Question about Whirlpool Duet GHW9150P Front Load Washer
Won't drain I unplugged the machine for 30 minutes, and then plugged it back in. I set it to spin and drain, and it just makes a low humming noise, but does not spin or drain. I think the drain may be clogged - perhaps by baby clothes. How do I check the drain? PS Eventually, if left on for a while, the error code will come up as "SUDS", but will not clear. There are no suds in the machine and we use the HD detergent.
  • 1 more comment
  • mlewisct Sep 01, 2008
    Worked like a charm. There was a baby sock in the drain pump. Thank you!
  • wepartyhardy Sep 01, 2008
    After 21 minutes of cycle, washer blinks F 02. Checked all drain pipes and took snake to house drain. Still won't finish cycle. HELP!!
  • momart Sep 01, 2008
    I have the same problem! Where is the drain pump, and how do I check it?
    momart
I had the same problem. Wouldn't drain, wouldn't spin. Took the three screws out on the bottom panel, unscrewed the port on the pump, cleaned it out...just a nail and some change...cleaned it up, put it back together and it works great! Easy enough even for a novice.
Thanks a bunch.
Posted on Sep 21, 2008
I followed "oldfixer"'s solution and cleaned out the hose to the pump and now it works great!! I found 3 golf tees, coins, 6 dental burrs, and earring and misc. fluff. Thanks!!!!
Posted on Sep 01, 2008
    Genius:
  • 1,028 Answers
Dip as much water as possible from tub..remove bottom panel remove clean out port on pump clean and reinstall
Whirlpool washer WTW5700X. When attempting to do a load washer will start to spin then stops and makes loud hum noise and the only way to stop it is to unplug washer.
Does it run after plugging back in? Does it drain properly? It may be a bad or clogged pump.sometimes stuff like baby socks can jam it up.
Mar 27, 2016 | Whirlpool Washing Machines
Kenmore 110.42822 won't spin
This should take 30 minutes: Remove the panel that is located below the front door, there are 3 small screws located at the bottom that hold this... you will see the water pump, which has a access screw plug. Unscrew this, its like a filter, you may see stuff, like coins, socks, etc, remove and clean out, then put everything back... this should fix the issue.
Mar 31, 2013 | Kenmore Washing Machines
Crosley 5000 front load washer won't spin
Hello - Does the drain pump make a humming noise? If so, you possibly have a restriction in the drain line or siphoning. Try setting the cycle to spin only and verify if water pumps out. If it does not, the unit could possibly be experiencing an issue with either the pump, door lock assembly or timer. Contact a professional to move forward accurately.
Nov 24, 2012 | Crosley Washing Machines
Frigidaire washer won't drain or spin
Hello - Does the drain pump make a humming noise? If so, you possibly have a restriction in the drain line or siphoning. Try setting the cycle to spin only and verify if water pumps out. Supposing that it does not, I would suggest contacting a professional to move forward accurately. The unit could possibly have a faulty pump, timer, or door lid (if it is a laundry center).
Oct 11, 2012 | Frigidaire Washing Machines
Frigidaire affinity front load washer
If the unit will not spin at all and makes a humming noise, sounds like something has seized up in the back of the unit. This could be a belt broken, motor seized up, or the transmission, if your unit has one, is gone.
Jul 17, 2012 | Frigidaire ATF6000ES Front Load Washer
Machine had been giving E20 error code - filter cleared and it re-started ok. When wash was in progress - jammed at rinse stage and all lights came on (except spin speeds) and humming noise and nothing...
E20 is an error code for drainage failure.
Check where the appliance drain hose connects to the house drains for a blockage.
If it's onto a spigot under the sink, take them off and check both for a blockage.
If these are ok then it's likely to be a blockage in the pump.
You'll need to drain the water out manually.
Put a shallow dish below the filter and slacken the filter.
Tighten it to stop the flow of water while you empty the dish.
Once empty, take the filter out, clean out the debris and ensure nothing is left jamming the pump.
Before refitting the filter, put the machine on drain or spin and listen at the filter housing to see if you can hear the pump running.
If you do, fit the filter and try the machine again.
Thanks for using FixYa
Oct 11, 2011 | Zanussi ZWD1470W Front Load Washer / Dryer
WASHER MAKES A HUMMING NOISE IN SPIN CYCLE BUT DOESN"T SPIN & CLOTHES ARE SOPPING WET.
what's the brand name and model number,all washers are different,most likely it's the motor humming or the pump is humming,could have something stuck in pump,if the water doesn't drain the washer won't spin,if you have a shop vac pull the drain hose out of stand pipe or sink,stick the shop vac hose onto the drain hose,get it down as low as you can and suck out the water and then see if it spins,if there's alot of water in the tub suck it out of the tub first then go to the drain hose,if it spins when water is out you know it's the pump but if you say water is still in tub i would have to say it is the pump,
Dec 25, 2017 | Washing Machines
Flashing F2
“F02” (Drain Problem)
Select PAUSE/CANCEL twice to cancel the cycle. Unplug
washer or disconnect power.
Check the following:
Is the drain hose kinked?
Is the drain hose frozen?
Is the drain hose clogged?
Is the drain hose more than 96" (2.4 m) above the floor?
After running this check list, plug back up and try a complete cycle using cold water and no detergent. Sudding can mimic a drainage issue as well. make sure you are using the correct HE detergent to prevent over sudding.
Feb 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
65 people viewed this question
Dan Webster
Dan Webster
Sal De
