooze alarm on and off. Press C to return to Timekeeping mode.
To cancel the next snooze: Press C until the timekeeping screen is reached or go to the Snooze alarm (SNZ) screen.
Good luck,
Techjoel
Apr 27, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
Need to fix time on Casio G-Shock
The hands are set independent from the digital display
1) Home City
3) Adjusting hands
4) Alarm set/on/off
5) Snooze
6) Hourly Chime
A -- B
C __ D
Press C until H-Set is reached. Hold A until time flashes. Press D to advance minute hand. Press B while holding D to set faster and continuously. Press D to stop hands before correct analog time is reached. Press D to step to current time (hands only go forward). Press A to exit H-Set mode. Press C to return to timekeeping mode.
4) Alarm set/on/off
5) Snooze (SNZ):
Good luck,
Techjoel
Apr 18, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
I cant set the digital time in casio illuminator
1) Home City
3) Adjusting hands
4) Alarm set/on/off
5) Snooze
6) Hourly Chime
A -- B
C __ D
4) Alarm set/on/off
5) Snooze (SNZ):
Good luck,
Techjoel
Apr 16, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
Instrutions for casio g600
A --- B Setting the digital time.
C __ D
Hold A until second flash. Press C until item to adjust is flashing. Press B or D to adjust. Press C to go to next item. Press B or D to adjust. Press A when done adjusting all items to exit.
Good luck,
Techjoel
Jan 06, 2009 | Casio G-Shock G600-1AV Wrist Watch
Casio G-Shock 7510
1) Home City
A --- B 2) Home city and Setting the digital time
( ) 3) Adjusting hands
C __ D 4) Alarm set/on/off
5) Snooze
6) Chime
4) Alarm set/on/off
Press C to enter alarm mode (AL1 - AL4 + SNZ and SIG). Press D to select alarm to adjust. Hold A until alarm time flashes. Press B and D to adjust alarm time. Press C to toggle between hour and minutes set. Press A to exit. Press A to turn alarm on and off.
5) Snooze (SNZ) and Hourly Chime (SIG):
Press C to enter alarm mode (AL1 - AL4 + SNZ and SIG). Press D to select snooze alarm (SNZ). Hold A until snooze alarm time flashes. Press B and D to adjust snooze alarm time. Press C to toggle between hour and minutes set. Press A to exit. Press A to turn snooze alarm on and off.
To turn any alarm off, press any button. To cancel next snooze, Press C to go to either the timekeeping screen or the snooze alarm screen.
6) Chime on/off
Press C to enter alarm mode (AL1 - AL4 + SNZ and SIG). Press D to select hourly chime (SIG). Press A to toggle chime on and off.
Good luck,
Techjoel
Nov 18, 2008 | Casio G-Shock GW500A-1V Wrist Watch
Watch
1) Home City
3) Adjusting hands
4) Alarm set/on/off
5) Snooze
6) Hourly Chime
A -- B
C __ D
4) Alarm set/on/off
5) Snooze (SNZ):
Good luck,
Techjoel
Aug 08, 2008 | Casio G-Shock G510D-1AV Wrist Watch
Watches Logo
363 people viewed this question
Top Watches Experts
Jimmy Accardi
Are you a Watch Expert? Answer questions, earn points and help others
