Question about Saws
Tile Saw How to remove blade from Plasplug wet/tile saw
  • 29 Answers
I know blades on tile saws don't have to be super tight, i'm not familar with that kind of saw, i put a wrench on the nut and hold on to the blade with my hand and hit the wrench with a rubber mallet, and of course have the unit unplugged
Posted on Mar 26, 2009
Looking for the blade guard arm.
Search Results
    7" Job Site Tile Saw with Laser - RIDGID Professional Tools
    https://www.ridgid.com/us/en/7-inch-wet-tile-saw-with-laser
    Ridgid7" Job Site Tile Saw with Laser. ... Heavy Duty Arm - prevents flexing while keeping the blade aligned; Guard Baffle - reduces air turbulence to help keep water ...
    [PDF]7" BRIDGE TILE SAW
    manuals.harborfreight.com/manuals/97000-97999/97360.pdf
    7" BRIDGE. TILE SAW. WITH STAND. Owner's Manual & Safety Instructions. Save This Manual .... that has an outlet that looks like the one illustrated above ... Use saw-blade guard and spreader for every .... arms and shoulders. To reduce the.
    [PDF]10" INDUSTRIAL TILE/BRICK SAW Owner's Manual ...
    manuals.harborfreight.com/manuals/69000-69999/69275.pdf
    parts. Nonslip footwear is recommended. Wear protective hair covering to contain long hair. 11. ALWAYS USE ... an outlet that looks like the one illustrated above in Figure A:... For Your Own Safety Read Instruction Manual Before Operating Saw. 1. Wear eye ..... Connect the clear water Hose from under the arm of the Motor ...
    SKIL 7" Wet Tile Saw 3540
Dec 16, 2015 | Blade Saws
Rigid tile saw. Can I use a wood blade?
Tile saws are designed to use a diamond blade, and to keep it wet. That's not something you want with a wood blade, nor with wood. The speed of a tile saw is much slower than a good wood saw. I wouldn't try it.
May 27, 2015 | Blade Saws
Easier way to cut glass wall tile
Easier than what? I use a diamond tile saw, and find that pretty easy.
Sep 11, 2014 | Saws
The nut that holds the saw blade on is flat like a washer. I can't find a tool to remove it. i want to change the saw blade.
Some of those nuts had 2 holes in them and there is a special tool that fits in the holes and you turn the tool to unloosen it.
Mar 16, 2011 | Wet International Q.E.P 4 inch Portable...
Looking for shaft lock to change the blade on MK 170 wet saw
Just use a rag and grab the blade. Unless the threads are messed up you don't have to hold the arbor still, just the blade.
Apr 27, 2010 | Mk Diamond MK - 170 Wet Cutting Tile Saw
How do you remove the blade on tile cutter model mk470 mk diamond products, inc
Unplug the saw, raise the guard fully, grasp the blade to hold it and loosen the nut then remove the blade.
Sep 12, 2009 | Mk Diamond Products, Inc. 7 In. Wet...
Crooked cuts
The bearings in your saw need to be replaced. I would contact a DeWalt store to obtain the parts or have them do the repair. You have an excellent saw there, well worth repairing. good luck.
Jan 04, 2009 | Dewalt Heavy - Duty 10" Wet Tile Saw -...
How to use Tile Saw
To cut a tile using a wet tile saw, measure the exact space in which the tile will fit. Cuts are usually along a perimeter, in a corner, or around an electrical outlet. Mark the line on the full-sized tile in grease pencil. Most saws will accommodate tiles up to 12 inches (30 cm) in size, but oversized saws can be rented for huge floor tiles. Wearing safety glasses, place the tile on the moveable platform, and line up the mark with the edge of the saw. With the motor running, slide the platform toward the blade with an even but gentle pressure. Since you are grinding the tile apart, ensure that the water have sufficient time to cool everything.
Aug 27, 2008 | Dewalt DW8308 60-Grit. 4 1/2" Blue...
Tile Saws question
Since tiles are so thick, brittle, and made of ceramic, a special saw must be used. An ordinary circular saw for wood or metal would either break the tile or get so hot that it would seize up and stop cutting. However, ceramic tile is not cut well with sharp blades. The wet tile saw was invented to address all these unique properties of ceramic. It doesn't overheat, uses a relatively dull blade with no serrations, and can be transported to a job site and set up on top of an existing table or sawhorses.
Aug 27, 2008 | Dewalt DW8306 36-Grit. 4-1/2" Blue...
Saws Logo
716 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
