Question about Frigidaire FRS26R4A Side by Side Refrigerator
Frigidaire FRS26ZSH freezer leaking
I have the same problem already described by others - water leaking out of the freezer. I manually remove the icesheet every couple of days to avoid water puddles on the kitchen floor. Any suggestions how to fix this permanently would be most welcome.
S.
  • Anonymous Sep 10, 2008
    I turned the water off to icemaker and the water stopped forming an ice sheet at the bottom of the freezer--but the back completely iced up and now I need to fix the thermostat or defrosttimer . . . which may have been damaged after ages of dripping water or . . . and now am unable to get water flowing again--so whatever you do--don't turn the water off . . . just keep chippin away until there is an answer.
  • sebastiandog Sep 14, 2008
    I have almost the same model, a FRS26ZSG. I just recently started leaking water. I noticed a spewing sound everytime I opened the door and after the 4th time a large water puddle appears and I then had to go check it every ten minutes to twist out the towel full of water - this is aggravating... I took off the front plastic cover but cannot see any visible water dripping down.. There is no pan underneath which is different from my last fridge but does anyone know what is causing this.. Is it repairable..? I have not had the ice maker ever connected so I know it's not caused by that which I have seen in other posts...
  • 76 Answers
Plz provide me with a e mail adres so i can foward a users manual to you for a Frigidaire FRS26ZSH.
Thanks.
Wouter....
Posted on Sep 10, 2008
Frs26zsh is having wter leaking and freezing at bottom of freezer what can i do
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 06, 2011 | Frigidaire Refrigerators
Frigidaire leaking water out the bottom
it comes from freezer. remove back cover of freezer and unclog hole where water collects
Feb 13, 2010 | Frigidaire GLRS234ZA Side by Side...
Frigidaire FRS26ZSH -ice & water dispenser panel lost power
I think you will need to unplug the pin plug under the cover at top or bottom hinge. Check the voltage and if OK leave unplugged until you can remove the dispenser and I will try to help you from the power source. Sounds like a short in the board and related to the light socket. The fuse only stopped the short from doing further damage, You may need to locate the short before replacing the fuse or board. I have looked over the wiring diagram. If you find the short without my help just be sure to replace the fuse with the correct size. The only things are the chute heater or something in that area of the board went to ground. Do you have a voltage meter? Contact me later when ready, Sea Breeze
Jan 20, 2010 | Frigidaire FRS3R5EMB Side by Side...
I have a Frigidaire Model FRS26ZSH need water filter instruction
Filter Status Press and Hold five seconds to reset light. (This light will tell you when to replace the water filter.)
press the button to the right of water filter to release filter...
Sep 17, 2009 | Refrigerators
Frigidaire gallery pro series model frs26zsh water leaks out somewhere goes into backside of freezer eventually goes down to underside of bottom basket and freezes
Mor than likely you have a clogged defrost drain. Drain is located at the bottom of freezer compartment behind the back panel. You will have to remove the panel and blow out (or vacuum) the drain hole. Hope this helps
Jul 31, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Ice Build Up in Freezer of FRS26ZSH
I had this problem. You need to clean out the drain under the freezer. The tech that came out used a squeezie bulb similar to what you use for a baby to clean their nose when clogged. You have to remove all the shelf's and the back plate. You need to use warm water to defrost the frozen ice and remove. use water and squeeze into the hole and **** out.. takes 10 minutes.. finally it will drain.. no parts are necessary. good `luck
Jul 23, 2009 | Frigidaire FRS26R4A Side by Side...
Fridgidaire frs26zsh side by side ice buildup in bottom freezer
if you have icemaker install check there or you have a clogged in your drain cut ashort piece of naked wire wrap it on the heater coil and puch wire down in drain not a long piece please unplug refrigerator
Mar 30, 2009 | Frigidaire FRS26R4A Side by Side...
Ice and Water dispenser
no manulal reset or fuse, buth tere is ususlly a "child lockout" feature prevent ing the dispensor from operating. check to see if the control has been placed, on, or perhaps the door is not closing fully, another reasom for the dispensor to stop
Jan 17, 2009 | Frigidaire FRS26R4A Side by Side...
Frigidaire FRS26R4A Side by Side Refrigerator Logo
507 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
