Question about HP Jornada 928
Water damage Hi there very disappontingly I got my jornada 928 damp whilst out bush walking. I had it in the non waterproof part of my pack. It still shows some sign of lifeand gets to the hp invent sign and sometimes to the startup screen for the machine . But it always fails once i try to get past the first screen. At the moment it is sitting in the cradle and periodicly fires up to the white scren and the timeing circle or the tap the scrre screen. Is there anyway to resussitate it thanks in advance
  • 450 Answers
It is probably permanently damaged now. In general with electronic devices if you get them really-really dry before turning them on then a little clean water doesn't hurt. These never really turn completely off though so just getting them wet might be the end.
Posted on Sep 12, 2005
Can you buy fanny packs that are waterproof?
Sure you can. They make waterproof fanny packs for people who are snorkeling and doing other under water activities. It's best to look out for fanny packs that come with a certification of some kind to prove that they are leak proof etc. But you'll have to be willing to pay a lot more money for it than you would for a regular fanny pack. Good luck.
Aug 04, 2013 | Luggage & Travel
Do I chanage water pump when changing timing belt on 2002 lexus GS300?
Most Japanese designed engines have an internally mounted water pump, usually driven by the cambelt.
When we talk in terms of cam design, there are two types of engines: a) Interference and b) non-interference.
An interference egine means - if the cambelt were to break whilst engine is running, there will be major internal engine damage.
A non-interference engine means - if the cambelt were to break whilst engine is running, there will NOT be any serious internal damage to the engine.
Note: the GS300 engine (3.0L 6-cyl) is considered a Non-Interference engine.
So, one of the most critical compenents which MUST be changed, is the cambelt itself. Most manufacturers recommend changing this belt every 90,000 - 100,000km's (80,000 miles). If you have a non-interference engine, this period is not as critical, but should still be changed soon, to avoid the inconvenience of a breakdown whilst travelling.
The 2nd critical compenent is the Water Pump. The worst possible outcome of a failed waterpump, is your engine will suddenly drain of all coolant, resulting in serious overheating, causing serious internal damage to your engine.
Although there is no specified time to change the waterpump, a waterpump endures wear and tear like any component and lifespan can reduce rapidly beyond 100,000km's (80,000 mles). As the waterpump is situated next to the cambelt, it is a general rule to change out both cambelt and waterpump at the same time.
The majority of the cost to replace the cambelt, is in labor (ie opening the engine etc). If you choose to replace only one of these components, you will need to be prepared to pay for same procedure again in future, to replace the 2nd component.
Therefore, it can be more economical in the long term, to have both components changed together.
Hope this helps...
"If this has helped you in any way, please rate this solution with thumbs up, or kindly leave a testimonial"
May 30, 2011 | Lexus GS 300 Cars & Trucks
The swing mixer handle has become very stiff. how do i get it off to clean it/
The first solution is of course correct. However I found it almost impossible to remove the spout assembly. It was very stiff and it was difficult to get any leverage to force it off without damaging the finish to the tap as a whole or damaging the sink.
What I found was that if you poured boiling water over the tap/faucet it eased the stiffness and having done this several times - ie about 5 kettle loads of hot water, I managed to remove the spout. It helps if you reconnect the hose directly to the outlet under the sink (ie not via the faucet). THis allows you to run cold water through the tap whilst pourung boiling water over the outside of the tap. The cold water shrinks the copper/brass components whilst the hot water expands the spout assembly.
Once off, it is possible to clean the inside of the assembly to remove corrosion or calcium deposits to say nothing of old "O" rings.
I also used a kettle descaler between dousing with boiling water in the hope that some of it would seep down within the assembly.
It took me three attempts to do this. I was almost going to spend UK pounds 430 or US dollars 670 and buy a new unit. So do not give up and I hope this helps.
It swings backward and forward now perfectly.
Aug 27, 2010 | Blanco Classic Single Handle Faucet with...
My documents in my Honeywell safe are moldy and damp
Desiccant Moisture absorbing packs will help to absorb some of the excess humidity in the safe. In addition to the desiccant packs, you should open the safe at least once every two weeks for approximately 20 minutes. To alleviate some of the musty odor, we suggest that you remove the items from the safe and wipe the interior with a paste of baking soda and water. Do not store your safe unit in areas of your home or business with already high humidity levels such as a basement or cellar as this will add to the moisture problems. You can purchase desiccant packs from . The link for the desiccant packs is:
May 10, 2010 | Honeywell 1070 cu in. Waterproof Firesafe
1984 928 began running very rough & lost all power. Shop indicates 0 compression on 4 cylinders and that likely cause is slipped timing belt and damage to valves on one side. I thought 1984 engine had...
depending upon the rpm that the engine was turning at, I have seen "non interference" engines bend valves on a timing belt or chain failure.
if you have 0 compression on that bank, it will need to be torn down to find out why. BUT I would do a cylinder leakdown on those cylinders after the belt has been removed (so you can turn the cam and close the valves for each of those cylinders), to make sure that they are not properly sealing, before removing the cylinder head.
Aug 30, 2009 | 1984 Porsche 928
Internet explorer error
Do you have problems also with downloading your e-mails? If not, you have problems with DNS - your computer cannot recognize web page name and convert it into proper IP number. Try to contact with your ISP and gain these numbers, which you have to enter into proper place in Connection menu (Advanced options)
Sep 12, 2005 | HP Jornada 928
Clock out of control
I have a Jornada 568 but I've never seen the behaviour you describe. Is it possible that you damaged or caught a small part when you installed the new battery? Your new battery, was that the small round battery or a battery pack on the back of the unit. "Resetting to Factory defaults" suggests that there is no power at all, doesn't it? If the small round watch battery is dead then that might effect the clock.
Sep 12, 2005 | HP Jornada 568 Pocket PC
HP Jornada 928 Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
