Question about Samsung RFG237AAWP Bottom Freezer French Door Refrigerator
I have a samsung french door refrigerator that is only 20 months old and it just started making a very loud humming noise that is coming from the back/top of the fridge. It stops when you open the fridge doors only (not freezer door). The only way to make it stop is to unplug the fridge for several hours but then the humming returns again. I have also seen some ice build up in vent holes of the fridge. Any ideas what is wrong?
SOURCE:
  • 5 Answers
SOURCE: loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Posted on Sep 20, 2008
  • 22 Answers
SOURCE: refrigerator
the fan behind the ice maker is iced up poss fault defrost heater gone try total defrost faor a list 36 hrs restart it noise come back then you need to repace the defrost heater hope this helps
Posted on Nov 13, 2008
tborn6
  • 700 Answers
SOURCE: fridge has just started making loud noise and temp too high
sound like that you have a ice build up thats hitting your fan blade. Take and do a manual defrost on the frig side and be extra careful removing the cover in the back because there's 11 screws that have to come out before trying to remove the back poanel. Also if theres stillo ice in there what happens is that when you try to pull the back panel off it breaks off the stryrofam that samsung used for the air paths to cool the frig. so be extra carefull removing theses and if oyu do tear any and the airflow is not going the corect way you will drive yourself bonkers always defrosting htis unit. so heed my warning on this particular unit. its a great unit if you can psture what has to happen for the air flow to be correct. also put all of the screw back in correctly on the panel too. don't skip any because then the air flow is compromised. Good Luck and don't forget to rate the answer please. Haooy Neew Year!!!
Posted on Jan 01, 2009
heatman101
  • 43501 Answers
SOURCE: Hi, My fridge ( 420 ltrs)
The noise is the fan hitting ice build up on the coils... it is no defrosting properly...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 14, 2010
Daniel S
  • 4323 Answers
SOURCE: RF263 series Samsung Refrigerator just began
Hi
The sound comes when there is ice build up around the fan and the fan will hit it causing this sound. You can try to leave it unplugged for around 4-24hrs and also make sure that the area near the back is clear so that airflow can get through. If the issue returns then replace the thermostat. Hope this helps...please post back for further assistance.
Daniel
Posted on Jul 01, 2011
My Samsung Refrigerator is making a noise that sounds like an old style door bell. It a loud buzz that occurs several times a day. Do you have any ideas?
User manual and parts list and diagrams.
SAMSUNG Refrigerator Parts Model RF217ACPN XAA
Your refrigerator has at least three motors with fans in addition to the compressor motor. The one most suspect is the one that passes air from the freezer to the refrigerator.
samsung refrigerator noise YouTube
Oct 19, 2014 | Samsung RF217ACPN - 20 cu. ft. French Door...
Loud humming noise
Happens when the bearings in the fan or compressor motor are getting worn out. make sure there isn't a piece of cardboard cowling or debris hitting the fan.
Jan 11, 2014 | Maytag MFI2269VEM 22.0 cu. ft. French Door...
What would cause an intermittent buzzer noise from a Samsung RF217ACRS refrigerator? It otherwise works fine.
That's the icemaker cycling.Ifya don't have water connected,it's still think'n its filling trays and dumping frozen cubes and all that stuff.Turn off the icemaker.Rigger said that.C-YAAaaaaaaaaaaaa
Aug 28, 2012 | Samsung RF217ACRS - 20 cu. ft. French Door...
Samsung rf265 series refridge is making a loud humming noise--only 1 year old
It is a well known defect.
the ice is builing up until it interferes with the fan.
The samsung people will not help you. You are screwed.
A&E appliance repair(Sears) told us to take all the food out and leave the doors open for 24 hours.
This happens at least once a month.
We cannot ever buy a fridge from Samsung again or from Lowes.
They ****** us hard. Good luck
Mar 21, 2011 | Refrigerators
Loud buzzing/rumble when running
Try this website "appliance partspros.com" You enter your model numer and the have compete breakdowns with pistures and how too instructions. the best part is if you join the websites blog......there you ask questions and an expert appliance reapir person sends you a reply. I have used the website for a few years and have never been steered wrong.
Jul 22, 2009 | GE Profile PFSF6PK Bottom Freezer French...
Loud humming noise as fridge is running
if you have ice buildup then the fridge may be low on freon.
or there is dust clogging around the pump or fan is not running.
remove the bottom or back and look around the compressor.
see that the fan is running.
Jun 04, 2008 | Sub-Zero 661/F Side by Side Refrigerator
Sounds like the freezer fan is rubbing some wires or possible some foam insulation around the fan. I would look into the freezer compartment fan and go from there. The fan Will Shut off when you open the doors. Let me know how you make out and if you need anymore help.
Thanks,
Bill
Apr 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Samsung RFG237AAWP Bottom Freezer French Door Refrigerator Logo
277 people viewed this question
Top Samsung Refrigerators Experts
Paul
Gerry Harvey
Gerry Harvey
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
