Question about Kyocera FS-3900DN Laser Printer
Error code 150:0000001
How does one clear or fix this error? I cannot access any of the menu, it seems to lock that up when showing the error... ?? your thoughts would be appreciated... I did install the software, I thought from your response this was a bios upgrade for the printer, not a network monitoring software.
Thanks Greg
    Problem Solver:
  • 14 Answers
You need to upgrade the firmware of the printer
Posted on Sep 16, 2008
    Genius:
  • 3,422 Answers
I don't have much experience with your model.I suggest you to contact other experts regarding this issue.
Posted on Aug 31, 2008
Canon iR6800C printer error code E000002-0001 pls fix this error code on photo coppier machin
Hi. You have to clear that error from service mode
Try to clear that error from service mode
press additional function
2 and 8 together
select copier
select function
select clear
select ERR
select ok. Unplug of the machine for 5 second and then turn it back on
try to make some copies, if problem persists fixing heater is damaged and need to be replaced
Mar 28, 2015 | Canon Office Equipment & Supplies
Reset Error codes
E000001-0002 refers to the fuser assy either getting to hot or not hot enough. Fuser error codes cannot be reset by power cycling the machine even though that is what the display tells you to do. In order to reset the fuser error code you must enter the service mode & reset the code. To enter the service mode:
press"Additional Functions" button (looks like a picture of a head with a star inside)
press the #2 and #8 at the same time (simultaneousley)
press "additional functions" again
The display should show a choice of
copier,feeder,sorter,fax,or board service modes
Select copier
select clear
select ERR
press OK
Turn power off & back on.
After clearing error stay at the machine to see if it comes to ready. The fuser assy can reach 139 degrees C.(Water boils @ 100C) The error can only be cleared through the service mode because a technician should inspect the fuser to verify there is nothing faulty that could possibly start a fire. If you enter the service mode & clear the error, power cycle the machine & during warm up the machine throws a code again- turn it off, unplug it & call a tech for fuser repair.
Jul 02, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Workcentre 7242, it was showing 01-333 fault at first but after correction another error 010-319 how can i sort out this error code
Error 010-333 for this machine is "Fuser Center Thermistor Overtemp (Over temperature) or Overheat Error"
Error 010-319 for this machine doesn't seem to exist (Yes - I know you've got it - hence the problem post.)
Error 010-319 for other Workstation models (7655, 7665, 7675, 7755, 7765, 7775) is "Fuser Heat Control problem *NOTE: This code must be cleared from Diagnostic Mode"
As regards fixing this error the Xerox website should be helpful
Feb 16, 2014 | Xerox Office Equipment & Supplies
I have a Kenmore Elite Washer for over a year and is getting a F35 error code, then the SuD flashing. Cleaned out the soap container & inspected the inside (as stated on page 21 of "Washer...
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa!!
Nov 12, 2010 | Kenmore Elite 45986 Front Load Washer
I have an error code OP what should i do
You could have a lid magnet out of position. Quick check for that is to place a magnet over the left bumper with the lid raised and see if the OP error code clears.
If it does you need to remove the inner panel of the lid to access the lid magnet see page 32 of the Service Manual for the procedure.
If the external magnet doesn’t clear the OP error code you will have to start troubleshooting the Left Hand Lid Lock. You could have severe corrosion with and an open lead on the magnetic reed switch in the Left Hand Lid lock. Link to replacement Left Hand Lid Lock
See this post Left Hand Lid Lock Troubleshooting for further info. I discuss troubleshooting the OD error code but you troubleshoot the OP error code the same way……Rich
Jun 11, 2010 | Maytag Neptune FAV6800AW Top Load Washer
E004
This is fixing error, probably bad thermistor. You should check the termistors, lamp, termoswitch.
But first try to clear the error in service mode
MENU i #
Clear
Err
OK
Turn off/on
But you have temperature issue in fixing section
May 31, 2010 | Canon imageRUNNER 2000 Copier
System error E000 how do I fix it. I tried what it said in the instructions to turn it off for a while then turn it back on that didn't help. Canon NP6025 copy machine.
To delay the 3 second shut down and enable the technician to access service mode; open the front door and pull out the transport unit. Do not actuate front door microswitch. Press the service mode button, enter " * 4 * ", scroll to error clear and clear error code. Machine will automatically turn off power after clear. Power up machine and test.
If the power shuts down after error code has been cleared, the cause of the error has not been corrected. Correct cause of error code and clear error in service mode.
May 07, 2009 | Canon Office Equipment & Supplies
Reset error codes for Canon imageRUNNER 3300i
We followed the instructions from your tech. on which buttons to press to get into the menu function and then followed the directions for clearing the error code. After that turned the printer off and back on and the error code reset and the printer worked like a champ.
Kyocera FS-3900DN Laser Printer Logo
149 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
