Question about Olympus Cameras
When camera is powered on it initially tries to focus but fails then gives a blue screen showing: D: 5f08 5e02 Unable to leave this screen no matter what setting is selected. Camera is U700 all weather 7.1 megapixel
  • 7 more comments
  • nev scai Aug 31, 2008
    have tried swithching off,removing battery and waiting 10 mins but this has not fixed problem
  • nev scai Sep 01, 2008
    have now recharged battery overnight and replaced this am but same problem as above.Did receive 2nd email but this had same solution as original...did I miss something?
    have tried solution suggested it didn't work.
    have also taken battery out charged it over night and replaced but again same problem.as soon as battery is put back in, camera makes a wirring noise and lens extends then retracts before any button is pressed!
    TRIED SEVERAL SOLUTIONS SUGGESTED AND FINALLY TRIED HITTING CAMERA INTO PALM OF HAND JUST AS IT POWERS UP....IT WORKED.CAMERA NOW BACK ON TRACK!!
  • nev scai Sep 02, 2008
    fix was short lived i'm afraid, it did right itself for a few moments but when i powered off then back on minutes later, the blue screen menace was back again and nothing i try will get rid of it....anymore suggestions.ps bought camera 15 months ago is it still covered by warranty???
    anymore ideas please ??
    no camera working up to error message.camera has not been dropped at all but did notice when i tried to take a close up picture the day before blue screen appeared that the focus/picture was blurred.
    camera has not been dropped at all.on a close up shot the day before, picture was blurred.
    thanks, will contact repair centre in due course
  • 10,594 Answers
Camera symptoms shows Focus Motor is jammed and needs to be replaced but you need to buy complete lens assembly. If you don't know how to repair camera, please contact nearest Olympus service center for proper repair.
Regards,
Posted on Sep 02, 2008
  • 1,879 Answers
Camera having an internal error - dropped it ?
Posted on Sep 01, 2008
    Sergeant:
  • 241 Answers
CHECK THE LENS HOUSING AND MAKE SURE THERE ARE NO OBSTRCUTIONS> LOOK AT THE TROUBLE SHOOTING GIUDE IN THE BACK OF YOUR INSRTUCTION MANUAL!!! ID YOU DROP IT THAN IT COULD HAVE BROKE INTERNALLY> THEN BRING IT TO A REPAIR CENTER OR THE MANUAL 1-800 NUMBER IN THE OWNERS MANUAL > CHECK THE WARRENTY DATE AND HOW LONG IT WILL COVER IT> SOME CAMERAS HAVE A 1YEAR ON CERTAIN ISSUES GOOD LUCK AND SURE HOPE THIS FINE TECHS CAN HELP YOU TOOO
  • 2,071 Answers
If your camera is still under warranty, the best thing you can dois to take it to the nearest official Olympus repair shop and Olympus Digital Cameras shouldfix it for free.
If your camera is out of warranty, or if Olympus refuses to repairit for free (happens sometimes if for example they suspect the camera has not been treated properly) you can try some ofthe methods listed here to repair it yourself. These simple methodshave helped a lot of people fix their cameras.
Before trying any of the suggestions, make sure your Olympus Digital Cameras has fresh batteries and it is in recording mode.
1) Remove the batteries from the camera, wait for a couple of minutes,then put them back in and turn the camera on.
2) Try compressed air. With a fine tip blow off gun and drycompressed air (20 lbs) set the tip between the lens turret and thecamera body and turn on the air while moving the tip around the lens.It should remove all dust and sand. Turn the camera on and it shouldfunction fine.
3) Another method is to tap the padded USB cover part on a hard surface, for example, a desk. It sounds so simple, but veryoften in works.
4) Try forcing the camera lens:
Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix. This type of a problem usually occurs if the camera was dropped while the lens was extended.
Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a "click" as it pops back into place. Try powering the camera back on.
If the lens doesn't extend at all or it extends, and then retracts again, do the following. Turn the camera off. Take the camera in one hand and with the other gently take one part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a "click" as it pops back in place. Power the camera on.
Another version of this fix would be to pull and twist on the largest ring of the lens while turning the camera on. Listen for a "click". If at first the focus seems to be off, turn the camera on and off and take lots of pictures, close ups and distance. Focus should slowly start improving.
5) If that doesn't work, there is an online guide for dismantling Olympus Digital Cameras and fixing the E18 error. (NOTE: Try this only if your camera is no longer under warranty!)It is a great guide with pictures and it can be found here.
There are 2 other guides, one Bulgarian and one Estonian with the take apart procedure for Canon cameras.They are not in english but have a lot of pictures which help with the process.
- Bulgarian guide
- Estonian guide
Hope this may help you;
Regards,
VOTIT
  • 6,487 Answers
It's a sensor issue, unfortunately. Caused by sand or dirt in lens cover machanism. Simple fix is to turn on camera while holding it with the lens pointing UP. Get some canned air and blow it out real good. If that doesn't work, understand that the average cost of a camera repair is around $180. As such, it may cost more to repair than it is really worth.
Hope that helps..........
Posted on Aug 31, 2008
  • Mark Gil
    Mark Gil Sep 01, 2008
    Good that the problem was resolve. feel free to contact us back for any concern in the future..
    Thank you........
  • Mark Gil
    Mark Gil Sep 02, 2008
    I believe this unit only has a 12 month warranty period sorry to say its already out of warranty...
    Master:
  • 521 Answers
Hve u checked the battery
  • tech expert12 Aug 31, 2008
    take it to the repair center for better help because manual reset should help you to solve.as by removing the battery the problem did not solved.so the problem is bit major.
    problem is not permanent it will be definately solved.by the service center because he will having all the necessary things and parts in spare to replace and check one by one.
    thanks.
    please do rate the solution,
    regards,
    fixya expert team.
    Genius:
  • 1,269 Answers
Try to turn off your camera for 10 mins, please remove the battery. After 10 mins put it back in and check if it fixes it.
  • Michael Galve
    Michael Galve Sep 01, 2008
    Have you tried updating or re-flashing the firmware of your camera? What is the exact model and brand of your camera? Try to visit the manufacturer's site and check if there's any firmware available for you camera.
    If all else fail, there might be some mechanical problem on the camera itself and only the authorized camera service center can fix it.
    Genius:
  • 3,422 Answers
HI,
Please reset it by taking the battery and mem. card back out and putting them back in again after 30min.
UNABLE TO INIT 4F BROTHER DCP-195c CAN'T TO PRINT.LCD SHOW UNABLE TO INIT unable 4F. my brother printer when on the screen show unable to print. how to solve the problem ?
The printer have its own initialization but seem to fail to complete initialization process. Check and clear the carriage jam, open check for motor failure in the carriage system.
Dec 18, 2015 | Brother DCP-195C Inkjet Multifunction...
Polaroid i733 digital camera
Initially, let's try a hard reset by removing the battery. Let it be without batteries for a couple of minutes to about an hour. Thereafter re-insert battery and try again. Additionally, pls verify that the battery is fully charged
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 07, 2008 | Cameras
My htc hd2 phone is showing unable to initialize camera. failed to set up the camera device.
Consult your owners manual, failing that take your phone to your service providers store location for tech help and if the phone is less than 1 year old with no water damage manufacturer warranty covers factory defects and if you have extended warranty plan they should give you a new one on the spot.
Nov 12, 2010 | HTC Cell Phones
Will not Auto focus is there any thing I can do? I have tried all focus settings and no luck. I can focus a picture by using the Zoom out.
Try the following troubleshooting steps:
1. Initialize the Camera.
MENU-->SETUP-->SETUP1-->Initialize.
2.Power reset the Camera.
Remove the battery of the Camera for atleast 1 minute.
This should resolve the issue.
Jul 20, 2010 | Sony Cyber-shot DSC-N1 Digital Camera
Cant take photos and lense dosn't focus. lcd shows " E : 61 : 00 " and its blinking
I'm sorry that the camera is not turning ON. Please make sure that the battery is fully charged. Check if you are able to access the Menu. If yes, then, please Initialize the camera under settings 1 Menu. If you are not able to access the menu, you may have to power reset the camera by removing the battery and press n hold the power button for 1 minute continuously. After that leave the button and insert the battery and check if it helps. If the issue still persists, your camera will require service.
Sep 26, 2009 | Sony Cybershot DSC-H3 Digital Camera
Dsc-t70/t75/t200 E61.00 is show on my screen and i can take a picture with it
E:61:00 Difficult to adjust focus
(Cannot initialize focus)
Retry turn the power on by the power switch. If it does not
recover, check the focus reset sensor of lens block (pin ea of CN401 on the SY-183 board). If it is OK, check the focus motor drive IC (IC401 on the SY-183 Main board).
Jul 22, 2009 | Sony Cyber-shot DSC-N1 Digital Camera
Error code E:61:10 for my Sony DSC-T70
hit the camera a few times it will go back to focus i had the exact same problem E:61:00 and it worked like a charm...
Nov 17, 2008 | Cameras
5f 08, 5e 02, Olympus 710, Help!
hi alexandra olympus cameras are know for having a few lens problems when ever a blue screen comes on the camera is faulty it sounds to me like you have some dirt or dust in the lens i have seen this problem a few times hope u get it sorted goodluck
Sep 28, 2008 | Olympus Stylus 710 Digital Camera
Blue out of focus; casting blue "glow"
Try changing the coolant in the blue tube. Contaminated coolant will give a halo look to the affected tube and you will experience difficulty focusing that color.Phillips/magnavox's blue is the tube most often affected with the contaminated coolant issues.
Mar 01, 2008 | Televison & Video
Blue screen error code
the lens open halfway, the picture on the LCD is blurry and one second after the lens close and an error appears of the screen saying "D: 5f08 5e02". what does this mean??? can you help me fixed this one??
Oct 13, 2007 | Olympus Stylus 700 / 700 Digital Camera
Cameras Logo
169 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
