Question about Hotpoint Refrigerators
Ice maker will not stop making ice. It keeps on coming after the bar is raised. What will fix it ?
  • Anonymous Mar 18, 2014
    stop making ice
  • 62 Answers
Can you raise the bar and detent it it into the off position? Will it stay there? Does the unit continue to make ice even when the bar is in the off position? If it does then there is something wrong with the icemaker. Also, you may want to check that the bar is in the proper location, meaning that the bar is inserted in the head assembly and the other end is supported if that is the type you have.
Posted on Aug 31, 2008
What can I do to fix my ice maker? My ice maker 12685003 in my Amana refrigerator keeps dispensing water and has a huge peak of ice in the tray. It works fine for awhile making regular cubes then it looks...
Most likely your Ice maker inlet valve is not closing properly and seeping water continuously.
This will lead to frozen ice layer on tray or surrounding area in the freezer. Also this water leak from valve will freeze the water line and stop making ice.
Your inlet water valve need to be changed for your fridge. Amana is made by Whirlpool Corporation. Check with your mode number.
If in USA
In Canada
Hey there are lot of other parts sellers too. Just two of them above
Oct 24, 2017 | Refrigerators
What to do if your ice maker stops working
Many refrigerators now come with built-in ice makers. Ice makers are very convenient, but occasionally they'll develop problems. Why pay a repairman to come out if the fix is easy and you can do it yourself?
Here are some tips for fixing an ice maker that stopped working.
- Check the on/off switch
Freezers with automatic ice makers have a switch that is used to turn the ice-making feature on or off. This switch is typically a rod above the ice box; when it's lowered, the ice maker is on, and when it's raised the ice maker is off. If the ice box fills up with ice, the ice can force the rod up, turning off the ice maker. Check this bar to be sure it is in the lowered position.
- Check if the auger or chute is clogged
Your ice maker has a chute where the ice falls from the freezer into the external tray (where a glass is placed). There is also an auger inside the freezer that rotates to drive the ice forward from the ice box into the chute. Check the chute for large chunks of ice that may be clogging it up, and check the auger for ice cubes or chunks that might have gotten wedged between the auger and the freezer, causing the auger to be unable to rotate.
- Check the water line
If you still haven't found the problem, check the water line leading into the freezer. This water line has its own valve. Make sure the valve is open, allowing water into the freezer to create the ice.
on Jan 23, 2011 | Refrigerators
Whirlpool ice maker start cycle then stops
The problem is the ice maker, the modular head of the ice maker has broken, hence the clicking sound and the raised arm stuck up. You will need to have an accurate model number and contact a local parts distributor for a new ice maker. It is a simple repair usually only 2-3 screws.
Apr 25, 2012 | Whirlpool GS6NBEXR Side by Side...
KUIC15PLTS ice maker keeps making Ice even though it is FULL
The high level sensor can get iced up and stop working. using a hare dryer carefully heat the area that the lensing arm goes into or snap off the front cover of the ice maker and blow warm air in there. raise and loser the arm at the same time. a couple of minutes should do it.
Apr 19, 2011 | Kitchenaid KUIC15PLTS 15 Inch Wide 25lb...
Icemaker clogs with ice. Water flows with icemaker unplugged.
ur solenoid could be allowing water to flow freely its in the back its blue try replacing this solenoid and see if this fixes the problem they r cheap and easy to change
Feb 27, 2010 | Amana ARSE67RBB / ARSE67RBW / ARSE67RBC...
Ice maker will not stop sending ice out of door
If your refrigerator has a wire bar that raises and lowers as ice cubes are ejected. Make sure the bar is not trapped or frozen in the down position. This will cause the ice maker to continuously make ice.
Usually pulling the wire bar all the way up the ice maker will stop.
If not, you may have a bad switch and will need this replaced.
Oct 18, 2009 | KitchenAid Refrigerators
Ice maker is overflowing
Older icemakers have a bar that drops from above your ice bin; once the bin is full the bar is raised and trips turning the ice maker off so that it won't dump. If your's is this style, try manually pushing the free end of the bar upward so that it locks in the upward position. Newer ice makers with the ice bin in the door have a small panel that moves to the open position when the door opens and closes when the door closes. Mine also includes an optical sensor that is visible when this panel is in the closed position. Try placing a non-clear tape over the optical sensor (don't know if that will work or not but worth a shot). If effective in stopping the ice flow then call a repairman. If none of this works, turn off the water supply coming out of the wall to your freezer.
Sep 08, 2009 | Kenmore Freezers
Crosley side by side ice maker makes to much ice !!!!!!
Most ice makers have a wire bar that senses when the ice bucket is full. The bar lifts up when new ice is made. The ice maker determines if the ice bucket is full by lowering the bar back down after the ice drops into the bucket. If the bar hits the ice cubes in a full bucket, the ice maker shuts off. If the bar drops all the way and dosen't touch ice cube, the ice maker continues making ice until the bucket is full.
So you likely have one of the following problems:
1) The wire bar is missing or bent. Check to make sure that when the bar is pushed up, the ice maker stops making ice. Most bars will 'click' into the up position so you can shut the ice maker off. Push the bar up until it clicks into the up position and wait overnight to see if it makes more ice. If there is no wire bar over the ice bucket, that is your problem.
2) The switch the wire bar is connected to is malfunctioning. If you push the wire bar up and the ice maker continues to make ice, this is likely your problem. You will need a new ice maker unit. Try Appliance Parts Pros or EBay for a new unit.
Jan 07, 2009 | Hotpoint HSS25GFP Side by Side...
Ice maker won't stop making ice
it's time to replace the ice maker, it will not stop, the you can feel the small bar when it looks in to the of position.
Dec 10, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
OK, there's two possible issues but you have to figure out what is happening. Does the ice maker continue to make ice forever and would fill up the whole freezer section in time OR does the ice maker just "over make" ice that overfills the bin which then falls out? If the ice maker just keeps making ice you need the motor module replaced but if it can be turned off by moving the lever up then you need the "modified lever assy." that is on our service bulletins.
Dec 23, 2006 | Kenmore 55693 Side by Side Refrigerator
Refrigerators Logo
76 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
