If your computer came with a motherboard disc the sound drivers could be on it
Click start control panel administrative tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers.
Click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have selected the correct speaker settings.
Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
If his does not fix the problem
Click start control panel sounds and audio devices you can adjust the volume there also select speaker.
volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the speaker volume icon system select adjust volume.
Click start control panel sounds and audio volume advanced speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand system speaker right click properties then select use this device (enable).
The speaker plug/outlets is usually at the back of the computer or if its a laptop on the side.
You will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity.
Clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line specifically around the sound card and the CPU central processing unit.
Dust causes static to build up in a computer
http://download.cnet.com/2000-20_4.html
On the home page you should see a search tab just type in what you are looking for.
Tick in either the all software or windows software box
IE: motherboard name audio driver you might have to try a few times to get it right
for windows 7
Click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to update drivers.
Click start right click on computer select properties then device manager scroll to sound and video if you right click on sound and video then on high definition audio device select update driver software.
Click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers.
Right click on the speaker icon in the bottom taskbar you will see an array of options select
playback devices make sure it has a green tick and the correct speakers are selected
be updated if you computer came with a motherboard disk the drivers could be on it although
once speakers are connected widows 7 should automatically update the drivers.
Click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker.
You might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down list in the advanced tab select dvd quality or another then apply
Hope this helps
Laptop
Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it.
Click start control panel sounds and audio devices you can adjust the volume there also select speaker volume.
You can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the speaker volume icon system select adjust volume
from the drop down list or navigate to the device manager scroll to system devices + to expand system speaker right click properties then select use this device (enable) also you might check the speaker plug/outlets they are usually at the side of the laptop.
dust causes static to build up in a computer
on the home page you should see a search tab just type in what you are looking for
for windows 7
be updated.
If you computer came with a motherboard disk the drivers could be on it although
Hope this helps
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrative tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to
reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have selected the correct speaker settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker
click start control panel sounds and audio volume advanced speakers select the appropriate speakers
the speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
for windows 7
click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to update drivers
click start right click on computer select properties then device manager scroll to sound and video if you right click on sound and video then on high definition audio device select update driver software
click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers
right click on the speaker icon in the bottom taskbar you will see an array of options select
click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker
you might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down
Laptop
reinstall drivers
the speaker plug/outlets is usually at the side of the laptop
for windows 7
hope this helps
reinstall drivers
for windows 7
hope this helps
Laptop
reinstall drivers
for windows 7
hope this helps
right click on the speaker icon in the bottom toolbar select playback devices should be a green tick in the speakers if not right click select configure also check the communications tab make sure the are not muted
hope it helps
?· Right click on the speaker icon in taskbar and select volume control options.
?· Put a check mark on "All devices currently playing sound".
?· Make sure you have "The default communication device unchecked".
?· Place a check mark on both speakers and headphones.
For Windows XP
- Speakers, Headphones
?· In "Control Panel", select "Switch to Classic View", and open "Sounds and Audio Devices".
?· In "Sounds and Audio Devices Properties", click the "Audio" tab, and click the "Volume" of "Sound playback".
?· On the "Master Volume" screen, click "Properties" in the "Options" menu.
?· Add a check mark to "Playback" of "Adjust volume for" on the "Properties" screen, and check marks to "Master Volume" and "Wave" for the control to be displayed, and click the "OK" button.
?· On the "Master Volume" screen, remove the check marks from "Mute all" of "Master Volume" and "Mute" of "Wave".
Note: The settings may differ depending on the PC you are using. Please check items such as sound in the manual for the PC you are using.
