Question about HP OfficeJet 6110 All-In-One InkJet Printer
Clean scanning bed glass INSIDE
After a couple years use the inside of the scanning glass is gucky from off-gassing from the plastics but I see no easy way to disassemble or otherwise get to the "inside" of the glass....
  • mccgsm Aug 31, 2008
    Thanks, Rakeshpramod; I pretty much figured this out--the All in Ones are designed so you CANNOT clean the glass internally, which is an absolutely STUPID design by HP and the LAST HP scanner I'll buy--no excuse for such planned obselescence and enforced use of factory techs. But at least you were helpful!
There are 5 scress on the flat bed around the glass and you will have to pop the control panal facia off then to reveil the touch pad circutary panel, you have to unhoo kthe clip at the bottom of the circutary panel in order to slide to the left and left off the unit (there is a thin ribbon cable behind it you can just arefully pull it off and resertion during the reassemble later. Once you did all that...there will be two clips on the left and right near the corner of the top flat bed glass assembly which you have to unclip then you will be able to lift the whole piece out of the unit and take your time to clean the glass all you wanted. There is also cabling on the back for the document feeder so just be careful with it. Whole thing is pretty durable even the cabling as long as you take your time and do it slowly, it will be just fine. Funny cas I just did the cleaning two hours ago and saw this postiong so I know it will work...cheer.
Posted on Sep 03, 2008
  • 234 Answers
Untill Unless it is Hp iam affraid we have anybody who can fix this issue.
Because it also has the machanisum involved in it the allignment of the carriage is a main problem her as it is all machine made even if you are able to open the glass it is not possibel to reassemble the carriage.
In future you may not be able to print even.
It is better to call HP and get the All-In-One Replaced
Good Luck
Posted on Aug 31, 2008
The scanner glass inside is cloudy
I recommend you do not take off the glass. I have done it and was never able to get rid of the dust, which really shows up on every scan. The fogging has something to do with an optical coating on the underside of the glass. If I knew then what I know now, I would let it be. If the fogging doesn't show up in scans, leave it. If it really does show up, the glass itself is often held down by simple double stick tape. You try to keep the tape intact so you can put it back down. It may be strong enough that the plastic frame on top of it could snap. Do it in as clean (not dusty) environment as possible so dust does not drift down inside the scanner. Never touch the lamp or move the scan mechanism. Again, don't do it unless it's showing up on scan results. Sadly, nobody "fixes" scanners, they are disposable, like coffee pots, even if they cost 300.00.
Mar 12, 2014 | Epson Perfection 1650 Photo Flatbed...
Vertical streaks only when scanning on glass
Clean flat bed glass inside..(you need to open adf unit)
Jul 31, 2012 | HP Officejet 6500 Wireless All-in-One...
Hp officejet 7410 will not fax or scan
Needs little bit technical skill level to do this activity:Open adf unit, remove flat bed glass, take out CCD unit, open bonnet of CCD, clean reflcted gasses with smooth cotton cloth or ear buds(no solvents requited) fix it back, clean glass both side, fix back all, try it..best of luck..Pl see the snaps for help:
Feb 04, 2012 | HP OfficeJet Office Equipment & Supplies
Scanner grinds when powers on
Its not drivers issue, hard ware issue.. Scanner assm faulty,replace it..For tech guys:Open flat bed glass, remove scanner assm clean inside reflector glass with ear buds & adf glass especially at home position.. lubricate on rail refix it back.. check it..
Dec 22, 2011 | HP Photosmart C4580 All-in-One InkJet...
Vertical line appears in scans using the ADF, but not with copies
happened to me after i fed a page with not-too-hard whiteout on it. the feeder makes the page run through a different piece of glass and i just had to clean it.
Aug 18, 2009 | Brother MFC 7840W Printer
HP Scanjet 4570c/5500c producing dark, blotchy, almost black scans. Has worked fine for years on XP. Reinstalled drivers/downloaded and updated drivers/rebooted/unplugged/replugged USB and power--same time...
Is the glass clean?
Often the plastic will out gas and it will deposit a film on the glass. You might have to open it up and clean the inside of the glass with window cleaner. There is also a mirror in the scanner head. That can get fogged up too (in fact it gets fogged up more frequently than the glass plate). The trick there is to find the mirror below the slot and then clean it with a q-tip that has been dipped in alcohol.
Jul 17, 2009 | HP Office Equipment & Supplies
How do I clean the INSIDE glass/platen?
You mean the inside of the scanner glass? (The platten is a part of the print unit),
You'll have to remove the sides and read cover. Unplug the scanner wires and remove the scanner assembly. Separate the document feeder from the scanner bed. Open the covers of the scanner bed (usually there are screws holding it together). Remove the glass and clean it. Reverse the process to reassemble.
Be careful. Canon multipasses are built a little like a Chinese puzzle box. There are little snaps everywhere as well as screws. Watch out you don't force anything and cause the snaps to break.
Nov 05, 2008 | Canon PIXMA MP830 All-In-One InkJet...
I have a CanoScan Lide 90 and the scanner bed is jamed and yes it is unlocked
had the same problem. take off the two framing pieces of plastic that run along the edges of the glass (they are stuck on with glue so use a knife). prize the glass out of the unit and check that you can move the scanning moving part up and down. remove any bits of plastic. test the moving parts by replacing the glass and scanning. mine seems to work fine now, fingers crossed. x
Oct 07, 2008 | Canon CanoScan LiDE 90 Flatbed Scanner
Cleaning the scanning glass
Hard to get a smudge inside but basically you take it apart and clean the inside of the glass
Aug 31, 2008 | HP Photosmart 2610 All-In-One InkJet...
Cleaning the Flatbed Glass
We cannot clean inside the flatbed scanner glass, it is not a removable part.
Jun 06, 2008 | HP Photosmart C6100 All-In-One Printer
HP OfficeJet 6110 All-In-One InkJet Printer Logo
94 people viewed this question
Seeker5211
Seeker5211
