Question about U-Line Icemaker
Bin Arm The bin arm in my U-line icemaker came out. How do I put it back in?
  • KCMizzoufan Jan 03, 2009
    Mine is out as well. Seems like it should be a simple fix for a reasonably handy home owner. The wire bin arm does not look bent or broken. Where can I find drawings to put it back or find parts?
    Problem Solver:
  • 11 Answers
It probably broken, these do not normally just come out. Please go to www.u-lineservice.com and click on the parts distributor search engine. These parts are available and this icemaker can be repaired. It's a little tricky to replace, but it can be done. Make sure to cut the power when working inside this icemaker.
Posted on Dec 23, 2008
The ice maker stopped making ice one day
A typical problem with these is some type of bin sensor that tells the icemaker that the bin is full. it is usually some type of "arm" that shuts it off when the ice rises to a level that raises the "arm" to "kill" the icemaker
Oct 01, 2012 | Refrigerators
Need to know how to turn on ice maker in whirlpool gz25fsrxyy2
Should be a wire feeler arm that runs front to back on that icemaker. If it is stuck in the up position---the icemaker is OFF. It should be hanging downward to be in the ON position. If up---just gentley pull it down until it is moving freely. As the ice bin fill with cubes that arm should move up and down with the icemaker. Once the cube level is high enough for the feeler arm to be held in the up position it will stop making ice until you use enough cubes for the arm to fall again.
Sep 26, 2012 | Whirlpool White Gold 25 cu. ft. ENERGY...
THe icemaker in our Kenmore side-by-side, model 106.57362702 is not working. The arm will not go into an upright position, but, rather, is in the down position.
if the bin arm will not go in the up pos . the i would belive the head has broken dirve parts inside / i would replace the icemaker . . mm hope this helps feed back pls and thanks for unsing fix ya ..
Sep 19, 2011 | Kenmore Refrigerators
The icemaker is not making ice as fast as it would before. It dumps a tray of ice about every 4 hours.
Make sure that there are no kinks in the water line.
Next, inspect the feeler arm of the ice maker and make sure that it is down and not blocked by any ice cubes. If it's raised, it has turned the ice maker off. This arm needs to be in the lowered position to activate the ice maker An over-abundance of ice in the bin will make the arm stay up as a safety feature to keep the ice maker from making more ice than the bin can hold.
Jul 30, 2011 | Refrigerators
I've got the LFX25960ST model. The icemaker
its the ice maker .water or condensation has built up in the ice maker modual and refroze upon turning unit back on.either get a new ice maker or uninstall the ice maker and let it dry for a few days and reinstall.but it could happen again that way.or maybe not.
Jul 24, 2009 | LG LFX25960 Bottom Freezer French Door...
The bin arm on my Uline Model 402 ice maker broke off. I have a replacement bin arm. I took off the front plate of the ice maker unit, but am unable to thread the bin arm all the way through the bin arm...
1st remove the icemaker from the unit. Then take the faceplate off.You might find that the support housing is fighting you.You should be able to move the arm into place as long as the icemaker is out.
Jul 19, 2009 | U-Line Uline Origins Series...
Ice maker overfill
The metal off/on arm may be disconnected. A full bin should keep the arm in the up position and shut off the ice maker.
Remove, then re-insert the metal arm in the back of the ice maker control head.
Make sure that a full bin of ice activates the control arm.
You may need to buy a replacement arm that is longer so that the ice catches on the arm.
May 20, 2009 | Jenn-Air JCD2295KES Stainless Steel
Ice Maker not making ice
replace the icemaker is the best solution , or possibly jst the control module
Jan 14, 2008 | Jenn-Air JCD2389G Side by Side...
U-Line Icemaker Logo
114 people viewed this question
Top U-Line Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
jasbo
jasbo
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
