Question about Hoover Vacuums
Started making a loud noise - Hoover Vacuums
  • dekri Nov 18, 2008
    A loud noise when started. Hoover S2105
    President:
  • 1,673 Answers
Wish you had included your model number, could have a clog in the hose or inlet by the brush roll. Sometimes a bad belt will be noisey as well as a bad brush roll. The motor fan may causing the noise, or motor bearings.
Posted on Sep 01, 2008
Loud noise coming from cyclonic cap
sounds like you'v lost a rubber seal check this diagram on the link below see if you can see anything missing
http://www.vacpartswarehouse.com/Dyson-DC24-Upright-s/3888.htm
Apr 01, 2013 | Dyson Ball DC24 Bagless Upright Vacuum
Dyson DC17 making loud noise
Hi Liz,
I'm sorry to hear that you're concerned about the noise your DC17 is making. It will be difficult for us to help without hearing the noise, so it's probably best if you get in touch with us directly. One of our Helpline experts will be able to determine the cause of the issue, and will be able to recommend the best course of action.
You can call us free on 1866MYDYSON, or email askdysonUS@dyson.com. We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Oct 27, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson makes loud noise
Could be damage to Fan within motor or shaft on motor..Remove brush roll and run with nothing connected to motor ,if noise still appparent then sounds like one or the other if ok then check for damage to the brush roller.../Housing..good luck
Mar 31, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Loud 'drilling' noise from motor area when turned on.
Sounds like bad bushings/bearings in the motor -- need to replace them.
May 27, 2009 | Electrolux Vacuums
Hoover started to make loud noise
It sounds like a bad motor. Take it to a local vac shop and they should be able to order the motor for you.
Apr 13, 2009 | Vacuums
Hi folks, my beam vacuum makes a very loud roaring noise quite often. the problem started when i was vacuuming up a quantity of vermiculite from my chimney. i think i overloaded the vacuum i think and...
If the filter bag is bad and didn't trap all of the dust, then it got into your motor, so you may have a problem with your motor now.
Apr 20, 2008 | Vacuums
Vacuum is making a loud noise
Is the smell rubber or electrical. If rubber then the belt is slipping and needs to be replaced, they stretch after awhile. Also is the brush roll turning freely, or is it bound up, it may have to be replaced. If the smell is electrical, then probably the motor is going bad and will have to be replaced.
Dec 03, 2007 | Kenmore 35622 Upright Vacuum
Brush bar does not turn & makes a loud noise
Hi.
You either need A new clutch or clutch belts need replacing.
Its a lot to describe so try this it has manuals on how to do the job.
http://dysonmanuals.inc.io/
Oct 14, 2007 | Dyson DC07 Animal Bagless Upright Cyclonic...
Eureka 5849A Boss bagless upright
remove belt to brush roll and see if noise persists. if it stops, you probably need a brush roll. at least doing this will narrow down the fault area
Mar 26, 2007 | Eureka 5849A Boss Bagless Upright Cyclonic...
Vacuums Logo
145 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
