Question about Haier HDN655E Dehumidifier
Model HDN455 Unit des not remove any moisture
    President:
  • 2,712 Answers
Check the coils at the back of the dehumidifier to see if there is any frost buildup on it. If there is, turn off the machine for a while until the room warms up and melts off the frost. The machine works by condensing the moisture in the air over these coils, so if the coils are frosted over, or are not cold enough, the moisture cannot condense. If the coils are not cold enough, you may want to get it refilled with refrigerant. You will need to take it in for servicing in this case.
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Sep 29, 2008
Haier model hdn455 serial number 05021110 it runs but has never taken a drop of water out of the air, so it just keeps running
The problem, may very well be, that the humidity extraction level is set too high. Lower it to 35% and see what happens. Keep in mind, the lower the percentage of the moisture/humidity setting, the more it extracts from the household air. The higher the setting, the less it extracts from the household air.
Also, remove and check the air intake filter to see if that needs to be cleaned. It should be cleaned at least twice a week during the operating season.
Hope this helped you troubleshoot and solve the problem. Please let me know. Thanks.
Jun 06, 2011 | Haier HDN455 Dehumidifier
The coil in the back of the my Hairer HDN455 is freezing up.
dehumidifiers work by cooling down so that warm moist air will condense has it stopped working ?
May 30, 2011 | Haier HDN455 Dehumidifier
How do you hook up drain hose to model HDN455 RB
Remove the bucket and remove the plastic cap on the bottom of the bucket. Then take the rubber insert out of the cap and save it. You will use it later. Using the hose that came with the unit, thread it through the cap opening and add the washer to the cap. Screw the cap to the mating connector on the bucket. Be sure to use the washer or the connection will leak. Now, thread the hose through the round hole and extend the hose to the back of the unit. And finally, replace the bucket in it's original position in the unit.
Hope this helped you. Please let me know. Thanks.
May 27, 2011 | Haier HDN455 Dehumidifier
HDN455 worked fine last fall. Turned off for winter. Started this week. Sounds and runs fine but not a drop of water condenses. Coils are not frosted over. Unit is warm along bottom. Air discharge is at...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Feb 19, 2011 | Haier HDN455 Dehumidifier
No lights or sound...changed outlets just stopped running, is there a fuse that could be blown?? or ???
There are many reasons for a dehumidifier tto not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Apr 13, 2010 | Haier HDN455 Dehumidifier
"running" light on but motor doesn't engage
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
heatman101
Jun 24, 2009 | Haier HDN455 Dehumidifier
The compressor does not seem to start or kick in.
need help to set date/month/year/ and time on my polaroid i830 digital camera
Apr 05, 2009 | Haier HDN455 45 Pint Dehumidifier...
Haier hdn455 45 pint overflows
Float switch is stuck, has a broken spring or the actuator arm is bent
Aug 19, 2008 | Haier HDN455 45 Pint Dehumidifier...
Haier HDN655E Dehumidifier Logo
108 people viewed this question
Top Haier Dehumidifiers Experts
Steve
Bill Long
Mike Squire
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
