Question about Music
PEAVEY ECOUSTIC 112 W/ NO SOUND ----muted?
Yesterday I was playing through my amp and it was working fine. I have had the "Pre-amp Out" jack in the back of the amp hooked up to my Behringer PA so that I can hear a little of my guitar playing through the PA while I sing.
Yesterday I unplugged the cord attached to the "Pre-amp Out" jack because I was going to use the cable for something else. Then, when I tried playing my guitar again - there was no sound. When you turn this off though you can hear the amp "Thump" through the speaker, so I do not think it is a speaker problem - PLUS all lights are on.
The one thing that I CAN find on the Peavey website regarding this is the following statement, "A single button‚ shielded footswitch used in the preamp out jack can be used to mute the amplifier."
BUT---that is the ONLY reference to this..so what I am worried about is that it is now set in MUTE with no way to get it back unmuted...Please help - I use this for my church and need this more than you will ever know
Thank You
  • 6 more comments
  • John Westbury
    John Westbury Aug 31, 2008
    I also opened it to make sure all of the connections were connected and all seems to be in order.
  • John Westbury
    All connections inside and out are connected
  • John Westbury
    I checked the guitar cable with my PA and it works fine. I played the guitar through the PA because I thought it also might be the guitar.
  • John Westbury
    i tried replacing the fuse and it does not seem to be that. Also, my guitar does work on other amps.
  • John Westbury
    I do not see a master reset. I opened it yesterday and there does not seem to be a wire loose. If you turn it all the way up you can hear a slight humm through the speaker. Just no cable sound from ANY cable or instrument or MIC.
  • John Westbury
    I checked the speaker and there is nothing wrong with it. I tried to re-create what I did unhooking it from the p.a. and nothing. When I opened it, there was only one fuse I could see, so I replaced it with another of the same kind. Should there be another? I cannot beleive no one has had this happen.
  • John Westbury
    PEAVEY MOD-- ECOUSTIC 112
    SER # 50567909
  • John Westbury
    I could not see anything burnt at all inside. Also, I do not ear any scratching when I press in on the speaker and there is really no sound whether I plug in anything or not. I can hear electricity ( very faint) but this is whether I plug something in or not.
    I stopped working while I had it on I thing, but I had it down low.
    Genius:
  • 1,011 Answers
Dear Sir/Madam,
Tune/Cal: This switch turns on the built-in tuner for approximately 60 seconds. Press a second time while playing a note and this pitch will become the calibration point for operation (handy when tuning to an ?out-of tune? instrument). During the tuning operation the guitar output will be muted. If you finish tuning prior to the 60 second timer returning the tuner to idle (and un-mute), you may press this button again to manually return the preamp to normal operation
Thanks
Good Luck
Posted on Sep 01, 2008
    Genius:
  • 2,035 Answers
Please the the amp with PA again then if it plays then and cable is fine you get the guitar circuit as it may have loose circuit you need to get it serviced...
    Brigadier General:
  • 6,966 Answers
Pls check the internal contacts of the pre-amp out jack. It simulates a switching action. It may be necessary to clean/scrape/bend them to restore operation.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
  • Louie  Role
    Louie Role Sep 01, 2008
    My apologies to Abrsvcs, this would appear to be along ( a variation) his solution.
    Brigadier General:
  • 5,158 Answers
Test the wires you are using with a multimeter to make sure they all show continuity
Robert
Posted on Aug 31, 2008
  • 2,071 Answers
This is an amp problem maybe it is cold or crack solder joint of the parts.It needs to reworks the solder so it will works normally,it would be much cheaper and quicker for you to take the amp to a
qualified repair shop and pay the price for a competent repair.
Hope this may help;
Regards,
VOTIT
  • LORETO LACARON
    LORETO LACARON Sep 07, 2008
    Did the solutions from all of us experts solved your problem if not then let us know the current updates so all the fixya experts can assist you further.
  • 4,234 Answers
I have not heard of the use of the pre-amp out as a switch as this is just a cutoff from the internal amp section. I assume that this pre-amp out is a 1/4" connector. These are switched internally such that when the jack is used to send sound to an amp, the internal amp is disabled. The thumping you hear is caused by the amp section. This essentially means that the amp is working as expected. Can you please post the model number that is on the metal plate? With that I can look up the service manual and try to explain this.
Dan
  • Music Master
  • 1,879 Answers
Make the PA act like a foot-switch, re-insert the cable. might do the trick.
else you gotta look for a foot-switch.
    President:
  • 1,263 Answers
. unplug and plug back in. hit the master control reset. if this doesn't solve the problem. take the back panel off.(don't do this if it voids a warrenty). check for a loose tube or chip on the main board. also make sure a loose wire has not come off the pre-amp out jack.
  • Ronald Mueller
    Ronald Mueller Aug 31, 2008
    as i stated your main board has a glitch and should be replaced by a music store tech they have the schematics and the replacement for you board. anything else is just a guess. you amp heats up and over time the heat causes the tube or chip connections to fail good luck
    Sergeant:
  • 241 Answers
HEY there MY MY AMP has the FUSE on the box it can be hidden sometimes. Take a look for the fuse and see that. Not sure what Guiter you have but some have a small (round) battery next to the EQ/Volume
  • 8 more comments
  • Jayson Brollini
    Jayson Brollini Aug 31, 2008
    HEY post your comments if you need help
  • Jayson Brollini
    Ok so you amp is tha problem.
    >You can try 2 things that should help
    (1) do you have a plug or and adapter (mono/stereo) that you can plug into another device to test the (AMP)
    Example: A another Gutiar or A keyboard or any other Audio device and hooked it to the amp. "this may tell you if the phone input is bad or loose" also wiggle the plug too to see if that cuts off the sound.
    (2) Caution> only if you feel comfortable unscrewing the AMP/SPEAKER
    You can remove the speaker cover/grill and carefully pull it out to see if the connection are loose or if the COIL is BLOWN and if any thing is wrong you will smell a bunrt smell
    And if that is ok unscrew the control panel/phone jackes EQ and check the connections there too
  • Jayson Brollini
    Ok that sound like the crossover is maybe the problem,
    You have open up the AMP and look at the internal board.
    look for a small fuse on the board or look near the heatsink.
    > Look for a pop/burned resister
    >Did you have the AMP on when it went off and DID you CRANK .
    > TEST 1:TRY to gently push the front of the speaker using two hand and applying even pressure to see if you hear any scratching (unnplugged the AMP for this test) NOTE: do not touch the center of the speaker(dust cover of the cone/woofer)
    >TEST 2: Follow the same instructions but turn the AMP (ON)
    turn it up half way and plug the GUTIAR OR any INSTRUMENT that will give you a continuing audio sound. NOTE: This test will tell you if the speaker is blown or fixable. you do not need to apply a great deal of pressure just make sure in is even pressure. push the speaker in untill you can hear the sound (it should get louder)
  • Jayson Brollini
    OK I need the Exact model number please...I read the post at the top and for some reason part of it was missing from my view.
  • Jayson Brollini
    Is the bypass foot switch ON or OFF Try plugging the Mic back in and tuen off the bypass
  • Jayson Brollini
    THIS is not as common as I thought I am really looking. Do you have the manual and under the Bypass there should be a page on the mute release.
  • Jayson Brollini
    OK i look at the manual the Channel Select Switch (6) must be in the LEAD position for the Remote Switch to work.
    www.peavey.com/assets/literature/manuals/00583640_3.pdf
  • Jayson Brollini
    TRY plugging it in and the adjust the sound/volume there
    I hope this helps
    PLEASE RATE YOUR FixYa ExpertKindofcheap
  • Jayson Brollini
    Jayson Brollini Sep 01, 2008
    Rate the Advise from FixYa ExpertKindofcheap
  • Jayson Brollini
    Wish i could of Helped
    Genius:
  • 1,269 Answers
You might find the answer here:
http://www.sanctuary-series.com/downloads/s4_manual.pdf
    Master:
  • 521 Answers
Is u cable working okay with other devices. plse recheck.
  • tech expert12 Aug 31, 2008
    as it is very rare problem.and solutions from all of the experts should solve your problem for sure.but it not been able to so i suggest you to take a technical knowledge at your place because he will be having all the required parts ready on the spot with him.and you have got quiet knowledge if he tells some fake about replacing.and it will really help you to know when the engineer is at the place.
    thanks.
    please do rate the solution.
    Brigadier General:
  • Music Master
  • 3,614 Answers
Check all the wire connections
Peavey special 112 solo amp cuts out.
Unfortunatly, there could be a few different causes for this and without the amp in frony of me it would be impossible to diagnose it. The best bet would be to have a qualified repairman look at it. Here is a link to the Peavey Contact page which has a link to their service centers.
Peavey com
Feb 26, 2015 | Peavey Music
Peavey bandit 112
cracked solder joint, bad pot, dirty insert jack
Aug 14, 2014 | Peavey Bandit 112 Guitar Amplifier With...
Im having a problem that alot of other people are having. my 112 is giving off this constant static and crackle. ive been reading that it could be abad jack in the effects loop.if anyone knows exactly what...
Could be a bad jack like you say. Have you changed your guitar cable? Your cable can make a HUGE difference. Can't know exactly which part it is unless its sitting here in front of me...
Sep 03, 2011 | Peavey Valveking 112 - Tube Guitar...
I'm trying to get a crunchy metal sound from my peavey 112 bandit. What should I set my controls to?
Overdrive is the key to the crunchy metal sound. The only effect on that amp is reverb.
You may want to consider getting an overdrive pedal to get the sound you want.
Mar 02, 2011 | Peavey Bandit 112 Guitar Amplifier With...
When the power switch is turned on the amp just has a loud hum and nothing works not even the little power indicator light..
You have a bad ground probably inside the amp , you need a on hands Tec for this one. I bet its not to serious , about $65.00, is it worth it to ya all tho I don't know your area , but its been my exp.this would be a fair price most any where. good luck DFD
Apr 13, 2009 | Music
then i'm afraid that your main board has a glitch that you can't repair. take it to a music shop they have the neccessary parts to repair this problem and they have the schematics that will show them which chip is faulty. i'm not sure how long you have had this amp but over time the heat causes the chips or tubes to fail. that is the best answer i can give you at this time anything else would just be a gues and a waste of time. good luck
Aug 31, 2008 | Music
Music Logo
508 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
