Question about Video Game Consoles & Games
Leapster not powering on
We have a leapster that my daughter has only had a couple months and it will not power on anymore. Nothing has happened to this game system and have tried new batteries, although we've been using the rechargeable batteries. HELP??
  • 1 more comment
  • Anonymous Nov 23, 2008
    I have the same problem, My daughter just got it today and all I had was rechargeable batteries. She used it for about 30 mins and not it will do nothing!! I have tried to clean the the contacts and put new nonrechargeable batteries in and it still wont work. Have to wait until monday to contact customer service!!
  • menkefh Nov 30, 2008
    Leapster L-Max that will power on and works perfectly fine when using the AC adapter, but will not work with new batteries in the battery pack that came with the unit or the rechargable battery pack accessory. Worked fine for about a year now this issue.
  • Anonymous Dec 08, 2008
    my daughters game worked fine for a couple months and the same thing happened . . . new batteries do not solve the problem.
    Problem Solver:
  • 13 Answers
I have never used the Leapster before, But I researched it a bit and discovered that it uses "AA" Batteries. Were the rechargeable batteries you used before designed for the Leapster or were they older Ni-Cad (Nickel Cadmium) style batteries? Older Ni-Cads put out a slightly higher voltage than standard (1.7v) as opposed to the standard 1.5v. This could possibly cause problems. If you have only had it for a few months than it should be warranty protected. Hope this helps. Cheers!
Posted on Aug 21, 2009
When clicking on leapster cartridge in Leapster 2, Leapster reboots itself. There were possibility of dirty cartridges-how does one clean the cartridges if they're in tiny slots?
If the cartridges can be removed, pull them out and try spraying an electronic contact cleaner, power off, and make sure it is safe for plastics, onto the cartridge pins. Then, Gently, slide the cartridge in and out of the socket several times to clean both the socket and cartridge. May have to do this a couple of times.
Jan 01, 2014 | Leapster 2
Leapster 2 screen not working
Hi
This is a common problem for Leapster. The company has a repair program. Charges depend on warranty.
May 11, 2010 | Leapster Learning System
The touch screen on my Daughters Leapster 2 has stopped working. What can I do about it. The Leapster is 16 months old
Hello
You might want to call this number call 1-800-701-5327. to get technical support for your leapster.
Thank you
May 02, 2010 | LeapFrog Leapster 2 Learning System
the screen maybe dirty try turing it off and cleaning it with a rag
Mar 18, 2010 | Leapster Learning System
My daughter has a Leapster 2 that is only about 2 months old and the touch screen does not work
Answer
I had the same problem and here is the answer I found at leapfrog.com which fixed my daughter’s disney princess leapster 2’s problem. Good luck!
If your Leapster2 does not respond to the stylus pen, it needs to be calibrated. Calibrating the Leapster2 is easy:
1) Ensure that a cartridge is not inserted
2) Hold down the Hint (?) button while turning the unit on. Continue to hold the Hint button down until the LEAPSTER menu appears.
3) When the LEAPSTER menu screen appears, press the A button
4) Touch each of the crosshairs that appear with the stylus
5) Restart unit
Jan 30, 2010 | LeapFrog Leapster Learning Game System
My Leapster 2 comes on, shows the name on screen & ask to touch my name w/ the pen; however when I touch the name, nothing happens. It keeps asking to touch a name or "guest".
Answer
5) Restart unit
Jul 28, 2009 | LeapFrog Leapster 2 Learning System
Leapster 2 unit turns on, warning msg re. seizures and flashing lights stays for a few seconds then shuts off. Has new batteries. my daughter has the same problem with hers it turns on and brings up an...
We have 3 Leapsters. The old green model and 2 newer models. Our green one started doing that not long after having it. But it still works and if it shuts off, then we just turn it back on again. When I called up c/s for Leapster, they sort of make it difficult to return. And then I was not promised a new one, but it could be new or refurbished. I let it go. Now w/ the 2 new models, I believe this has happened. I've questioned if my kid's are accidentally hitting the power button. I have seen the green one power off before. I purchased the $10 plug in's. So worth it. No more batteries. And we haven't had any issues. So perhaps it is the batteries. Call up Leapster though and see what they have to say. Good luck! :)
May 26, 2009 | LeapFrog Leapster 2 Learning System
Leapfrog Leapster
I've tried the Home and A button several places... and it seems to work for others but not me :( I was about to give up then I found another way to reset the screen - Hope it works for you!
1. Unit must be OFF and NO cartridge
2. Hold down the HINT (?) button while turning the unit on
3. When Leapster menu screen appears, press the A button
4. Touch each of the cross hairs that appear with the stylus
5. Restart unit
Dec 01, 2008 | LeapFrog LeapSter L-Max Console
The pen won't work on my daughter's leapster
1) Ensure that a cartridge is not inserted 2) Hold down the Hint (?) button while turning the unit on. Continue to hold the Hint button down until the LEAPSTER menu appears. 3) When the LEAPSTER menu screen appears, press the A button 4) Touch each of the crosshairs that appear with the stylus 5) Restart unit
Nov 10, 2008 | LeapFrog Leapster Electronic Book:...
Leapster with broken pen
My daughter did the same thing to the tip of her Leapster 2 stylus. I called Leap Frog at 1-800-701-5327 and was able to order a replacement stylus directly from them on credit card for $5.00 shipped.
I also took her old stylus and sanded the broken tip down with 100 grit and then 220 grit sandpaper to get rid of the sharp, cracked point and it works just fine. I figure I'll keep the sanded one as a spare in case she does something silly with it again.
Jul 27, 2008 | LeapFrog Leapster Electronic Book:...
Video Game Consoles & Games Logo
230 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
