Question about HP iPAQ RX3115 Pocket PC
Soft Restart Whenever my IPAQ has not been in use for an extended amount of time, the power button will not turn the unit on... I am having to restart the unit using the soft restart key on the bottom of the unit. is this normal, am I doing something wrong... do I need to change a setting on the unit?
    Master:
  • 450 Answers
No thi is not normal and it sounds to me as if the unit may be faulty.
Posted on Sep 12, 2005
I´ve a pda hp h5455 that don´t start , i´ve tried to do a hard reset and charge it via USB and nothing hapens
To do the hard reset, while on battery (NOT A/C) power, hold down the two outside front-panel buttons (Calendar and iTask), While holding them, press the reset button with the stylus. Keep these buttons all pressed until the image on the screen begins to fade (about 4 seconds), then you can release the reset and application buttons. To restart your iPAQ, you must then plug the unit into A/C power, or do a Soft Reset by again, pressing the reset button with the stylus.
Nov 21, 2009 | HP iPAQ H5455 Pocket PC
Power on problems
  1. some times it may in loose contact or cool reboot problem, switch off, check and clean all contacts, refix it
  2. in my view after a long time its cooled that make this contact problem, when it warm up this effect is eleminated
  3. it may happened some old systems
Jan 20, 2008 | HP iPAQ HX4700 Pocket PC
I forgot my passwod to my windows mobile ipaq 5.0
here is your answer
but if you want to solve your problem quick
microsoft takes 11$ to fix it
see this if this help you
Resetting the Device
Sometimes there is a need to reset your Pocket PC. Resetting the
device is known as performing a "soft" or "hard" reset.
Performing a Soft Reset
A soft reset stops all running applications, but does not erase any
programs or saved data. Be sure to save any unsaved data within
a running application before performing a soft reset.
Perform a soft reset to:
■ Stop all running applications
■ Install a new application
■ Restart the Pocket PC if it stops responding
To perform a soft reset:
1. Locate the recessed Reset button on the bottom of your iPAQ
Pocket PC.
2. Use the stylus to lightly press the Reset button.
The Pocket PC restarts and displays the Today screen.
Performing a Hard Reset
Perform a hard reset only when you want to clear all
user-installed settings, applications, and data from RAM
(Random Access Memory), where data and applications you have
loaded are stored.
CAUTION: If you perform a hard reset, your Pocket PC loses all data
and programs not saved in iPAQ File Store.
To perform a hard reset:
1. Press and hold down the Calendar and iTask buttons.
2. While holding down these buttons, use the stylus to
lightly press the Reset button on the bottom of the iPAQ
Pocket PC for about two seconds.
3. When the Pocket PC screen begins to fade, release the
Calendar and iTask buttons first, and then remove the stylus
from the Reset button.
Note: If you simultaneously push and hold the Reset, Calendar,
and iTask buttons for more than two seconds, the battery
disconnects. To restart the device, either plug the device into the
AC Adapter or press the Reset button again.
After performing a hard reset, you may need to reinstall
applications stored in iPAQ File Store to restore shortcuts and full
functionality.
4. The Pocket PC resets and powers on.
To return your iPAQ Pocket PC to factory settings after
performing a hard reset:
1. Tap Start > Programs > File Explorer > My Device.
2. Tap the iPAQ File Store folder to open it.
3. Tap Edit > Select All.
4. Tap and hold the selected files, then tap Delete.
5. Tap Yes to delete all file in iPAQ File Store.
Oct 16, 2008 | Computers & Internet
HP Ipaq 2910 wont finish the boot
Hey :), I'd be happy to help. I honestly don't think that you've physcially damaged your Ipaq, so you should probally hard reset your Ipaq. To do this you must hold down the reset button and the power button at the same time for like 5 seconds. This will get rid of data on your pocket pc, but It might solve your Ipaq's problem. Thanks! and I hope this helps, if it doesn't I'd recommend for you call Hp where they will repair it or give you a new one :)
Sep 01, 2008 | HP iPAQ H2210 Pocket PC
Power-on delay
some software program is causeing it to slow down.
try uninstalling some of your programs, or preform a hard reset witch returns the pda into the original state.
How Do I Perform a Hard Reset?
Perform a soft reset when:
  1. Press and hold the Calendar and iTask buttons.
  2. While holding these buttons, use the stylus to lightly press the Reset button on the bottom of the iPAQ Pocket PC for about two seconds.
  3. When the Pocket PC screen begins to fade, release the Calendar and iTask buttons first, and then remove the stylus from the Reset button.
    CAUTION: If you push and hold the Reset button for more than two seconds, the battery disconnects. To restart the unit, either plug the unit into the AC Adapter or press the Reset button again.
Mar 23, 2008 | HP iPAQ HX2400 Pocket PC
Doesn't start up
Hi, Based on your post/description, your iPaq 2210 will not power on. It is possible that your battery is deactivated. To reactivate, plug it to the AC power supply/adaptor, press reset at the back of the unit. Assuming no other problem, the unit will initialize back to default factory settings. It's very likely that all your previous/personal settings, files and applications will be also gone. Good luck and pls post back how things turn up. Kind regards.
Jul 21, 2007 | HP iPAQ H2210 Pocket PC
3970 Stuck
Try this, take the ipaq off the cradle, turn the ipaq off (if you can), restart the desktop, put the ipaq back in thc cradle, turn the ipaq on, and restart ROM update again.
Sep 12, 2005 | Compaq iPAQ H3970 Pocket PC
RX3115 Remains on
Calendar appointments will wake up the unit. You can change the power settings so that the unit will turn off after a certain amount of time. On my iPAQ rx3715, it's Start>Settings>Power>Advanced tab.
Sep 11, 2005 | HP iPAQ RX3115 Pocket PC
IPAQ 5455 Hard Reset
Just hold down the calendar and today buttons, these are the two outer buttons on the lower left and lower right, then using a stylus press and hold for at least ten seconds the soft reset button this is located on the lower right edge of the unit. The screen should reset and the iPAQ will boot up again.
Sep 07, 2005 | HP iPAQ H5455 Pocket PC
HP iPAQ RX3115 Pocket PC Logo
44 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
